#1 |
Guest
MTX Shifter Knob
Hey guys, I'm in the process of fixing up my 94 Probe GT all nice and clean again and want to replace some worn out parts to make her look closer to new again, and one thing I wanted to replace is the factory 5 speed shift knob. I like it and don't want to change to something else, but mine is getting worn out.
So my question is, does anyone know where I can get an exact replacement, or maybe even get it repaired? I'm pretty sure Ford doesn't sell it anymore, and they would be to $$$ anyway, however I see that Mazda still sells theirs for the 94 MX-6. Does anyone know if they are the same? Any info would be appreciated Jason |
#2 |
Ludicrous Speed.
Find a junkyard
They aren't hard to remove they twist on, and are lighter typically than the ricer knobs.
PhotoPOC(tm) 95' base stocker, 5-spd, chrome swirls 94' PGT cai/Hotshots/Greddy SP2, battery relocation and 100 wet shot, gutted and broke.....current project |
#3 | |
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 1997 Ford Probe GT [SOLD] Black PGT '93 MTX: [Hotshot CAI][CenterForce DF][Mx-3 Flyweel][MBX Dual Feed FPR][Red PRD Wires][P&P IM][F & R Polish Valve Cover][67mm TB][Insert Mounts RR-Racing][FD Strut Bar][Custom B-Pillar Bar][Custom Tranny Saver Red Powdercoated][Tokico HP Struts][DZ Springs][Chrome Wheels][Gauges AutoMeter C2 & Cobalt][Clear Corner][PRD Fan Shroud][Kenwood eXcelon & Rockford Fosgate Sound System w/ Kicker Components] |
#4 |
Yeah, Mazda should still sell ones for the MX-6/626. If not, almost any shift knob from the newer Mazdas should fit as well.
Kevin B - Former Probe-owner To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
Five Star Member
also if you pull of the leather then you will just have a knob that says 1-5/R on it and i dunno I sorta of like mine... its abit smaller, and well its rubber so has more grip. I find atleast.
94 PGT - 12.9@114 stock de block, ze intake, portmatched de heads, Colt Tri-flows, Ebay turbo kit, .50/.63 t3/t4, 3" truebendz downpipe back, 2.5" ic piping, nissan 550's, cosmo afpr, tre 255lph, fidanza fly, act unsprung 6 puck, stock PP, trans saver, msns v2.2, aem wideband, Egr, PS, AC, VRIS delete. Needs Brakes then traction mods. |
#6 |
Guest
Yeah, I've tried a few local junkyards, but it's hard to find any probes in them at all. Or heck, even MX-6 626 are hard to find in those years. I think my local junk yards are just too small
Thanks for the input guys. |
#7 |
You can pull off the leather and it will be like an SE knob, it will still have the shift pattern on it underneath.
07 Mazda 3 S GT Sedan (Phantom Blue Mica):[5-spd][F2 CAI][Borla CBE][F2 Rear Sway][RX8 Wheels][Progress Springs][Koni Struts][TWM STS] SOLD:96 PGT 100K:[Borla][Catco][K&N][IAT mod][Hayden 404][ZR1 Filter][16mm 626 Swaybar][Tokico Springs/Shocks][13.7lb FDs][Z24 Lip] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 |
ProbeTalk MC
yeah, pulling off the leather sounds like it will do good for you.
or you could go out and buy yourself a civic short throw shifter from ebay, and the factory '98-'02 shift knob from an accord. (both found on ebay) it looks like this http://www.collegehillshonda.com/pau...-sm4-003zb.jpg and it threads right onto the civic short throw, and possibly threads onto the stock shifter also. you will hit two birds with one stone, because you will also be getting rid of those worn out shifter bushings that make your shifter feel all sloppy, and replacing them with bearings that the civic short throw has.
1994 Probe GT Megasquirted ZE - 183.7whp/167.2wtrq on 87 octane 1995 Ford Probe GT - bone stock 2005 Saab 9-2x Linear... grocery getter 2008 Ford Fusion SEL 32mpg Company car. |
#9 |
Google monsterknob - highly recommended!
94PGT, Borla Catback, SSA Headers, Magnaflow HF Cat, HS CAI/K&N, Cosmoracing STS, 10.2mm IW/NGK Iridium IX |
#10 |
Guest
Actually, I already replaced the bushings, so it's much better now, lol.
Also, as a clarification, is the same year MX6/626 shifter exactly the same (looks wise, I understand the threads are the same)? I want one that looks/is exactly the same |
| Thread Tools | |
