Take your Ford Probe to the edge of top performance and style with headlights, lowering springs & real wood dash kits on sale now at AutoAnything. Don't miss out on top name brands such as Thule racks & Yakima racks, K&N, Magnaflow & Autometer and save $10 on orders over $100 today by entering PROBETALK in the checkout cart!
| Register | FAQ | Members List | Timeslips | Calendar | Arcade | iTrader | Mark Forums Read |
Thread Tools |
#1 |
Primary Shaft Oil Seal Replacement
This explains how to replace your Primary Shaft Oil Seal. This How To assumes you already went through the Teardown How To, and should now have a Clutch Housing Case that looks like this:
http://img125.imageshack.us/my.php?i...tep291fnx8.jpg The Primary Shaft Oil Seal is on the top left, next to the breather tube. You don’t have to unbolt the breather tube, but it does make it easier. Note that there is a gasket under it, so if you tear it, replace it or make a new one. Let’s do this!!!! With a small flat head, GENTLY wiggle the outer race. This race is NOT pressed in, but is in there tight. You may even be able to just use your fingers to rotate and pull to get it to come out. Do not scratch the inside of the race. http://img55.imageshack.us/my.php?image=step1sl6.jpg With the race out, pry out the old seal, making sure to use the groove in the side of the housing like in the pic. I also used a couple of paper towels as extra padding. Don’t scratch the sides of the housing that come in contact with the seal! http://img111.imageshack.us/my.php?image=step2pv3.jpg Grab your new seal and oil up the outside parts. Place it inside the housing and push it in some. You won’t be able to push it in all the way by hand, so just make sure that you get it straight. Get a socket that is as close to the diameter of the seal as possible and place it on top of the seal. Now tap it in. Don’t just hammer away at the same spot, move around. The seal may tip a little on you, but that’s OK. Just tap in the other side a little and you will be back on track. http://img115.imageshack.us/my.php?image=step3uc0.jpg Time to put the outer race back in. Again, this race isn’t pressed in, but it is snug. Line it up by hand and then firmly push it down using your palm. If it gets stuck, don’t ram it in and DON’T hammer it in. Just take it back out and try again. http://img55.imageshack.us/my.php?image=step4im2.jpg You are done! http://img111.imageshack.us/my.php?image=step5dd8.jpg Who loves ya baby? -Chris
"The ultimate result of shielding man from the effects of folly is to people the world with fools."
#2 |
Your a very good guy to do this. Thanks alot.
1996 PGT-T...276hp/264tq@8psi....on a very conservative tune. N20 is like a beautiful women with an STD: you wanna hit it but your afraid of the consequences. I'm built to fire once.....like a musket. |
| Thread Tools | |
