yes, everything else was fine, you should redo the schmatic in the correct wire colors.
Using a KLZE DISTY with HEI , anyone intersted?
i have a question about the 4 pin j spec plug
the color of my wires are why different from that diagram
from the front of my engine to the rear first i have pink then orange then red/blue (thickest) then black/red
what wires are what? can you tell me from front to rear of you engine compartment what wire is the grond, pcm power relay, crank pos, sensor, cyl ident?
I did this mod a couple years ago and have the diagrams all laid out as well. I had the setup running with the MSD Digital 6+ ignition and Blaster HVC coil though, so mine was a little different. If anyone would like to see my diagrams, let me know, I can scan em..2014 BMW 328d Luxury Line- Mineral White/Saddle Brown Leather, Premium Package, Driver Assistance Package, Cold Weather Package, Navigation, car seats inside
2012 BMW X3 35i M Sport- Traded
2003 BMW 330i ZHP- Alpine White/Natural Brown Montana Leather, Performance Package, Cold Weather Package, Navigation, Certified Dinan Stage III, car seats inside
2004 BMW 330i ZHP- Totaled
Originally posted by jon93PGTI did this mod a couple years ago and have the diagrams all laid out as well. I had the setup running with the MSD Digital 6+ ignition and Blaster HVC coil though, so mine was a little different. If anyone would like to see my diagrams, let me know, I can scan em..What's a ZE?
i don't know, but your email address is NOT working and it needs to be fixed ASAP!
I am planning this on a '95, since my stock disty might be fried. What is the main difference in the wiring, since the '95+ distributers have a five wire lead versus the 6 wire lead? Also, I see a 1K ohm resistor in the mix. Will any 1K Ohm resistor work?'08 Cadillac CTS 3.6DI FE3 MTX
'07 Lexus IS350
Originally posted by Tim95pgtI am planning this on a '95, since my stock disty might be fried. What is the main difference in the wiring, since the '95+ distributers have a five wire lead versus the 6 wire lead? Also, I see a 1K ohm resistor in the mix. Will any 1K Ohm resistor work?Last edited by Mbolin5; July 18, 2006, 01:38 PM.
What is the wattage on the 1K ohm resistor? My local Radio Shack only carries 0.25 and 0.5 watt versions. I found the HEI module and the Blaster Coil locally, so all I lack is the resistor.'08 Cadillac CTS 3.6DI FE3 MTX
'07 Lexus IS350
