Here's my write-up again this is the last time I'm posting this or chiming in on this... If you don't read this I won't help you.
Read on though.
When I was installing mine I tested them with the gauges out of the pod, and there was a very VERY muted... I tested again once I had it all together in the pod and I had to get my head down onto the cluster to hear them. That was on the brightest green setting... With my head in normal driving position they were inaudible... Once they were installed and running they looked sweet. There is no issue of quality here...They are good...
Some complaints...
1. The power wire for the center piece exits the pid directly where one of the clips goes (easily fixed using a small coping saw to cut opening for the wire)
2. On my set the wires to the controller (digital buttons) were upside down, so they
only lock when the color change is controlled by the dimmer, and the dimmer controlled by the color change. (easily fixed by just flipping it upside down and using electrical tape to hold it...)
3. The connectors from gauge to powerlines were expensive ones, but cheap ones that hold stronger would have been prefered by me.
4. The words on the information center lights (CEL, Airbag, Parking Brake) are kinda hard to see. Not a major problem, but hey I'm trying to rant so you guys won't have to later. I'm thinking of solving this by cutting out their little white screen that covers the lights, then ordering the speedhut carbon fiber overlay, though I'm too lazy to do it now.
All my gauges work well, and I used alot of 2 sided tape because I don't want them to shift, nor bubble out. (causing needles to hit them). The only problem here (found out after lotsa hair pulling) is that the little holes are just a little too tight, I used a small piece of sand paper rolled into a cylinder to enlarge the openings. I started with 150 grit to get the hole open (you can use larger, but it is what I had) then went to 400 grit to smooth it all out. My gauges work, and the light up extremely well.
In closing,
They look Sweet
Chris
That should be all you need to know. Email me if you need anything else.
- Remove the screws holding the knee bolster on, and pull it out set it aside (2 screws bottom, 2 clips top)
- with this out of the way remove the 5 screws holding the gauge shroud on (black thing, 3 up top, 2 bottom). pull shroud out and to the left disconnecting the dimmer's wire and set the shroud aside.
- With that out there are 4 screws holding the gauges in (each corner) remove those and begin to remove your cluster. it's hard to fit out, and half way through you have to disconnect the wiring.
- with the cluster out you can remove the clear plastic cover, then the black spacer.
- To install the gauges on the sides simply bend the new face and slide over needle. For the speedo/tach remove the black endcap on the trip set button and depress button fully. Rotate your gauges to a perpendicular position compared to the bottom of the cluster (needles parellel) then just bend and pull the gauges over the needles and trip button. I used lotsa 2 sided tape to hold them down away from needles, and checked them for free rotation before installation (holes were eventually enlarged see complaint section)
- once that is done modify the prong as noted in the complaint section below. Put cluster back together and wait for reinstall.
- Next remove your shifter knob, and then your center console.
- Remove the 2 screws holding the center dash panel and remove panel
- I used the power wire from my foglight switch to power the gauges (as directed on the directions sheet do not use the dimmer wire for power), and ran the ground back to under the cupholder area (I like solid grounds)
- I then taped the black box to the bottom cross member of the center stack.
- With that wiring done I fed the wire to gauges up through the center stack past the stereo and zip tied them inplace for a quick scs/jr bacon break.
- With the modified cluster in hand I proceeded to connect the 3 wires from the cluster to the closest 3 (of 4) connectors from the black box.
- Then I reinstalled the gauge cluster (get it in half way and then connect the wiring harness to it then the rest of the way in) Screwed it back into place...
- I Fished back out the dimmer wire and connected it and replaced the shroud... From there I'm pretty sure you can complete the mod.
Read on though.
Some complaints...
In closing,
They look Sweet
Chris
