Nitrous Part Numbers (NOS brand)
This topic is closed.
  • Nitrous Part Numbers (NOS brand)
    This is something I posted on Probetalk.temp, and now I just stumbled across my file somewhere on my HD....so here it is again. Just for the hell of it
    NITROUS JETS:
    PART NUMBER SIZE
    13750-14NOS .014"
    13750-15NOS .015"
    13750-16NOS .016"
    13750-18NOS .018"
    13750-19NOS .019"
    13750-20NOS .020"
    13750-21NOS .021"
    13750-22NOS .022"
    13750-23NOS .023"
    13750-24NOS .024"
    13750-25NOS .025"
    13750-26NOS .026"
    13750-28NOS .028"
    13750-29NOS .029"
    13750-30NOS .030"
    13750-31NOS .031"
    13750-32NOS .032"
    13750-33NOS .033"
    13750-34NOS .034"
    13750-35NOS .035"
    13750-36NOS .036"
    13750-37NOS .037"
    13750-38NOS .038"
    13750-39NOS .039"
    13750-40NOS .040"
    13750-41NOS .041"
    13750-42NOS .042"
    13750-43NOS .043"
    13750-44NOS .044"
    13750-45NOS .045"
    13750-46NOS .046"
    13750-47NOS .047"
    13750-49NOS .049"
    13750-51NOS .051"
    13750-52NOS .052"
    13750-53NOS .053"
    13750-55NOS .055"
    13750-57NOS .057"
    13750-59NOS .059"
    13750-60NOS .060"
    13750-61NOS .061"
    13750-62NOS .062"
    13750-63NOS .063"
    13750-64NOS .064"
    13750-65NOS .065"
    13750-67NOS .067"
    13750-69NOS .069"
    13750-70NOS .070"
    13750-71NOS .071"
    13750-73NOS .073"
    13750-75NOS .075"
    13750-76NOS .076"
    13750-77NOS .077"
    13750-78NOS .078"
    13750-79NOS .079"
    13750-80NOS .080"
    13750-81NOS .081"
    13750-82NOS .082"
    13750-83NOS .083"
    13750-85NOS .085"
    13750-86NOS .086"
    13750-87NOS .087"
    13750-89NOS .089"
    13750-90NOS .090"
    13750-91NOS .091"
    13750-92NOS .092"
    13750-93NOS .093"
    13750-94NOS .094"
    13750-95NOS .095"
    13750-96NOS .096"
    13750-97NOS .097"
    13750-98NOS .098"
    13750-99NOS .099"
    13750-100NOS .100"
    13750-102NOS .102"
    13750-103NOS .103"
    13750-104NOS .104"
    13750-106NOS .106"
    13750-107NOS .107"
    13750-108NOS .108"
    13750-109NOS .109"
    13750-110NOS .110"
    13750-116NOS .116"
    13750-120NOS .120"
    13750-125NOS .125"
    Jet Kits
    PART NUMBER SIZE
    13750-MNOS Master Jet Pac (482 Jets)
    13750-SNOS Flare Jets-blank
    13750-STNOS Standard Jet Pac (178 Jets)
    Ford 5.0 EFI Stage I to Stage II Conversion
    PART NUMBER DESCRIPTION
    0015NOS Converts #05115NOS Stage I kit (75 hp) to #05115-2NOS Stage 11 kit (150 hp)
    Ford 5.0 EFI Dual Stage Conversion
    0016NOS Single to 2 stage conversion kit, for kit #05115-2
    SOLENOIDS
    Flow Rate: Up to 175 HP
    Amp Draw: 8.6 amps
    Inlet/Outlet: 1/8" NPT / 1/8" NPT
    16020NOS Nitrous Solenoid
    16020-CNOS Chrome Housing Nitrous Solenoid
    16021NOS Rebuild Kit
    16022NOS Replacement Coil
    Flow Rate: Up to 200 HP at 6.0 psi
    Amp Draw: .6 amps
    16080NOS Fuel Solenoid
    16080-CNOS Chrome Housing Fuel Solenoid
    16081NOS Rebuild Kit
    16082NOS Replacement Coil
    NITROUS BOTTLES
    Standard:
    *14760NOS – 20lb
    *14750NOS – 15lb
    *14745NOS – 10lb
    *14730NOS – 5lb
    Polished:
    *14760-PNOS – 20lb
    *14750-PNOS – 15lb
    *14745-PNOS – 10lb
    *14730-PNOS – 5lb
    Carbon Fiber:
    14707NOS Carbon fiber wrapped bottle, 1.6 lb. capacity, 11-3/8" x 3-7/8" diameter.
    14708NOS CO2 bottle, carbon fiber wrapped, 1.6 lb. capacity, 11-3/8" x 3-7/8" diameter.
    14747NOS Carbon fiber wrapped bottle, 12.5 lb. capacity, 24-3/4" x 6-5/8" diamete.
    14130NOS Billet Aluminum Bracket set for 10 lb. and 15 lb. (7" diameter) bottles.
    14132NOS* Billet Aluminum Bracket set for DUAL 10 and 15 lb. (7" diameter) bottles
    14155NOS Billet Aluminum Bracket set for 20 lb. (8" diameter) bottles
    16030NOS Purge valve for -4AN line
    16032NOS Purge valve for -6AN line
    16160NOS Bottle heater for 2 lb. & 2.5 lb. bottles, 12 volt DC
    14164NOS Bottle heater for 10 lb. & 15 lb. bottles, 12 volt DC
    16164-110NOS Bottle heater for 10 lb. & 15 lb. bottles, 110 volt AC
    REMOTE BOTTLE OPENER - 16058NOS
    15910NOS 1-1/2" diameter Nitrous Pressure Gauge with 4AN adapter
    15912NOS 1-1/2" diameter Nitrous Pressure Gauge with -6AN adapter
    15914NOS 1-1/2" diameter Glycerin filled Nitrous Pressure Gauge with -4AN adapter
    15916NOS 1-1/2" diameter Glycerin filled Nitrous Pressure Gauge with -6AN adapter
    15911NOS 2-5/8" Diameter Nitrous Pressure Gauge with blue face (0-1500 PSI)
    15911BNOS 2-5/8" Diameter Nitrous Pressure Gauge with black face (0-1500 PSI)
    15911SNOS 2-5/8" Diameter Nitrous Pressure Gauge with silver face (0-1500 PSI)
    15906NOS 1-1/2" diameter 0 to 120 psi Fuel Pressure Gauge for EFI Applications
    15907NOS 1-1/2" diameter Glycerin Filled 0 to 120 psi Fuel Pressure Gauge
    15908NOS 2-5/8" diameter Fuel Pressure Gauge (0-100 PSI) with red face
    15908BNOS 2-5/8" diameter Fuel Pressure Gauge (0-100 PSI) with black face
    15908SNOS 2-5/8" diameter Fuel Pressure Gauge (0-100 PSI) with silver face
    Distribution blocks for direct port:
    PART NUMBER APPLICATION
    16700NOS 1 in 3 out -1/8" NPT hex block
    16700-C-SNOS Same as above, chrome
    16705NOS 1 in 3 out -1/16" NPT hex block
    16705-C-SNOS Same as above, chrome
    16710NOS 1 in 4 out -1/8" NPT std. block
    16710-C-SNOS Same as above, chrome
    16712NOS* 1 in 4 out Pro Race block
    16715NOS 1 in 4 out -1/16" NPT
    16715-C-SNOS Same as above, chrome
    16720NOS 1 in 6 out -1/8" NPT std. block
    16720-C-SNOS Same as above, chrome
    16725NOS 1 in 6 out -1/16" NPT std. block
    16725-C-SNOS Same as above, chrome
    16730NOS 1 in 8 out -1/8" NPT std. block
    16730-C-SNOS Same as above, chrome
    16735NOS 1 in 8 out -1/16" NPT std. block
    16735-C-SNOS Same as above, chrome
    16740NOS 2 in 8 out -1/8" NPT Siamese block
    16740-C-SNOS Same as above, chrome
    16745NOS 2 in 8 out -1/16" NPT Siamese block
    16745-C-SNOS Same as above, chrome
    16750NOS 2 in 16 out -1/8" NPT Siamese block
    16750-C-SNOS Same as above, chrome
    16755NOS 2 in 16 out -1/16" NPT Siamese block
    16755-C-SNOS Same as above, chrome
    16760NOS 2 in 16 out -1/8" NPT
    16760-C-SNOS Same as above, chrome
    16767NOS 1 in 4 out -1/16" NPT Showerhead
    16768NOS 1 in 3 out -1/8" NPT Showerhead
    Programmable Progressive
    Nitrous Controller
    Part #: 15834NOS
    High Pressure Nitrous Filters
    15550NOS -4AN x -4AN, in-line billet aluminum
    15552NOS -6AN x -6AN, in-line billet aluminum
    15560NOS N20 Filter, 1/4" NPT x -4AN (Cheater or Pro Fogger)
    15562NOS N20 Filter, 1/4" NPT x -4AN, 90°
    15564NOS N20 Filter, 1/4" NPT x -6AN (Big Shot)
    15566NOS N20 Filter, 1/4" NPT x -6AN, 90°
    15568NOS N20 Filter, 1/8" NPT x -6AN
    15570NOS N20 Filter, 1/8" NPT x -4AN (Power Shot)
    15572NOS N20 Filter, 1/8" NPT x -4AN, 90°
    15574NOS N20 Filter, 1/8" NPT male x 1/8" NPT male
      Good stuff!
      WAGS
        that is a great listing of all the part numbers. Should prove very useful. Thanks.
          here is a complete list off a taurus sho fanpage.......
          ITEM DESCRIPTION QUANTITY
          NOS P/N
          (1)
          Bottle 10lb. (filled)
          1
          14745****
          (2)
          Bottle Valve Adaptor (4AN)
          1
          16220
          (3)
          Bottle Valve Washer
          1
          16210
          (4)
          Bottle Bracket Set
          1
          14135
          (5)
          Fan Spray Nozzle (Blue)
          1
          13500
          (6)
          Nitrous Solenoid
          2
          16020
          (7)
          Nitrous Solenoid TEE
          1
          17242
          (8)
          Solenoid Mounting Bracket
          1
          16509
          (9)
          4AN Nitrous Filter Fitting
          1
          15570
          (10)
          1/8-inch NPT Male X 1/8-inch NPT Male Nipple
          1
          17500
          (11)
          Nitrous Pressure Regulator
          1
          15850
          (12)
          1/8-inch NPT X 3/16-inch Hose Barb
          1
          16244-A-S
          (13)
          3AN Hose with 1/8-inch NPT Male Fitting
          1
          15060-1
          (14)
          Vacuum Hose Pressure TEE
          1
          17538
          (15)
          Vacuum Hose
          1
          15005
          (16)
          Ratcheting Hose Clamps
          5
          16239
          (17)
          Main N20 Feed Line 4AN 14-ft
          1
          15295
          (18)
          4AN X 4AN 90 degree fitting (optional)
          1
          17535
          (19)
          Flare Jet
          1
          Varies w/ Kit
          (20)
          Microswitch*
          1
          15640
          (21)
          Arming(Toggle) Switch
          1
          15600
          (22)
          Fuel Pressure Safety Switch**
          1
          15685
          (23)
          Wiring Relay-30AMP
          1
          15618-S
          (24)
          Harness for Wiring Relay***
          1
          15604-S
          (25)
          1/8-inch NPT FE X 1/16-inch NPT ML
          1
          16785
          (26)
          1/16-inch NPT Tap
          1
          15990
          (27)
          Nozzle Mounting Collar
          1
          13710-S
          (28)
          Nozzle Mounting Nut
          1
          13711-S
          ...Matthew Lemens ©..........www.lemens-ts.com................
          1993 Probe GT - 19's/BagStrutted/Kitted/Shaved/Molded
            Useful - consider it stuck!
            1997 Ford Probe GTS Turbo | 2000 Jaguar XJ8 | 1988 Jeep Grand Wagoneer | 1930 Model A Hotrod | 2005 VW Touareg V8
              Hey kool thanks for the info. What about Sparkplugs? One step kooler? Laters Mikal
              MY CAR HAS BEEN SOLD. Thanks to all who have inspired me and more important to those that I might have inspired. For the friends and friendships that Ive made here in the PT community. Thank you all. www.jadecrew.com
                40-60shot NGK ZFR6F11
                60+shot NGK ZFR7F11
                  Nitrous Jet calculator (NOS brand)
                  http://www.robietherobot.com/NitrousJetCalculator.htm
                  Enjoy
                  Rick_96PGT #62
                  "I never apologize.
                  - Homer J. Simpson
                    I like the pull down menu for the number of jets/ports.
                      Merging threads.... =)
                      Gil - '06 Z51 A6 C6
                      K&N CAI w/Open Shroud & Halltech Beehive
                      Port matched intake manifold/exhaust
                      Dual X-pipe conversion to Z06 HiFlow
                      Diablo Sport ECU/TCM Tuned
                        isnt the the 7f a longer plug? therefore if ur heads were shaved this could cause clearance issues , right?
                        Black 95 PGT
                        Silver 98 CSVT
                          the heat range does not change the reach.
                          Originally posted by ngk faq
                          The heat range measurement is determined by several factors; the length of the ceramic center insulator nose and its' ability to absorb and transfer combustion heat, the material composition of the insulator and center electrode material.
                          2015 Audi Q3 - Stock |
