I need to know if someone has a VAF from a PGT/MX-6 so I can take a look at the innards..
A broken one is fine, and preffed...
I just came across this in my fluids book, and they have the spring rates for various flows... According to that, you *should* be able to properly calculate the spring rate that would allow the VAF to work with boost THEN you would increase your fuel pressure to make up the difference..
This idea is used on 944s ALL THE TIME, which is one of the reasons ppl easily get 400hp daily drivers out of that car. Just slap on the bigger injectors, more boost, then go to the Porsche dealership and have them reset the preload on your MAF with a little round knob that has a wound spring attached to a flap door..
Very simple idea, and it works well...
