Does MBX still sell the oil filter block off plate?
Yes, he does, contact him directly through the website email. Shogunned at aol I believe.¶¶¶ Spyder Mica Metallic1994 PGT ZE-T04E Intercooled @ 6 psi.. ----- Sold within NEPO and PT
¶¶¶ Arancio Atlas Metallic1995 PGT NOVI 1000 Intercooled @ 10psi. ----- STUPID FAST
¶¶¶ Verde Mica Metallic 1993 PGT Modified, Sanctified, Retired. ----- Damn I miss her.
Originally posted by TravisWilliams_GTYes, he does, contact him directly through the website email. Shogunned at aol I believe.
Also, we have complete oil filter relocation kits in stock, here are the details:
93-97 Ford Probe/Mazda 2nd Gen
MBX Ultimate Oil Filter Relocation Kit
Description: MBX Ultimate Oil Filter Relocation Kit was designed to replace your stock oil filter housing for those who are running custom supercharged and turboed applications where the stock oil filter housing is in the way. We have custom machined a billet block off plate to mount in place of your old oil filter housing to allow you to relocate a new oil filter housing unit. Kit allows for greater oil capacity, cooler oil temps and added filtration protection. Please contact us if you need oil feed lines for your turbo or supercharger and we can supply the fittings and custom oil feed lines for you. This is not a spin on kit!
Kit Includes:
6.5 Feet of -8an Aeroquip Stainless Braided Line
3 Straight Aeroquip Male fittings
1 Straight Aeroquip Male fittings with 1/8 NPT Port
4 Aeroquip Re-useable Swivel Hose End Fittings
1 MBX Oil Filter Block off Plate
1 Factory OEM Oil Filter Housing Gasket
1 Perma Cool Oil Filter Housing Unit
1 Fram PH8A or Equivalent Oil Filter
3 Mounting Screws
Price is $149 Shipped in the US
Mike, I need to pick up three of the block off plates¶¶¶ Spyder Mica Metallic1994 PGT ZE-T04E Intercooled @ 6 psi.. ----- Sold within NEPO and PT
I can't seem find it on your website.....
Is CrimsonRed not done with the new one yet?.........¶¶¶ Spyder Mica Metallic1994 PGT ZE-T04E Intercooled @ 6 psi.. ----- Sold within NEPO and PT
how would I, as a customer, go about purchasing a plate?¶¶¶ Spyder Mica Metallic1994 PGT ZE-T04E Intercooled @ 6 psi.. ----- Sold within NEPO and PT
Originally posted by TravisWilliams_GThow would I, as a customer, go about purchasing a plate?
Our customers can goto https://www.paypal.com/affil/pal=JSBPQH7XC4ASY and make direct payments to us in the total amount of either $42.50 per MBX Billet Aluminum block off plate with factory OEM gasket or $149 for the Complete MBX Oil Filter Relocation Kit
Please be sure to list what you are purchasing in the Subject line
Originally posted by turboshoCan you send me pics of the oil rellocation kit?
What's the thread on the PH8?....3/4'' or 13/16'' ?
Thanks.
hey what do i do about an oil pressure gauge and my oil feed line for my tubo since that is where they both run from?-J-Rod-
93 PGT-T
Originally posted by Jarod7920hey what do i do about an oil pressure gauge and my oil feed line for my tubo since that is where they both run from?
Jarod,
You can mount the new oil filter housing unit underneath the frame rail under the battery on the driver side and run the lines towards the front radiator support underneath and around to the block off plate on the engine. This will look wicked As for the oil feed line, we can provide you with -8an straight fittings with 1/8" npt port in the center of which in turn would serve as a t-fitting from the block off plate. You can also add one to the oil filter housing unit of which you can add your oil sending unit for the gauge. We also have 1/8" npt to -4an adapters for your oil feed lines available too. We have everything in stock!
