We will have this up very soon, we just got back and will work on getting the site updated and pics etc.... Orders can commence immediately after everything is posted!
"NEW" MBX Ultimate Dual Feed Fuel Pressure Regulator Kit
Our dual feed set-up is designed for the V6 fuel rails, being that there are two rails on the V6 and two feed ports on our Aeromotive Units enables this to happen.
Our single feed set-up on our site is the Ultimate for the single rail 4 cylinder applications available now!
Our dual feed set-up will feed both fuel rails from seperate ports on the Aeromotive FPR enabling balanced pressure at both rails at all times. I will have pictures, prices and availability listed very soon. We will have many kits in stock!
Originally posted by SirMichaelIm not sure if this is where this belongs but would it benifit even more with a larger ss fuel line since the fuel is going to be split between the two lines now or does it matter?
-Mike
The -6an SS Braided lines are more than adequate, our rails would be the limiting factor before the lines would.
Mike
how long till these are available then ?| Eaton Supercharger | HID Conversion | 330cc Top Feed Injectors | Megasquirt | KL-ZE | Aeromotive Dual FEED FPR | Hotshot Intake | Hotshot Gen V Headers | Eibach Springs | KYB GR2 Struts | Home Depot RSTB | 7/8" PST RSB | DIY STS | HKS Catback | Testpipe | P/P'd ZE manifold | Colt Cams SuperStreet Grind | 65MM Throttle Body | TB/IM Phenos | CM3 w/ Fidanza Flywheel | UDP | FD Wheels | MSD 6AL w/ Blaster 3 Coil | A/C Removed |
Originally posted by Mike BaxterPics, pricing and availability will be listed on Monday the 27th guaranteed! or earlierLast edited by SirMichael; September 15, 2004, 03:18 PM.
