Millennia-S Forged 4340 connecting rods for 2nd Gen. Probe GT's & Mazda MX-6's
if you still have any left in 2 weeks then i will take a set
Current: Green Envy Fiesta ST e85 Tuned
Project: Olive Green SAAB 9-3 HOT 19T Biopower
Sold: BCM MS6, MSP,
Sold:3L Full Oval Port Swapped 99 Cougar
Hookers and Blow, LET'S GO.
so what happens if one of these fails or is flawed, i know very unlikly but...i take it there is no warrenty on these at all either. im planning on rebuilding the ze and boosting it hard, would like to get a little over 400 to the ground.
are these a direct drop in for the KL or do we need to modify the block to make them fit. I recall an issue with making them fit in the previous thread that discussed these rods.
This was covered a little in the long post that was going for the past several months before the BB if you happened to catch it. Due to these rods being a custom size they didn't offer any warranty. However I can say that when we were coming up with the blue print we exactly copied the main beam dimensions (cross section) of a H-Beam Ford 302 connecting rod that the company was mass producing. This was mainly done to insure they were strong as well as keeping the design simple for the shop to tool up. I also measured and hardness tested a few rods from the orignal batch they made last year and never found one out of print spec.
I tested them in two blocks, one was given to me so I'm not sure what year it is, and the other was from a 94. The 94 seems to have a little more clearance while one or two cylinder skirts on the other block could use a touch up with a half round file or die grinder to make extra clearance for the beefier rod bolts. I do question what this block came from though; although its a 2.5L Mazda block it has some spots that look a little different than the one that I know came from a 94 Probe.
Originally posted by mesoungodlyfast
I didnt see it on there... are they regular millenium pins or floating wrist pins?
These rods are bushed for floating Millennia wrist pins. The stock Millennia pins are actually floating, unlike the Probe/MX6 wrist pins. The bushings are also left a few thousands undersized so they can be hand fit and allow for wrist pin variances.
I missed out the first time these came around, I'm in for sure this time. pm me your paypal. I will be paying with paypal of course and it won't be a echeck.
03 frontier family car/dd
93 mx6 tessa's car: ze and just about every bolt on.
01 ws6 : 618/695 wrecked tell your kids to use a effing cross walk!!
02 35th SS.. heads and cam
You said you hardness tested these rods?? Im assuming it was either a brinel or Rockwell hardness tester? Do you recall the hardness??? Not that its a big deal because to most ppl on here the number wont mean squat, but i am intrested to see what they came out to!
Ryan
hopefully it's rockwell, cause I can test that at work. I'm hoping there atleast 30-35c. being that there 4340 they should be atleast that, cause 4140 you can get pre-hard and it's already 35c so.... I was thinking about it today and would it be to much for you to give me a copy of the specs so I can have to check them myself. I'm not doubting you at all, but being that this is the first step in a major build I want to make sure I have everything in writing. what there should weigh,distance between wrisp pin C-Line and crank journal C-Line. I plan on having all that info for the pistions I choose, the wrist pins,rings,valve train ect.
thanks
If i had to guess, i would say they are in the higher end of the 40c. If avalible id also like to have any specs you have on the rods as well, expecially the torque spec they gave out for the rod bolts. The last time i did a build with the czt kit, it was a nightmare trying to get a torque spec for them, with the new arp bolts.
Ryan
Just made it through the PM's I received today, now to the posts.
Unfortunately all of the information I had from testing was in the older thread, I'll bring one to work tomorrow and see what I get. As far as overall dimensions I was able to get the following information from corporate Mazda after much much much effort. I will also spot check some of the dimensions at work tomorrow.
Crankshaft Bearing Bore Diameter 2.2047-2.2053in
Wrist Pin End Diameter 0.8255-0.8258in
Length (Center to Center) 5.426-5.429 in
Out of Round Limit 0.002in
Taper Limit 0.002in
Width of Crankshaft End 0.8360-0.8340in
Hardness is in the 36C range, I am not sure of the tolerance off the top of my head.
Rod bolt torque was suggested at 55-60lbs since they are ARP bolts (non torque-to-yield like the stock bolts.) The torque sounds extremely high compared to the 17.5lbs+90°+7°+90°+7° of the stock rods, but keep in mind these are 8740 material and 7/16" diameter... very stout.
* Edit, please read above and below.
Some of the H-Beam rod dimensions are intentionally skewed one direction or the other to allow for hand fitting wrist pins, allowing for engine wear (assuming no one will be installing these on a brand new crankshaft) etcetera.
