So my passenger side door is split down the middle so it's it two parts now. I had the same problerm with the drivers side and I hot guled them both. The drivers side is still golden but the passenger side isn't. I tried to re-glue but I can see it will be the same.... so i need some good ideas and help... I don't want to drill or screw thur them... what have people done?
Interior Door panel repair
94 GT, atx SWAPED to MTX, Silver, Oil Cooler, Blue Calipers, Front and back strut bars, 22" Rear sway bar, Hotshot Headers, Greddy cat-back, Sloted and Drilled Roters, Hotshot Cold air intake, Pheno Intake and TB, and much more.
93 GT, MTX, Black, Red Calipers, Hot Shot Air intake, Sloted and Drilled Roters. Pheno Intake and TB, More to come on this one!!Tags: None
i have head of some peolpe rivit them together, but the best way to solve it is to get some 95+ door panels that are one piece
can't rivit them cuz I don't have one... and 95+ are different style then what i have now94 GT, atx SWAPED to MTX, Silver, Oil Cooler, Blue Calipers, Front and back strut bars, 22" Rear sway bar, Hotshot Headers, Greddy cat-back, Sloted and Drilled Roters, Hotshot Cold air intake, Pheno Intake and TB, and much more.
Originally posted by probety View Postcan't rivit them cuz I don't have one... and 95+ are different style then what i have now93 PGT ATX, Short Ram Intake, HEI mod w/Crane LX91 coil, MSD plug wires, relocated Optima battery, B&M tranny cooler, shimmed oil pump, 98+ 626 brake upgrade, 16mm 626 rear swaybar
use gorilla glue....just dont put it too close to the edge...because it expands and foams...Make sure you clamp it too. It will hold...but still be careful with it. You could rip it apart if ya wanted to. If you glue it and fasten it with all the screws theres no chance it will seperate93 Probe GT
Its not a PROBLEM. It's a PROBE LUM
http://i227.photobucket.com/albums/d..._5571185_n.jpg
Well, IMO just get the 1 peice style. If you really like the 2 peice style, then I say gorilla glue or JB weld them together. If you do glue them clamp them and make sure to not put it really close to the edge or it will run out like Phat said.
No no no. Don't use Gorilla or JB! Thats a
Use LocTite plastic epoxy! It works far better.
Once, I accidentally kicked the map pocket right off of my driver door. To fix it, I mixed up the epoxy on a piece of cardboard using a Q-tip. I applied the epoxy sparingly to the map pocket and panel surface. I placed the pocket onto the panel, turned it upside down, put a few very small wood screws through the back where the plastic weld spots are, and then flipped it back over and placed weights on it to hold it still and tight.
Overnight, I left it to dry. The next morning, it was SOLID. You cant really tell it was ever broken. Its probably stronger now than it ever was.
The trick is to press down or clamp down in it with precision while the epoxy is drying. This will allow it to get a good molecular bond and adhere much better.DRIVE IT LIKE YOU BUILT IT!!
94 Probe GT..no engine!
96 Probe GT now with full-forged KLZE ..8psi untuned and buck wildCarDomain page
Haha, I did the same thing, kicked my map pocket right off. I JB welded it back together, mixed it up spread it on both sides and clamped it. Let it sit overnight and it is strong as hell. So both work, but maybe the epoxy works better.Last edited by Ransom; August 21, 2010, 02:03 PM.
Thanks for all the ideas...very good stuff. As far as putting new style doors on... aren't the door handles different? same with the elect?94 GT, atx SWAPED to MTX, Silver, Oil Cooler, Blue Calipers, Front and back strut bars, 22" Rear sway bar, Hotshot Headers, Greddy cat-back, Sloted and Drilled Roters, Hotshot Cold air intake, Pheno Intake and TB, and much more.
Originally posted by probety View PostThanks for all the ideas...very good stuff. As far as putting new style doors on... aren't the door handles different? same with the elect?
I'd have to try the local pick n pull but the rape people on the stuff!94 GT, atx SWAPED to MTX, Silver, Oil Cooler, Blue Calipers, Front and back strut bars, 22" Rear sway bar, Hotshot Headers, Greddy cat-back, Sloted and Drilled Roters, Hotshot Cold air intake, Pheno Intake and TB, and much more.
They swap right over, you need the new style door handles. Also, I have never done this because well all my probes have been the 95+ models, but I have heard 2 of the holes don't line up. This isn't really a problem because you can put drill some new holes if need be. All you would have to do is put the door panel on and the two holes that don't line up you can drill right then with the panel on and throw the screws in and there you go.
---------- Post added at 03:22 PM ---------- Previous post was at 03:21 PM ----------
Originally posted by probety View PostI'd have to try the local pick n pull but the rape people on the stuff!
theres a bracket you have to remove from the 95+ door and installd it on your door. It goes in the center and is the same spot as that little pocket is that you grab to open and close your door with your 93-94 panels. You can do the epoxy method...probably going to need a fair amount of it and that stuff aint cheap. If you do clamp it...make sure its rubber or you got something over it so it dont damage the panel93 Probe GT
picture is dark but i used plastic push tabs.
94 PGT[96 PGT FuLL OBD2 WiRe HaRNeSS] ]KL31 SHoRT BLoCK & CaMS] [KL1C MaF SWap] [CuRVe NeCK MaNiFoLD] [KL68 TB] [Hei & MSD BLaSTeR 2] [Cai] [SS HeaDeRS] [STS] [R&R PoLY F&R MouNT & SHiFTeR iNSeRTS] [STaGe 2 CLuTCH] [FiDaNZa FLYWHeeL] [eGR DeLeTe] [FuLL a/C DeLeTe] [CoiLoVeRS] [RX8 WHeeLS oN 225/45/18]
