  ProbeTalk.com Forums > General > Knowledge Base > How-To
How-To Post, read, and discuss 'How-to' guides for all years of Probes.
October 1st, 2015, 08:34 AM   #1
HappyProbe
: Apr 2015
: 24
how can I check if fuel is good/bad
my 89 has been sitting a few years and I've just replaced the alternator but worried to just start it up without knowing the quality of the gas. what's the best way to check if the gas is healthy still or not? or should I just turn the key and see if she runs? thanks
October 1st, 2015, 10:29 AM   #2
LowClassCC
Low Class C.C.
: Apr 2007
: Mauckport, Indiana
: 44
: 2,082
Bad fuel can cause her not to run. It won't hurt to try to start her up in my opinion. How much fuel is in the tank? At parts stores they do sell stabilizer for fuel. You could always add that and then add fresh gas.
Bad gas can also clog the fuel filter. If you can not get her running try changing the fuel filter. If she starts I would look into changing the fuel filter after you run a couple tanks through her too.
October 1st, 2015, 02:05 PM   #3
HappyProbe
: Apr 2015
: 24
thanks, I started her up. there was a ticking sound that goes away at higher rpms and the rear turn signals dead.
October 1st, 2015, 02:13 PM   #4
LowClassCC
Low Class C.C.
: Apr 2007
: 44
: 2,082
Now you just need a fresh oil change, check to make sure the antifreeze is good and don't need changed. If the front turn signals are working you most likely will only need to change the bulbs in the rear.
October 1st, 2015, 05:02 PM   #5
HappyProbe
: Apr 2015
: 24
thanks for the tips! I had to change the whole light harness, the old one was rusted and damaged from a leak I used to have. fortunately I kept a spare laying around. it's all good now, just need to change the fluids.
thread
Compression check. good or bad Coleman1993se 2nd Gen (93-97) I4 2.0L Performance 10 April 20th, 2006 05:17 PM
Have 3-gal fuel cell - need a good fuel pump Dan [Sac] Forced Induction (Turbo/S.C.) 7 December 27th, 2004 05:11 PM
Good bye disks! Check this out Tombfyre Canuck Forum 3 March 1st, 2002 02:29 AM
