  ProbeTalk.com Forums > General > News and Support
News and Support Site related News and Support can be found here.
December 29th, 2011, 11:13 AM   #251
TravisWilliams_GT
yes.....wait, what?
: Feb 2000
: Lynchburg, VA
: 43
: 12,536
I actually retrofitted my existing rear calipers, I drilled and tapped the end of the slide pin housing and installed a zerk/Alemite fitting. I didn't even have to remove the caliper from the car.
----- Sold within NEPO and PT
----- STUPID FAST
----- Damn I miss her.
December 31st, 2011, 11:21 PM   #252
daweb
: Jun 2011
: kansasville,wi
: 54
: 4,887
ive done that on a few of my cars it helps alot havnt done it on my pgt's yet just anti seized those so far ill probably do that when i do the brakes or do an upgrade
95 PGT white dd klze / mtx fidanza,maf swapped obx headers 2 1/2" mandrel bent 14.3 sec 1/4mile time
94 PGT blue toy de/ze/g4 hybrid/ mtx turbo 5- 10 psi maf swapped aem piggy back, fidanza mandrel bent exaust
93 PGT red klde/mtx klg4 intake,wild orchid interior
97&94&93 PGT gone
DALE
March 28th, 2012, 10:00 AM   #253
cmicgross
: Dec 2007
: Richmond,VA
: 25
CrossPollination?...hows about Hybrid?
Youse guys are F'in unbelievable!...and I thought I was wise buying MX6 parts....duh...Also thought it was something dropping OE Spectum struts in my Gen1 GT...rides tight anyway, though I sure do miss my PRC, even though I almost always kept it on Sport ;-)~Keep rockin' da Probe!
M
1stGen Red '89PGT mostly stock 2nd engine 178890 mi
August 5th, 2012, 08:52 PM   #254
LoNaTiC
: Jan 2006
: Lorton, Va
: 31
: 1,961
Compilation Part1
I've attempted to compile this as best as i can from the postings in this thread....
"Donated for 1G MX-6 applications (implied 1G Probe 626 where applicable)"
What: Compressor housing/Wheel
Donor Car: 87-88*Ford Thunderbird*Turbocoupe (Note, only applies to the IHI turbocharger equipped model)
Modification required: Adapter plate for compressor housing, plus a silicon reducer to mate it to the IC piping.
Why: Larger than the stock compressor housing/wheel, produces more power than stocker at same boost level.
What: Upper*Intercooler*pipe (charge pipe)
Donor Car: XX-XX Isuzu Impulse turbo
Modification required: Small section of metal tubing and rubber hose must be used to make the pipe reach the*throttle body
Why: Allows use of 5 dollar garbage disposal rubber boot rather than 90 dollar OEM TB boot.
What: 440cc Injectors
Donor Car: 87-92 Supra Turbo
Modification required: 88-89 will require 90+ injector clips. Controlling them effectively will require work
Why: More fuel for those who need it
What: 330cc Injectors
Donor Car: 90-92 MX6/Probe GT
Modification required: The injector clips will have to be changed over along with the injectors themselves.
Why: More fuel, won't need any type of management to make these run well.
What: Fuel filter
Donor Car: XX-XX*Isuzu Rodeo*(Part number- FRAM G7393)
Modification required: *None. Filter will "float" in the engine bay, leaving the coil bracket empty.
Why: Flows better than OE unit
What: Front struts/springs
Donor Car: 93-94 MX6*LS/Probe GT
Modification required: None. However, rears will not fit.
Why: Lowers car, allows more options as far as aftermarket products.
What: Rear strut tower*bar
Donor Car: 90+ MX6 GT
Modification required: *None. 88-89 GTs are missing this item, which can be found on the 90+ model.
Why: Improved handling.
What: Stainless steel clutch line
Donor Car: 93-97 MX6*LS/Probe GT
Why: Inexpensive mod, improves clutch feel, as line will no longer expand with pressure
What: Cupholders
Donor Car: 92-95*Ford Taurus
Modification required: *Requires open "bay" under*CD player
Why: The MX6/626 lacks cupholders, which some people find valuable. Not an upgrade per se, but a nice creature comfort.
What: Rear sway bar
Donor Car: 89-92 Probe GT
Why: The 1G MX6 comes with a 16mm sway bar. The 18mm sway bar is stiffer, and said to improve handling
What: Inside Door Handles
Donor Car: 89(maybe earlier)-95 Mazda MPV
Why: The if you don't want*chrome door handles, the MPV handles come from the same mold, but are all one interior color.
What: Different dash switch
Donor Car: 88-91 Mazda 929
Why: If you want a different switch and you want it to look stock...
(I don't have a picture of this switch but I think its for heated mirrors or something luxury like that)
What: VAF, VAF adaptor Plate
Donor Car: Multiple Toyota models from 88-92
Modification required: I don't know if they use the same VAF or they just LOOK the same. I know the adapter plates are the same. 2 cars I've visually seen the same looking VAF are 88-92 Corolla, 88-89 (may go up to 93) Cellica Discussion
Why:
G35 Coupe
95PGT kinda stock
12 R6
14' Optima slow
August 5th, 2012, 08:54 PM   #255
LoNaTiC
: Jan 2006
: Lorton, Va
: 31
: 1,961
Compilation Part2
What: Shift Knob
Donor Car: Any*Mitsubishi*(I'm sure there are others)
Why: *I found a nice leather shift knob in the junkyard and for $15*on ebay.
What: Make the back of your car, on the trunk say "MX-6 GT"
Donor Car: Mitsubishi 3000GT*(I'm pretty sure any year will do)
Why: on the back of the 3000GT, just carefully peel of the GT and put them on your car.
What: Passenger Under-seat tray Slider drawer from 89-92 PGT replaces factor sub box.
Donor Car:
Modification required: mounts in same location(for those who dont use that subbox due to aftermarket stereo) No drilling required, However it will not fit DX seats. You'll need both brackets and the drawer, thats it!
Why:
What: Aluminum rx-7 Scissor jack.
Donor Car:
Why: For those who want to lose a few pounds but still have a jack, one weighs about 3-4lbs compared to the nearly 10 our stock one weighs, fits in the same spot, no modification required
What: Aluminum 16X5 5-lug Rx-7 Space saver
Donor Car: All rx-7 convert's,*87-91 rx-7*Turbo, and 89-90 rx7 GTUs<(not just GTU, has to be a GTU-s)
Why: Weighs alot less then our stupid tiny steel ones, looks alot better... Fits perfectly in the trunk
What: 89-91 Rx-7*Fuel pressure regulator
Donor Car:
Modification required: use longer length of*fuel line*because outlet is shorter. Fits int he same flange, i noticed 2psi more basepressure
Why:
What: *2g pgt/mx6 LS KL*Spark plug wire*holders, the ones that mount on theintake manifold
Donor Car:
Modification required: cut a little notch to fit the little nub on our valve covers.Holds the plugwires Up higher because bracket is horizontal, not almost vertical.
Why:
What: 3-4 Psi Pressure switch-gotta thank rebel2k4 for this one Switch turns on at 3-4psi, However with a boost controller inline with this switch, you can use it to turn on some extra injectors or N20 at any pressure above 4psi.
Donor Car: Old Volvo Turbo's, the Non intercooled ones. Switch is blue and yellow and located on the firewall in the middle near the valve cover.
Modification required: Self explanatory
Why:
What: 88-91 929*Master Cylinder*w/resivour.
Donor Car:
Modification required: NONE, just make sure the lines are the right side, they'll differ depending on ABS or not(same as your car) you can just use the resivour if you trust yourself enough to get it out in 1 piece. I sat at the hub autozone store for an hour and tried 11 different*master cylinders, they all sorta fit, only the 929 fit perfectly(i had a*brake booster*sitting there to compare)
Why: its basically the same, except the resivour is alot larger and better shaped.
What: MX-3 Front Strut Mounts
Donor Car: MX-3
Why:
What: Mustang Fuel Pump
Donor Car: Mustang
Why:
What: 2nd Gen Clutch line
Donor Car: 2nd Gen PGT or MX6
Why: Interchangeable
What: 2nd Gen Frunt Upper Strut Mount
Why: lower drop
What: 2nd gen Probe A-pillar gauge pod
Why:
What: 1st Gen MX6 seats and 1st Gen Probe seats are interchangable
Donor Car:
Why:
What: RX7*steering wheel*fits 1st gen Probe
Donor Car:
Why:
What: *Mustang leather shift boot fits 1st gen Probe
Donor Car:
Why:
What: 1st gen MX6 factory RSTB fits 1st gen Probe
Donor Car:
Why:
What: 1st get MX6 factory lower tie bar fits 1st gen Probe
Donor Car:
Why:
What: The front tie bar for an Isuzu Impulse Turbo will fit the lower*rear tie bar*brackets of a 1st gen MX6 or Probe.
Donor Car:
Why:
What: ONLY 1996 Calipers will fit with*Subaru Legacy*2 pot calipers fit on the 1g with no modification. Just need to use the stock 1g caliper bracket and place the Subby caliper on the slider pins.
Donor Car:
Why:
What: 95 Corolla's MAF
Donor Car:
Why: http://forums.probetalk.com/showpost...&postcount=194
What: Stock late model (4th gen I believe) ford taurus/sable 3.0 exhaust manifolds are a better design than the 1st gen Probe 3.0 and fit directly. I believe they need a custom Y pipe though. Same goes for the Ford ranger/Mazda B3000 aftermarket headers.
Donor Car:
Why: http://forums.probetalk.com/showpost...&postcount=214
What: For the 1st gen 2.2 motors you can use the rockers from the 8 valve engine to replace the stock rockers. The 8V ones are solid instead of hydraulic and can be reved higher. The centers need to be honed out and re-centered to fit the F2 rocker shaft though.
Donor Car:
What: Fuel filters used on 2.4L Nissan's (ie: 93'-01' Altima's) are a direct fit for 1st gens. (ie: Fram G5237)
Donor Car:
Why: http://forums.probetalk.com/showpost...&postcount=245
G35 Coupe
95PGT kinda stock
12 R6
14' Optima slow
August 5th, 2012, 08:56 PM   #256
LoNaTiC
: Jan 2006
: Lorton, Va
: 31
: 1,961
Compilation Part3
"Donated for 2G PGT applications (implied 2G Probe 626 MX-6 where applicable)"
What: 2nd Gen clutch line is same as 1st gen, interchangable
Donor Car:
Why:
What: Clutch line is also interchangable with 1994*Ford Escort*lines (g-Series tranny only?)
Donor Car:
Why:
What: Brake line*from 1985 Buick Century fits 2nd gen Probe (MX6/626 implied; less expensive)
Donor Car:
Why:
What: 2000 626 Rear Sway Bar fits 2nd gen Probe Chassis with replacement bushings
Donor Car:
Why: http://forums.probetalk.com/showthre...hlight=swaybar
What: 1995*Nissan Altima*Endlinks fit 2nd gen chassis and are better made & less expensive
Donor Car:
Why:
What: GM fin type door clips fit 93-94*door panels
Donor Car:
Why:
What: Inner Door Panel Fasteners or clips for 1998-2001*Ford Explorer*fit Sideskirts on 2nd gen Probe
Donor Car:
Why:
What: Early 80s Buick/GM 1-wire*Oxygen sensor*replaces 3-4 wire sensors without throwing a CEL (less expensive)
Donor Car:
Why:
What: Mazdaspeed Protege LSD diff fits g-series 2nd gen transaxle
Donor Car:
Why:
What: Chrome centercaps for a*mazda RX8 fits*the chrome swirlies perfectly (Part number L082-37-192)
Donor Car:
Why:
What: Front rotors from*1993-2003 Protege*fits 2nd gen Probe (MX6/626 implied)
Donor Car:
Why:
What: 1999-2003 Protege*coilovers/struts fit 2nd gen Probe (MX6/626 implied) TEIN, B&G, K-Sport, JIC Magic
Donor Car:
Why:
What: Civic STS can be forced to fit 2nd gen Probe (MX6/626 implied)
Donor Car:
Why:
What: Prelude intake*can be cut in half and fits 2nd Gen PGT (MX6/626 possibly implied)
Donor Car:
Why:
What: Porsche 911*Carrera*brake calipers*fit 2nd gent Probe (MX6/626 Implied)
Donor Car:
Why:
What: Escort front upper*strut mount*fits 2nd gen Probe (MX6/626 implied; 5/8" lower drop) Front is the only end interchangable.*Rear are not.
Donor Car:
Why:
---------- Post added at 11:56 PM ---------- Previous post was at 11:55 PM ----------
What: 2nd gen front upper strut mounts fit 1st gen Probe (MX6/626 implied; lower drop)
Donor Car:
Why:
What: 2nd gen Probe*A-pillar gauge pod*fits 1st gen Probe
Donor Car:
Why:
Donor Car:
Why:
Donor Car:
Why:
What: Mustang leather shift boot fits 1st gen Probe
Donor Car:
Why:
Donor Car:
Why:
Donor Car:
Why:
What: G-Series Escort transmission internals fit 2nd gen G-series gearbox (stronger components upgrade)
Donor Car:
Why:
What: Millenia-S injectors & rails fit 2.5L V6 KLDE (60cc more than stock)
Donor Car:
Why:
What: Millenia curved neck ZE*intake manifold*fits 2.5L V6 KLDE (more airflow)
Donor Car:
Why:
What: 1998 Millenia PCM will run a 1996+ 2.5L V6 KLDE w/ATX (MAF conversion)
Donor Car:
Why:
What: 1.8K8, 2.0FS, 2.5KL and 2.5ZE, ATX & MTX can all be swapped around between 2nd gen vehicles with matching mounting hardware, axles, etc.
Donor Car:
Why:
What: Alloy and*steel rims*from all models & years are interchangable (GT rims & tires significantly improve handling of base models over 14" steelies)
Donor Car:
Why:
What: A 1993 Corvette ZR1*oil filter*will increase your 2.5KL's oil pressure and oil holding capacity
Donor Car:
Why:
What: Swap out front calipers for the 91 3000gt vr4 4piston calipers and 11.9" rotors cost a total of like $300:*http://mnpoc.org/forum/showpost.php?p=89178
Donor Car:
Why:
What: Clutches are the same between the 1st gen 2.2 non turbo, and the 2nd gen 2.5 v6.
Donor Car:
Why:
What: The 1st gen 2.2 turbo clutch is the same as the*89-92 rx7*turbo clutch, however the*pressure plate*is different.
Donor Car:
Why:
What: Acura tsx*(mtx, same as newer TL's) rubber boots/sleves that go on the clutch and break pedals & they do fit on the pgt mtx pedals...
Donor Car:
Why:
What: Cobra 13 inch vented rotors will fit 2nd Gen PGTs with minor modification.Porsche Brembo Monoblock Radial Mount caliper can be very easily adapted to match on the PGT. With this setup though you need some very big rims. 19 inch rims will fit with stock struts and springs and same diameter tires.
Donor Car:
Modification required: Centric hole needs to be opened just a small amount. Bolt pattern is the same.
Why:
What: The Mazda MPV 2 pot calipers may fit with no or little modification. I was reading the thread at work so I do not remember it so clearly. But another brake option for the Probe.
Donor Car:
Why:
G35 Coupe
95PGT kinda stock
12 R6
14' Optima slow
August 5th, 2012, 08:56 PM   #257
LoNaTiC
: Jan 2006
: Lorton, Va
: 31
: 1,961
Compilation Part5
*COMPILATION PART4*
What: *Non abs 93-02 and 98-02 626 abs rear hub assemblies fit the 2nd gen abs probes (cheaper). The old sensor ring knocks off and when heated up slip right back on without any pressing.
Donor Car:
Why:
What: Ford Escape axles are a good upgrade to ours and will fit just fine.
Donor Car:
Why:
What: 323 GTX gears apparantley fit in the 2g tranny case as well.
Donor Car:
Why:
What: Protege calipers upgrade for the rear of our PGTs to get rid of the freezing up that happens on the 93's & 94's. The third gen protege*rear calipers*are what you are looking for - 99-03 model years as well as the 02-03 p5.
Donor Car: 99-03 Protégé, 02-03 P5
Why: They give you about 1/3" more contact patch on the rotors, and are physically larger calipers also (for the "look" of it, if you're interested in that) Most importantly, the seals on the piston and ebrake arm are much better.
What: 626 brakes on 2nd Gen
Donor Car: 98-02 626
Modification required: the probe caliper fit fine, but needed to use the newer caliper bracket, and disc's.
Why: http://forums.probetalk.com/showpost...&postcount=181 http://forums.probetalk.com/showpost...&postcount=230
What: Russel Brake Stainless Steel Lines
Donor Car: 2003 Mazdaspeed Protégé
Why: http://forums.probetalk.com/showpost...&postcount=185
What: Mazda6 brakes
Donor Car: 03-07 Mazda 6, 06-07 MazdaSpeed 6, 06-08 Ford Fusion, 07-08 Lincoln MKZ, 06-06 Lincoln Zephyr, 06-08 Mercury Milan
Why: http://forums.probetalk.com/showthread.php?t=1701256566
What: Mazda 3.0L 929 side plug fuel injectors
Donor Car: 90-92 Mazda 3.0L
Why: http://forums.probetalk.com/showpost...&postcount=193
What: KLG4 30mm SLA's
Donor Car: 97 and up Mazda 626 2.0L 4CYL
Modification required: It has two cylinders less so you have to find two cars and get a full set of SLA's.
Why: http://forums.probetalk.com/showpost...&postcount=195
What: JE50 VAF
Donor Car: Mazda 929
Modification required: For those wanting to run KL - 31 ECU.
Why: http://forums.probetalk.com/showpost...&postcount=196
What: The throwout bearing that came with our*clutch kit*is the same exact bearing that's in the serpentine belt pullies.
Donor Car: The part number is 6203 RS made by CCVI, the NSK bearing part number (stock with the bearing) is 6203DUL1.
Why: http://forums.probetalk.com/showpost...&postcount=197
What: SVT Countour Rear Sway Bar
Donor Car: Ford Countour SVT
Why: SVT Sway bar: 18mm http://forums.probetalk.com/showthread.php?t=1701262358
What: SHO Power harness for the slave CD player can be used to add the needed power connection to 95+ PGT's that lacked the equalizer plugs on the harness.
Donor Car:
Why: http://forums.probetalk.com/showpost...&postcount=209
What: The 2nd gen Probes (SE and PGT) came with 28MM front bars and so did many 93-97 626's. The MX6 and the rest of the 626's came with a 26mm front bar.
Donor Car:
What: Protege lateral links are tubular and much more rigid than the MX6/probe stamped links.
Donor Car:
Why:
What: The upper strut mounts for the Escape/Tribute SUV's are a stronger and safer captured design than ours and is a stiffer mount (ie less rubber to flex) but has a round hole. So you'll need an impact to instal most likely.
Donor Car:
Why:
What: The intake manifold from a 98+ V6 626 bolts right on and is a better design than ours but you need a Mazda Millenia 2.5L throttle body to make it work.
Donor Car:
Why:
What: The MX3 K8 cams are slightly more agressive than the DE cams but not quite as agressive as ZE cams.
Donor Car:
Why:
What: The MX3 GS and all final generation 929's used the JE 50 VAF used with the KLZE. The MX3 GS ECU is also a decent stand in for a genuine ZE ECU.
Donor Car:
Why:
What: 98+ 626's sometimes came with chrome interior door handles that swap with 2G MX6 handles.
Donor Car:
Why:
What: If you have an OBDII car you can switch from the VAF to the MAF found on a 96+ Millenia takes a little work but you can do it, I liked it.*There might be a 95 with a MAF, I found one in the Junk Yard that had a Maf and a OBDI ECU, I still have it just never did anything with it.*
Donor Car:
Why: http://forums.probetalk.com/showpost...&postcount=230
What: Mazda 929*Master Cylinder*fits ABS Cars, there was a change so it would work on Non-ABS cars too it was a little nicer for bigger brake kits and is obviously cheaper. 92+ 929's I believe.*
Donor Car:
What: The Mazda Miata Oil Pressure Sender is the Same as the 93-94 Sender that is an actual sender for a real oil pressure reading.
Donor Car:
What: Toyota PCV Rubber Gasket is a great replacement for our VC Gasket that seems to break most of the time when you remove it.*
Donor Car:
What: The Ford ZX3 Antenna Mount works well and looks great
Donor Car:
What: For all you European people (such as myself, currently stationed in Germany), I just found out that the 94 Mazda*Xedos*2.0 v6 has the JE50 VAF (much like the KLZE). I have yet to find out what ECU it has. Will not be surprised if it is the KL31. Will also try and tear apart the engine and check out the cams.
Donor Car:
Why: http://forums.probetalk.com/showpost...&postcount=239
What: GM part number 15149708 is a great replacement for the stock trim retainers on the interior. GM uses them on their fender liners on pickups and a few other applications as well. The only downside is they only come in black.
Donor Car:
Why: http://forums.probetalk.com/showpost...&postcount=243
What: I believe 98 and up Mazda 626 KLG4 cars came with silicone valve cover gaskets. They do not need sealant to keep them from dribbling. I have not verified this but I have recently found the silicone gaskets on two different G4 cars. So either they were what was factory OEM or they got the silicone gaskets at a Ford/Mazda dealership service department? I don't know if I want to pay Ford prices for the gaskets only to find that they are the bake-n-crack variety.
Donor Car: 98 and up Mazda 626 KLG4
Why: http://forums.probetalk.com/showpost...&postcount=246
G35 Coupe
95PGT kinda stock
12 R6
14' Optima slow
June 30th, 2013, 08:51 AM   #258
doanh
: Jun 2013
: 10
that a useful thread!
July 3rd, 2013, 06:38 PM   #259
Lowbudgetprobe2
: Jun 2013
: 28
Helpful page thanks
July 3rd, 2013, 10:46 PM   #260
shaun708
Juiced Member
: May 2011
: Louisville, KY
: 996
Anyone know the model year carrera that the brakes come from?
January 27th, 2014, 08:49 AM   #261
illcool
: Apr 2011
: virginia
: 239
Bump, lots of great information. Does anyone know what year and engine type for the Ford Escape Axles?
93 PGT- street/track build KLZE, All Go no show! Cracked block
repairs in progress.
95 PGT- Daily Driver KLDE, body kit, 18in rims, cai, dual exhaust, plugs and wires.
96 PGT- Turbo Project KLZE, will be both Show AND GO!
1998 Eagle Talon Tsi AWD Street/Strip project. if you wanna know whats under the hood come and find out!
January 29th, 2014, 02:00 PM   #262
Dan [Sac]
Admiral General
: Feb 2000
: Nor*Cal
: 25,085
You don't need to bump this, it's got permanent, top-of-forum sticky status.
- KLZE, fender-flared, right hand drive, 2350 lb fully loaded sex machine. ||
||- SOLD
- 10.24 @ 139.9 mph ||545 whp @ 20 psi ||
- GONE
97 GTS - Rear Wheel Drive KLZE, 6-speed, 3.90 Torsen LSD, 2650 lb, daily driver! -
- GONE
90 Ghettocet KLiata - forever WIP
February 9th, 2014, 01:15 PM   #263
Ford427
: Nov 2008
: Minnesota
: 31
: 292
Is there anyone with info on the 8 valve engine make model and year as far as upgrading from stock f2t rockers to these solid ones? Or a thread about it that I missed... Pm'd ls-6 with no response
89 PGT: DD, stock until spring
June 19th, 2014, 12:22 PM   #264
coyotanark
: Dec 2010
: France
: 7
Brakes
Mazdaspeed 6 brakes are plug & play on front and for the rear you have to make a custom ebrake cable (I made one with a Lokar kit), for 2nd gen.
On the 2.0l, 36-1 harmonic balancer from protege is plug & play and the crank sensor too for megasquirt.
June 22nd, 2014, 06:35 PM   #265
MSDKLZE
Turbo Junkie
: Mar 2008
: Gulfport Mississippi
: 34
: 4,071
I think you meant 12 valve.
For all of you Mazda6 brake swap guys, be aware that they are now available through AutoZone's Duralast Gold brand as high-carbon steel rotors! I just got my own brand new front set and they are awesome
DRIVE IT LIKE YOU BUILT IT!!
November 22nd, 2014, 05:28 PM   #266
RACERSNUT
: Feb 2009
: Down South
: 247
I'm interested in the Protégé tubular lateral links, can someone supply the years/model we should be looking for?
I see no mention of the MX3 rear motor mount that can be used. Still looking for the years/model we should be looking for that as well.
November 23rd, 2014, 09:17 AM   #267
MonoxideChild
: Jul 2002
: Rockford, IL.
: 39
: 17,228
^ The MX3 rear motor mount isnt a direct swap. It involves a bit of fabrication and welding. This thread is more for stuff that is easily swappable.
PaTricK
~ 92 PGT, 97 KL MTX 626, 05 Mazda6, 13 Mazda CX9, 09 Kia Sportage 4x4 v6 ~
December 8th, 2014, 09:00 AM   #268
B-Ball
: Aug 2010
: Fort Walton Florida
: 895
A little off topic, but transparent lego antennas make good replacement needles for gauges. I was thinking about this when reading the thread on changing the gauge colors and how many people have broken the needles off. http://www.toysperiod.com/lego-set-r...-antenna-pack/
I think it's an obsession!
June 16th, 2016, 02:01 PM   #269
Bradley in DC
: Mar 2016
: Washington, DC
: 94
Great thread. The fluidic windshield washers for a Mazda Tribute are a cheap but fantastic upgrade.
Bringing back a 1996 SE with 181k miles
February 3rd, 2017, 12:02 AM   #270
Stanced4lyfe
: Jul 2015
: 178
I have read this whole thread and found great information except the one I really want which is about the ford escape axles. Found specs on rock auto for the Ford escape axles from 01-06 2.0L, 2.3L and 3.0L v6.
Ford Probe manual axles(Same as auto. 2.0L 2.5L are the same)
Front Right
ABS Ring Type: Toothed
ABS Tooth Count: 44
Axle Nut Hex Size (mm): 32
Inboard Joint Diameter (mm): 81.5
Inboard Joint Type: Female
Length (In): 22 7/8
Length (mm): 581
Measurement Type: Compressed
Number Of Inboard Joint Bolt Holes: M22*1.5
Number Of Inboard Splines: 28-2T
Number Of Outboard Joint Bolt Holes: 0
Number of Outboard Splines: 28
Outboard Joint Diameter: 84.5
Outboard Joint Type: Conventional
Front Left
ABS Tooth Count: 44
Inboard Joint Type: Male
Length (In): 24 13/16
Length (mm): 630
Ford Escape axles (V6 only comes in auto)
01-04 2.0L manual transaxles
Front Right
ABS Tooth Count: 44
Inboard Joint Diameter (mm): 79
Length (In): 22 9/32
Length (mm): 566
Number Of Inboard Splines: 35
Outboard Joint Diameter: 83
Front Left
ABS Tooth Count: 44
Length (In): 24 11/16
Length (mm): 627
01-04 2.0L Auto transaxles
Front Right
ABS Tooth Count: 44
Length (In): 21 15/32
Length (mm): 545
Number Of Inboard Splines: 35-1T
Front Left
ABS Tooth Count: 44
Length (In): 25 7/8
Length (mm): 657
01-04 3.0L V6
Front Right
Same as 01-04 2.0L Auto axles
Front Left
ABS Tooth Count: 44
Length (In): 26 7/16
Length (mm): 671.5
05-06 2.3L manual transaxles
Front Right
Same as 01-04 2.0L manual transaxles
Front Left
ABS Tooth Count: 44
Length (In): 24 7/16
Length (mm): 621
Number Of Inboard Splines: 30
05-06 2.3L auto transaxles
Front Right
Same as 01-04 2.0L auto transaxles
Front Left
05-06 3.0L v6
Front Right
Front Left
You can easily look at these specs and determine if they will work or not. Hope this helps!
