  ProbeTalk.com Forums > Tech Section > 2nd Gen (93-97) V6 2.5L
October 18th, 2004, 08:56 AM   #1
timr467
: Oct 2004
: 7
Angry Help, My tail lights, dash lights, and park lights dont work
I have a 97 probe that I receantly purchased. The only lights that are come on when I turn on my lights is the head lights.
The tail lights, park lights, fog lights, and dash lights are not working. Anyone have any ideas how to fix this problem?
October 18th, 2004, 10:39 AM   #2
bato_yu
: May 2004
: MI
: 33
: 136
damn bro sorry totell you but you probably fried a ground wire somehow and it melted with other ones . This hapened to me when I was installing neons and extracting power from the lighter. and through my carelesnes i conected the ground with the power suply for only a few seconds and the ground wire burned all the way to the main harness and then i realized that my dash or tail end lights didn't work. i had to take the radio and ac console out and follow the wire all the way back and replace.
Took about 3 hours. GOOD LUCK
October 21st, 2004, 12:17 PM   #3
fekinfast_gt
: Oct 2004
: Denver Pennsylvania
: 34
: 31
Arrow
mayb u should try checking all the fuses the cover over the fuse case inside yer car and under your hood both have a diagram telling u what fuse does what check the brake lioghts or check all the fuses make sure there not blown
Oni-Roh
PGT deep
fekin fast probe
October 21st, 2004, 02:32 PM   #4
jordanmc31
: Dec 2001
: Pennsylvania
: 762
Could be condensation getting into the light sockets.
October 21st, 2004, 03:27 PM   #5
95gt4me
: Sep 2003
: pa
: 83
i had this problem before. i remember it was a fuse. dont remember where though.
October 21st, 2004, 05:16 PM   #6
punkerx86
: Oct 2004
: 8
its fuse number 11 i believe, but hey if i'm having that problem but it keeps blowing the fuses when i replace them and i've tried putting in bigger amped ones and they blow too is it a bad ground connection?
October 21st, 2004, 05:19 PM   #7
Project GT
Balls Across The Nose
: Jun 2004
: 3,493
man see all my shit work except my gauge lights...i'm stuck on that one
October 21st, 2004, 07:04 PM   #8
ouch1011
: Jul 2001
: ProbesNW.com
: 17,298
Fuses blow when excess current is running through them, meaning that one of the wires is shorting to ground. Not fun stuff, as it involves tracing the wiring through the car, looking for wires with broken insulation.... DO NOT put a higher rating fuse in there, or anything else to replace the fuse, as that is a textbook way to start a fire.
To the original poster, your problem is a fuse. All those lights are operated off the same fuse. I can't remember which one, unfortunately, and I don't want to dig up my owners manual to find out
Kevin B - Former Probe-owner
October 22nd, 2004, 09:38 AM   #9
timr467
: Oct 2004
: 7
I got them to work. I had a wire off at the switch in the turnsignal.
