  ProbeTalk.com Forums > Vendor Support and Contact > Former Vendors > South Bend Clutch
South Bend Clutch South Bend Clutch
February 1st, 2006, 01:26 PM   #1
SB Clutch
: Jul 2004
: 57
: 5
Feramic is the best clutch material ever made
Feramic is a cinderd iron clutch facing that has graphite impregnated into it. It has more holding power than ceramic, it engages way smoother than ceramic and won't eat up the flywheel like ceramic.
The best part is that it can be used on a puck style clutch disc or a full face clutch disc. And it can be coupled up with other friction products to fit different torque levels.
These are available for all Probes. Here is a link. Check it out...
Andy
http://www.dxdracingclutches.com/images/100_0976.gif
February 9th, 2006, 07:48 PM   #2
mx6gt04
: Nov 2002
: 1,807
Yes, for an all around clutch that is much less likely to break our transmissions from shock loading due to harsh engagement, feramic seems to be the hot ticket.
I've yet to see a disc that can compete with the OFE in streetability, reliability, and holding power. Nice job
94 MX3 V6 - 403 whp 412 ft lbs 15 psi pump gas. RIP
04 Volvo S60R 6 spd
February 9th, 2006, 08:25 PM   #3
veltpak6
Registered User
: Dec 2002
: Toronto
: 39
: 1,229
is that disc hardcore enough?
February 9th, 2006, 09:06 PM   #4
mx6gt04
: Nov 2002
: 1,807
I ran a kevlar before, and with a 1700 lb pressure plate, it held 397 tq for a good while before i got occasional slipping. This disc has a higher coefficient of friction, so it should hold the 450-500 hp/tq I'm shooting for.
04 Volvo S60R 6 spd
March 11th, 2006, 12:47 PM   #5
raf2379
: Sep 2000
: 296
Im actualy in the marker for a new clutch, next week I'll be Ordering one, but my question is, if i buy the dxd-F kit with the regular pressure plate, will the clutch hold up to 350hp + and torque?? or should I go with the DXD-F kit SS Stage 5, its a bit more expensive, but i have the money and if it holds 98% more then It probably would be a good choice, any sugestions please.
Thank you
1991 Probe GT -=| Garrett GT3071R 0.63A/R external wastegate |=-
March 11th, 2006, 03:37 PM   #6
jmmdm2
: Feb 2000
: I have no life so I don't LIVE anywhere
: 45
: 2,813
I'm in the markeR for a new clutch as well.
I'm sick of the damn chatter off my spec stage 3, been looking for a full face with decent holding power. The spec engaged quite harsh and I'm thinking it's to blame for popping my diff pin through the case.
Anyone running these feramic clutches yet?
I'd like to hear real world opinions on one before I buy one.
DE/ZE Hybrid 189 WHP 165 WTQ <--- SPUN #6
March 11th, 2006, 06:57 PM   #7
izzy
: Nov 2004
: All over Ontario
: 179
so how much is it for this clutch? for 2.5 2nd gen
March 11th, 2006, 07:29 PM   #8
jmmdm2
: Feb 2000
: 45
: 2,813
if i read the web site correctly, the full face two side feramic is 550 with the better pressure plate. 82% increase in holding
March 12th, 2006, 02:22 PM   #9
izzy
: Nov 2004
: All over Ontario
: 179
thats what i was afraid of
thanks
March 12th, 2006, 03:56 PM   #10
mx6gt04
: Nov 2002
: 1,807
Ive got 800 miles on my OFE. Engages nice and smooth for a clutch that can hold as much as it does. Havent had the chance to up the boost and tune for 20 psi and 450ish whp yet though, so we shall see
04 Volvo S60R 6 spd
March 12th, 2006, 05:04 PM   #11
jmmdm2
: Feb 2000
: 45
: 2,813
Just to clarify...
You're running a full face feramic? Both the flywheel and PP sides of the disc are feramic? This PP is a heavy duty version?
I just want to make sure I'm buying exactly what I want.
March 16th, 2006, 10:22 AM   #12
mx6gt04
: Nov 2002
: 1,807
Im running the OFE, which is full face feramic on the flywheel and organic on the pressure plate with a sprung hub. Im using an 1800 lb pressure plate with it.
04 Volvo S60R 6 spd
April 29th, 2006, 12:30 PM   #13
RigsPGT
: Mar 2002
: PT territory and sunny FL
: 40
: 7,093
Im running one too
Its a full faced Feramic on both sides and so far (12k miles) has been holding good. Mine was rated somewhere 365whp or smth like that which i dont think i will exceed it for a while.
Rio Red 94PGT, Turbo T360trim,T3T4E 50 trim,T3T4E57 trim Parted out!
1998 Volvo S70, The Brick
1999 Red Volvo S70 T5 The Red Devil, modded
1998 Black V70R AWD, The Waggo with mods
April 30th, 2006, 04:39 PM   #14
akmer
: Feb 2005
: San Antonio, Texas
: 34
: 1,810
would this clutch be good for n/a? i only have the mods listed on my sig...and later down the road im gonna supercharge it, but is it worth the mony to jusr get it while im n/a?
April 30th, 2006, 06:31 PM   #15
RigsPGT
: Mar 2002
: 40
: 7,093
The good thing about this clutch is that it feels like stock but holds the power and right now im not boosted yet
April 30th, 2006, 06:41 PM   #16
akmer
: Feb 2005
: 34
: 1,810
^^^cool man, thanks for the info, ill should be ordering this in around 2 weeks
May 1st, 2006, 11:41 AM   #17
spada
ProbeTalk MC
: Feb 2000
: Eating spaghetti in Rochester Hills
: 39
: 15,555
so how do you know that it holds the power?
personally, i dislike my OFE clutch. it definitely holds all my power (which isn't much) but it slips for a half second if i'm shifting hard from gear to gear.
the CM-III had a much more positive grabbing feel.
go with the Feramic on both sides if you can. that medium metal organic side that the OFE has basically makes it grab like a stock clutch if you ask me.
2014 Fusion SE MTXtreme
2005 Mountaineer Premier
May 1st, 2006, 12:18 PM   #18
RigsPGT
: Mar 2002
: 40
: 7,093
Good question Ben
I meant to say its holding great at stock levels that i am now! According to Andy at SBC, this full faced feramic (both sides) holds ~365lbs, a lot more than i'll throw on it (10psi). <-------will see how it goes.
And since you mentioned CM clutches, one thing i liked about my CM1 was that the clutch grabbed hard, i could chirp 3rd everyday.
If i still had the CM1 PP, i would have used that instead! SBC seems to use PPs that are rated at/or stock numbers. (i've read the discussion that comes into ur mind now)
May 1st, 2006, 01:03 PM   #19
mx6gt04
: Nov 2002
: 1,807
Ive got 400 hp and it doesnt slip for me
It grips like stock, but thats awesome. Ive broken 3rd gear twice and dont feel like doing it again. A harsh clutch is completely unneccessary.
04 Volvo S60R 6 spd
May 1st, 2006, 04:15 PM   #20
spada
ProbeTalk MC
: Feb 2000
: 39
: 15,555
i totally agree that a harsh clutch is unncecessary.... but the good stick drivers know how to use their harsh clutch in a mild manner, which is why i would have liked for this clutch to be a little more harsh... like at least give me the ability to chirp 2nd gear.
oh well... it's a good daily clutch anyways, and it holds all the way to 7000rpm. i shouldn't complain too much. though if i were to do it again, i would have went either feramic on both sides, or segmented kevlar again
May 1st, 2006, 10:16 PM   #21
samurai gt
: Oct 2002
: Boston, MA
: 37
: 92
I have about 1500 miles on my OFE clutch. I believe that I have the lowest level pp on my setup and I love the way it grips. I have not run the car really hard yet but I have chirped 2nd without trying. The other day I was going along slow in 1st or 2nd I can't remember, then I decided to go WOT suddenly. I was surprised that I chirped the tires. I had a SBC kevlar TZ prior to this when i replaced it the pressure plate looked great. This is a great clutch.
KL-ZE, Southbend Clutch OFE, 11 pound UR flywheel, cross-drilled rear rotors, CAI, sleepy eyes, H-4 conversion, NGK V-power plugs, MSD super conductor wires, MBX UDP
Just moved to Boston any MAPOC members in the area. Hit me up with a PM.
October 1st, 2007, 07:46 AM   #22
mesoungodlyfast
BATN, but AKA:
zlyricist
frcfdkl03
: Jan 2005
: 5,329
south bend rules!
October 1st, 2007, 06:22 PM   #23
RigsPGT
: Mar 2002
: 40
: 7,093
36k miles later and mine is still perfect. I changed a tranny at 30k and there was little to no wear on it. Great clutch soo far
