Now available!!
1988-92 MAZDA MX6/Ford Probe rear trailing link kit. Tubular steel with polyurethane bushings. Enhanced rear wheel control with these units. Replacement trailing links for the 88-92 MX6 are made of tubular steel utilizing urethane bushings on the both instead of the stock rubber. This unique approach controls the different forces at work, on each end of the arm. Provides much better control and stability. Gloss Black powder coated finish.
Most of you have seen and known of these for the 2nd gens for a long time. I know there are bushings available already to put into your stock arms. However, I am not sure if its the same with the 1st gens as it is with the 2nd, but we tend to bend out stock arms easily overtime from normal use. This way, the arm is stronger materials as well.
Can be purchased at www.nolanspawn.com/forsale.htm
