Originally posted by earl8245
View Post
I don't smell gas when I crank it over, interestingly enough, I had pulled out a spark plug on cylinder number 1, and the sparkplug is wet and it did smell like gas actually.
As far as the starting fluid, I would guess that I have somebody else crank it over while I open the throttle body and spray the starting fluid with the can straw in there, correct? Is there going to be any backfire or anything that I need to be aware of, like catching myself on fire, or any little detail like that?
Now what did you mean by "An easy route would be to pull off the pcv hose from the manifold (the one that comes from the front valve cover)"
Do you mean to inject the starting fluid in there or something?
On the the ECU. Is there a way to test this thing? Do I have to take to the dealer or something to have them test it? Also.. where is this thing in my '94? I'm thinking that I will have to be upside down under the steering wheel to reach it? Does anybody have a picture of it so I know what I'm looking for?
Again, I had the intake manifold off this summer. The connectors in the back were really a pain to deal with. Is that what provided the signal to the injectors to fire? My thought being that maybe I might have damaged that part when I put it back together. Although it did run, it never did start right off the bat like it did before I started that particular task.
Thank you again you guys for your help.
Shawn
