  ProbeTalk.com Forums > Tech Section > 2nd Gen (93-97) I4 2.0L
2nd Gen (93-97) I4 2.0L Discussion of Maint Issues for I4
May 9th, 2018, 09:24 AM   #1
griffer
: May 2016
: 21
Strut issue - help
replaced the front struts and springs. The psg one has wayyyyy bad camber problem. Top of tire slants way in. I know the only way to fix a camber is to turn the mount at the top. My question is how much? 90 degrees? 180 degrees?
May 9th, 2018, 04:43 PM   #2
yellowrob
: Feb 2009
: Pure Michigan
: 36
: 1,947
Depends can you look at your old ones and see where they matched up at?
Some people are living life and some people are just living.
May 10th, 2018, 05:59 AM   #3
griffer
: May 2016
: 21
Nope I can't they're gone. The new struts are Tokico's.
May 10th, 2018, 06:20 PM   #4
Silverprobe
: Feb 2000
: Shawnee Nat'l Forest
: 4,385
Use eccentric camber bolts to gain more adjustment? (Replace one of the stock strut/knuckle mounting bolts on each side to gain adjustment capability).
Can't post links, so just Google "camber bolts".
May 11th, 2018, 09:48 AM   #5
griffer
: May 2016
: 21
Can't do that
I would do that but the mount hole in the struts are round. They won't accept the eccentric bolts only round ones.. I have bolts though.
May 11th, 2018, 06:20 PM   #6
Silverprobe
: Feb 2000
: 4,385
Eccentric camber bolts are smaller in diameter than the stock mounting bolts. It's the eccentric part itself that makes the overall diameter the same at that point on the bolt, and which allows for the adjustability.
When I first installed my Eibach springs years ago from Tirerack, I purchased the eccentric bolts at the same time. They've done the job ever since.
May 13th, 2018, 05:52 PM   #7
g98swc
: Dec 2014
: NW Washington
: 35
The flat edges of D-shape threading at the top of the struts should mirror each other. Should be to the inside rear corner, if memory serves me right.
May 14th, 2018, 05:42 AM   #8
griffer
: May 2016
: 21
Tada!!! Factory screwup
I just had a weird feeling on this so I checked. Now the part number is stamped on the strut along with a BIG R. Well I assumed that meant RIGHT. So that's where I installed it. That particular part number goes on the LEFT. I haven't checked the other strut yet to if it has an L on it. DuhO!!!!! That might explain a lot.
thread
volt gauge issue/ idle issue slammedslug 2nd Gen (93-97) V6 2.5L 26 June 21st, 2012 05:18 PM
Idle Issue/Fan Issue CEL 09 FightTillYouDie 2nd Gen (93-97) V6 2.5L 5 October 7th, 2009 05:41 PM
alignment issue/rotating strut mounts... PLEASE help if you can! dummkompf 2nd Gen (93-97) V6 2.5L 2 October 1st, 2009 11:53 PM
Quick question about rim/strut issue Level 9 Appearance Section 9 March 9th, 2005 08:14 PM
