  ProbeTalk.com Forums > Vendor Support and Contact > Former Vendors > Cyborgzero Racing Technologies
Cyborgzero Racing Technologies Cyborgzero Racing Technologies
August 9th, 2005, 08:34 AM   #1
boosted2g
: Oct 2002
: Nebraska
: 204
czt engine kit?
I have the czt internals. I had a horrible knock in the motor. Took it apart after only 1500 miles, and all the bearings were destroyed. Both rod bearing and main bearings. I need to know if these guys are still around? Also if anyone else has this kit what are the changes that need to be made to the block to get everything to fit? (I cant find any old email's) Anyone with some information please let me know.
95 Probe GT Turbo
06 Mazdaspeed6
12 Nissan Pathfinder
August 9th, 2005, 09:44 AM   #2
babyblueMX3
: Jul 2003
: Gatineau, Quebec, Canada
: 37
: 1,015
I have it in my car and no problem what so ever..THe main concern we had when machined/assembled the engine was to ifnd proper rod bearings to fit the cranks. the 0.030" undersize he sent with the kit was too big.
0.040" under fit but didn't have enough clearence. so we machine down the crank in order to fit the 0.050" undersize
You did check the clearence between bearing and crank right? I hope you did and not installed the first of bearings you got.
I got the clevite 0.050 bearings for rod paired with toga high performance main bearings...0 knock
01 Golf GTI 1.8T
August 9th, 2005, 10:10 AM   #3
janz99
: Jul 2003
: Winnipeg
: 1,626
I also have this kit, and we had to machine the crank as well!! If you didnt machine the crank chances are this is why you have chewed up all the bearings!! He told me specificly that i would have to machine the crank.
CZT is still around, its just hard to get ahold of him!! Ive talked to him several times!
Ryan
August 9th, 2005, 01:37 PM   #4
deejayarse
: Oct 2000
: Arctic Circle
: 43
: 1,369
Same here. I have czt kit in my engine and the machine shop was having hard time with having it all machined up. I'd remember they had to machine the crank too. There were some issues with the bearings but I really can't remember what it was.
Mici
Mazda MX-6 LS-T
Audi TT-R 1.8TQ
Toyota MR2 Spyder
Aprilia RSV1000RR Factory
August 9th, 2005, 01:46 PM   #5
boosted2g
: Oct 2002
: Nebraska
: 204
Mici
I know that the bearings that were in there were the .040. The main bearings were the ones that failed. The knock came alive when we were making 21psi. When I took everything apart the mains were destroyed (toga high perf.) the rod bearings werent as bad, but not reusable(sp)
Also when you mach. the crank don't you lose some strenght?
Thanks for the help!
95 Probe GT Turbo
06 Mazdaspeed6
August 9th, 2005, 02:21 PM   #6
mx6gt04
: Nov 2002
: 1,807
You do lose some strength, but i highly doubt youll ever break it.
You sure you had good oil pressure? Sounds like an oil delivery problem to me, if the clearanced were right.
94 MX3 V6 - 403 whp 412 ft lbs 15 psi pump gas. RIP
04 Volvo S60R 6 spd
August 9th, 2005, 02:51 PM   #7
boosted2g
: Oct 2002
: Nebraska
: 204
I have a brand new high volume toga oil pump. Pressure seemed normal. Around 50psi. what oil psi do you run?
95 Probe GT Turbo
06 Mazdaspeed6
August 9th, 2005, 03:39 PM   #8
gus 93pgt
: Jan 2003
: ILL
: 38
: 3,345
Did the motor tick or make noise from the get-go?can you get some pictures?usually you can tell if it was oil or clearence issues.is the bearing worn out evenly?or are they just destroyed?
|.....Overnight.....................| ||
|........Japan Parts................||'|";,___. <~~~~~~~~~~~~~ \_ OH NO'S! It's Toretto!
|_..._...____________======||_|_|...,]------------------__/----\___
"(@)'(@)""'''''''''''''"'''"**|(@)(@)*****"(@)--------------~['(@)***(@)_'\
August 9th, 2005, 04:05 PM   #9
TRWeiss1
: Jul 2002
: Squirting all over Binghamton, NY!
: 38
: 16,018
At 21 psi, are you sure the knock you were hearing wasn't detonation? What kind of timing/fuel delivery are you running?
95 PGT MTX - Probezilla - Supercharged 'n Squirted ZE @ 8 psi
93 FD -
(w/ old rotary setup)
89 DTM PGT -
miles! -
- Sold
04 Subaru WRX STi - Perrin FMIC, Greddy 3.5" catback, K&N intake -
- Mustang Dyno
(past rotary setup)
August 9th, 2005, 04:39 PM   #10
boosted2g
: Oct 2002
: Nebraska
: 204
Main bearings were destroyed (peices of them in the oil pan) Rod bearings were just worn. The motor had 1,500 miles.
95 Probe GT Turbo
06 Mazdaspeed6
August 9th, 2005, 04:47 PM   #11
boosted2g
: Oct 2002
: Nebraska
: 204
Megasquirt, 65lb injectors.
95 Probe GT Turbo
06 Mazdaspeed6
August 9th, 2005, 10:51 PM   #12
janz99
: Jul 2003
: Winnipeg
: 1,626
Who did all the machine work, clearancing the bearings etc??? We had a hell of a time with EVERY bearing on this engine. Were the main bearings sat, the hole was actually to large, so we had to machine down the main girdle then re-line hone were the main bearings sit. Then the crank had to be machined to fit the over sized bearings!!
ALSO VERY BIG!!!! My scat rods were OUT OF ROUND!!!! Oval if you will, the large end. We had to machine the caps of the rods, then re-hone the rods to get them perfectly round!!
I am going to say that the machine shop that put your engine together over looked a few things and now this is why you are having difficulty with it!!
Let us know how it turns out!
Ryan
August 10th, 2005, 06:20 AM   #13
93GTSR
: Mar 2001
: Independence, KY
: 37
: 6,357
wow, sucks to hear this guys. Makes me glad that i have moved on to cars with actual aftermarket performance, and being able to buy things that have been tested many many many times, and i know they work
August 10th, 2005, 07:02 AM   #14
boosted2g
: Oct 2002
: Nebraska
: 204
Ryan
I think that you are correct. The machine shop broke it off in me!
95 Probe GT Turbo
06 Mazdaspeed6
August 10th, 2005, 10:56 AM   #15
charger758
PT Guru
: Dec 2000
: Jon's mom's box.
: 6,323
What a nightmare, I hope you get this straightened out, thanks for posting too. Before I buy an engine kit it will help with my research.
98 Z3
2000 F150
August 10th, 2005, 11:00 AM   #16
Probesport
20 years of Probin'
: Feb 2000
: Standing on a hill in my mountain of dreams.
: 18,720
Following is always easier than leading
| 2005 VW Touareg V8
August 10th, 2005, 11:11 AM   #17
TRWeiss1
: Jul 2002
: 38
: 16,018
Glad to see you got your intake temps down man!
93 FD -
89 DTM PGT -
miles! -
- Sold
- Mustang Dyno
(past rotary setup)
August 10th, 2005, 03:40 PM   #18
93GTSR
: Mar 2001
: Independence, KY
: 37
: 6,357
Leading for years and years and going through 3 transmissions a summer takes it toll
So now ive moved on to cracking ringlands on 3sgte's
-Ty
August 11th, 2005, 06:02 PM   #19
twinturbo6
: Aug 2001
: Pooler, GA
: 484
probesport, ole friend, why don't you lead us into a piston/rod kit that genuinely works? I believe we would all be grateful....
I choose to believe what I was programed to believe.
August 12th, 2005, 04:58 AM   #20
babyblueMX3
: Jul 2003
: 37
: 1,015
why ? the czt kit is good enough. just a problem with the bearing size. depends on the wear you have on the crank
01 Golf GTI 1.8T
August 12th, 2005, 05:02 AM   #21
Fastest95PGT
: Dec 2000
: Near Worcester, MaPOC
: 40
: 4,427
I think it was moreso because CZT's business habits have been questionable in the past so handing ~$1300 over might not be something people are willing to do . . . especially if CZT already has $400 of their cash for some .. other product.
I agree the bearing size isn't a real issue from the numerous people with this kit I have spoken to. Just bring a rod, bearing, and crank to the machine shop and say "make workie" and if the shop's decent, they can machine the crank ever so slightly to make it work.
(member #1404) 1995 PGT - Reliable stock internal'd 10:1 300+whp ZE-T & highest horsepower of 275whp @ 5psi
August 12th, 2005, 05:19 AM   #22
charger758
PT Guru
: Dec 2000
: Jon's mom's box.
: 6,323
Thanks, at the moment she is running better than ever.
98 Z3
2000 F150
August 12th, 2005, 06:52 AM   #23
janz99
: Jul 2003
: Winnipeg
: 1,626
Well if i was doing it, i would also have the shop measure the rods themselves, like i said earlier they were out of round by a big margin on my build!!
The rods, were not czt's fault in anyway, if anything, i would place the blame on scat for not checking to make sure they bored the rods out properly.
Ive talked to rob nemerous times, and he has always been upfront (with me anyways) on how long something was going to take to ship. He told me 3 and a half months on my engine kit, as he would have to wait for the pistons. It ended up taking him 4. Id do buisness with him again.
Ryan
August 18th, 2005, 06:38 PM   #24
bslav94pgt
: Jun 2005
: Lyons, Il
: 459
Hey this is gus 93pgt on a diff computer,anywho,destroyed bearings=machine shop error.They have to machine each bearing journal,and line hone the block/girdle and the balance the rotating assembly.Reason is the .040 is alot for the mains,it's expensive,but it has to be done,otherwise when the motor sees alot of stress the main bearings will just get demolished.I'm into DSMs now,but same machining process has to be taken.I would try and get sme money back off the machine shop.
August 18th, 2005, 07:34 PM   #25
janz99
: Jul 2003
: Winnipeg
: 1,626
You sir are correct. This is what was done with my block to ensure proper fitment of the 40 over bearings!
Ryan
