  ProbeTalk.com Forums > Performance Section > 2nd Gen (93-97) I4 2.0L Performance > 2nd Gen (93-97) I4 2.0L Performance Archive
2nd Gen (93-97) I4 2.0L Performance Archive Quality Archived Posts and FAQs
January 19th, 2005, 12:47 AM   #1
ddrop
Moderator
: Dec 2001
: buffalo ny
: 35
: 1,843
FS Head Performance Archive
It is a known fact that the fs02 motor makes minimal gains with basic bolt-ons. This inspired me to create an Archive for improving a very important role player in the FS engine…the head. This archive is mainly a database containing information about upgrading head components, head swaps, and dyi headwork.
I am not completely done with it, and may have a few errors here and there(its 3am gimme a break ) Any info you would like to add/correct, please pm me.
Head swaps
Currently only fsze and fsde heads can be swapped onto our blocks. The problem here is that the heads are almost the same. The only reason why I could see you swapping the head is because the FSDE has the advantage of using solid lifters. Also you would have to put a hole into the head for the stock distributor.
No Honda heads have been swapped onto the FS block.
Here is a good thread on this topic:
http://forums.probetalk.com/showthre...ght=head+honda
Another FAQ is about swapping the Mazda fe3n head. It has already been researched, and will not work.
Head Work
Head Terminology
http://www.alaniztechnologies.com/headterms.html
DYI headwork guide
http://www.sa-motorsports.com/diyport.shtm
Interesting headwork articles
http://www.automotiverebuilder.com/ar/ar119854.htm
http://www.team-integra.net/sections...sp?ArticleID=4
Headwork on the FS head
http://forums.probetalk.com/showthread.php?t=1701130909 - My experience analyzing, disassembling, and performing custom work on the fs head.
http://www.msprotege.com/vbb230/show...ight=flowbench -Protege owners experience with headwork including flowbench #s
Head Component upgrades
Cam upgrades:
Basic info on cams can be found at http://auto.howstuffworks.com/camshaft.htm
Additional info- http://www.elgincams.com/campaper.html
The stock cams on the FS motor are bit on the conservative side. A lot of power can be made by upgrading these cams.
Please keep in mind that there is no BEST cam for the probe. It depends on your application goals. Certain cams may require additional upgrades to the head such as valve springs and lifters.
-J-spec Intake cam off FSZE motor
Pros: Mildly aggressive intake cam with gains seen as high as 10whp, as well as raising the powerband up ~400rpms. Has shown improvement among boosted applications as well.
Cons: Loss of torque, rough idle. Can only use the intake cam due to the fact that the exhaust cam lacks a distributor gear
Dyno plot:
http://www.toprotege.com/reviews_old...stock_run.jpeg
Cost: $180
Website:
http://www.corksport.com
http://www.srmotorsports.com/protege.htm
-Crower Custom Cam Regrinds
Pros: Custom cams tailored for any specific application. Very cost efficient when compared to the J-spec cam.
Cons: Process requires you to send in your stock cams. More dyno research needs to be done in order to maximize gains.
Cost: Typically $200 + core cams
Website: http://www.crower.com/
Phone: 619-422-1191
-Wagner Motorsports Stage 2 cams
Pros: Gains seen has high as 24whp on Protege with both intake and exhaust cams
Cons: Can only use the intake cam due to the fact that the exhaust cam lacks a distributor gear. Price not listed
Cost: call
Dyno plot: http://www.wagnermotorsports.net/gra...e_Cam_Dyno.jpg
Website:
Adjustible Cam Gears:
Cam timing is what controls the opening and closing of valves.
Adjustible Cam Gears will allow you to change your cam timing. This in return sets the placement of the Power/Torque curves. Adj Cam Gears should be tuned on the dyno for best results...otherwise they may hurt performance.
-SR Motorsports ACGs
Website:
Valve spring upgrades:
-Eibach Evs Spring kit
Website:
http://www.corksport.com/main.php3?p...3Fcat%3D220746
Valve Upgrades:
Ferrea Custom Valves
http://www.ferrea.com/valves.php
http://forums.probetalk.com/showthre...light=2.0+head -ferrea valves on the fs head.
More info to come…
Lifter Upgrades:
Custom or
Protege lifter swap:
http://forums.probetalk.com/showthread.php?t=1701141841
More info to come…
Evo16g,
, Oliver Billet rods,Wiesco 9:1 forged pistons,Apexi AVCR, 440cc injectors,Walbro 255hp,TypeRS Bov,Atx->Mtx,2.5 DP & MES Catback,RR-Sts,CM 2-R clutch, AWR Rad & Pan,Megasquirt2pcb3,
January 19th, 2005, 01:19 AM   #2
ddrop
Moderator
: Dec 2001
: buffalo ny
: 35
: 1,843
Misc Info/Helpful links
http://web2.airmail.net/theman/protegefaq/engine.html -FSZE and FSDE specs
http://members.aol.com/solomiata/MX5Engine.html -Mazda Interchangeability guide
http://www.msprotege.com/forum/showt...ghlight=valves -MSP FS buildup
Evo16g,
