  ProbeTalk.com Forums > Performance Section > 2nd Gen (93-97) I4 2.0L Performance > 2nd Gen (93-97) I4 2.0L Performance Archive
2nd Gen (93-97) I4 2.0L Performance Archive Quality Archived Posts and FAQs
June 27th, 2008, 01:21 AM   #1
M.Hicks
: Aug 2002
: Omnipresent
: 5,412
Post FS Revisions & Redesigns 93-03
Reference by year:
1993
Head revised slightly(late 93).
1994
Cams revised(rumored be slightly more aggressive).
Crank revised(mid 94).
1995
Intake manifold revised for OBD-II emissions(late 95, same basic design).
Pistons revised.
Crank revised(late 95).
1997
Crank revised.
1998
Throttle body redesigned(larger).
New intake manifold equipped with VICS introduced for the protégé.
Old intake manifold(non-VICS) redesigned(less torque bias) for the 626.
Head redesigned(larger ports - FS9 casting).
Valve springs revised.
Lifters redesigned(SLA’s replaced HLA’s).
Cams revised for solid lifters and slightly improved power and torque.
Pistons revised.
Block revised(allows for the OEM oil cooler, also rumored to be stronger and have more coolant passages).
2000
Intake cam revised for improved emissions(no change to the exhaust cam).
Pistons revised.
Crank redesigned(forged crank replaced cast crank).
2002
Throttle body revised(mid 02).
Rods revised in the advent of the MSP(rumored to be only tolerance revisions).
Quick reference by part:
Throttle body: 98, mid 02
Intake manifold: late 95, 98, 00
Head: late 93, 98
Valve springs: 98
Lifters: 98
Cams: 94, 98
Pistons: 95, 98, 00
Rods: 02
Crank: mid 94, late 95, 97, 00
Block: 98
I'm going to put this up here as a sticky for a week, then I'll move it to the archive. I've left this thread open so feel free to leave feedback here, and as always, you can PM me any time.
Matt Hicks
Silver 97 2.0 Turbo
Factory Green ZX6RR
If you have 1,000 posts and have not donated to PT, you should consider doing so.
"We're all still learning."
June 27th, 2008, 08:46 AM   #2
unionrdr
: May 2007
: Sheffield,Ohio
: 63
: 7,820
Good info to have,thanx Hicks. Interesting that the 98 has a larger TB. It'd be nice to maybe change the control box on top of it,etc to use on the earlier models. Or maybe the controler/reader that's on the larger one could be used by the obd1 ecu's? Just a thought...
'94 PROBE SE Middle-aged croozr
July 7th, 2008, 06:23 PM   #3
bedwards6954
: Jul 2006
: Northwest
: 1,942
I am curious about the throttle body how much bigger is the 98 compared to ours??
Supercharged 2.0 Ford Probe
2k4 Mazda RX-8 GT, 9000rpms anyone?
July 9th, 2008, 11:00 PM   #4
akstud1983
: May 2006
: Anchorage, Alaska
: 36
: 298
also would it be better to buy the 02 over the 98??? what are the revisions???
2004 Subaru Impreza 2.5 MTX(Needs Boost BAD!)
96' Green SE 125k MTX 2075 Lbs "lightweight"
95' White 626 LX 137K AT !SOLD! "tha Turd"
94' Pink SE 64K MTX
Sold
92' Silver PLX ATX (R.I.P.)
July 11th, 2008, 07:36 PM   #5
M.Hicks
: Aug 2002
: Omnipresent
: 5,412
Revisions are minor, mostly insignificant changes.
Redesigns are major or significant changes.
Matt Hicks
Silver 97 2.0 Turbo
Factory Green ZX6RR
