Hi everyone,
I have been trying to track down a stutter around 2000 rpms when the car is warm and under load. It has become worse over the past month. No issue starting or running when cold.
I did the basics already, new spark plugs and wires, cleaned the nipples on the disty cap.
To see if get any symptoms at all when it should be running rich i disconnected the front O2 sensor in an attempt to get the ecu to give it a rich mixture because of a "bad" O2 sensor reading. After driving around for like 30 minutes the CEL never turned on. not sure why. Any ideas?
Thanks
Thanks
