Thee NYPOC Lounge
  • They're not THAT fast Ant. I also have a boost controller + chipped ECU running somewhere between 12 - 15 psi.
    I'm not saying that he wouldn't beat me...but it'd definitely be a far closer race than you'd think. From what I've seen, most of those R/T's are running between 14.5-14.8 stock, depending on the driver. It's not unreasonable for a 1G running more than double the stock boost to fall into that range.
    95 PGT MTX - Probezilla - Supercharged 'n Squirted ZE @ 8 psi
    93 FD - LSx 7.0L - 11.6@128.5 (w/ old rotary setup)
    89 DTM PGT - 49K ORIGINAL miles! - MINT! - Sold
    04 Subaru WRX STi - Perrin FMIC, Greddy 3.5" catback, K&N intake - 308AWHP/318AWTQ - Mustang Dyno
    Probezilla & The FD 540 RWHP/415 RWTQ @ 24.5 psi (past rotary setup)
    • Speeds run 14's If I sucked at driving... I could lose...
      Anthony D. Christiano
      • My parents use to have a plymouth acclaim that looked like that. I would love to get it and be like yeah its boosted. lol But anyways that plymouth acclaim was a POS went through like 4 transmissions... worst car ever.
        93 PGT-ZE-T<---- Yes T as in turbo.
        89 PGT
        • well if you upped the boost to double so would I!!!!!!
          93gt 230k dd.
          1993 probe gt
          96 pgt 135k dd
          http://i86.photobucket.com/albums/k1...100_3918-1.jpg
          • Fair is fair!! Sounds like we have a race
            Jeremy
            P.S. I just like the name Denise...
            83 LTD wagon "Sandra Dee": 351 Windsor, 3.73's and LSD, T5, 266whp 330ftlbs
            97 F-250 Powerstroke "Julia": S&B intake, aFe exhaust 191whp 418ftlbs
            97 Escort wagon "Klair": Version 2
            98 CBR600F3
            • HAHAHAHA, you funny Chris! I'm sure you'd crush me with double the boost level! It'd only be remotely fair if you stayed at stock boost.
              Now, the 90GT I had, on the other hand....That would've been a different story. Nothin like hitting 25 psi on the stock turbo on the highway! Boost creep? What boost creep?! That thing was a friggin tank...Now THAT would've given the R/T a run for its money!
              • I'm eager to get my boost gauge in to see what this thing runs at, especailly in each gear.
                • Those limit boost in 1st and 2nd as to reduce torque steer, right Ant? Once you start doing breathing mods to boosted (turbocharged) cars you do have to watch out for boost creep...just FYI.
                  • I understand what it is... just not how or why it occurs.
                    • Simply put the exhaust gasses can't leave the turbo fast enough out of the wastegate which allows the turbo to then build more boost.
                      You shouldn't get much with just an intake but the very first things you'll want to do is full exhaust including a larger diameter downpipe. This will allow the exhaust to leave the turbo faster by creating less back pressure. Once the boost gets high enough you will need an external wastegate on the manifold which will dump the exhaust before it reaches the turbo opposed to within it.
                      Jeremy
                      98 CBR600F3
                      • Originally posted by KLDE Wagon View Post
                        This pretty much explains it in a nutshell. Because exhaust is exiting more quickly due to less backpressure, the turbo will continue to spool, even if the wastegate is open. The exhaust will take the path of least resistance, and even though some will be diverted around the turbo via the wastegate, a large majority will still travel through the turbo, which will cause it to continue to spool.
                        Some people get around this by porting their wastegate (depends on whether you have an internal or external wastegate), which works in some applications...Others get different plumbing and run a larger external wastegate with a good, solid EBC to eliminate the problem (the route I took). It can get expensive though...
                        • I may only ever get the turbo to spool about 20 psi. But Cobb DP and Corksport 80mm exhaust are on the list with the addition of the AccessPort. Basic breathing mods. Definite suspension mods. It's too... soft.
                          • I <3 boost. That is all.
                            • Originally posted by Domino81 View Post
                              It's too... soft.
                              it haunts us no matter what we're doing!!!
                              93gt 230k dd.
                              1993 probe gt
                              96 pgt 135k dd
                              • Boost its a hell of a drug.
                                89 PGT
