Hello all,
I am in the process of making a plug and play harness for a 96 Probe 2.0. I have lots of Megasquirt experience on VWs, Subarus Mazdas, and Hondas, but this is my first venture into Ford.
I got a stripped down pin out of the ECM side of things and I took apart a spare ECM to get the connector from it. I see a few things are missing that I normally want. I wonder if you can answer some of my questions.
1) Ignition on the Probe is a Coil with what looks like its own igniter. Great! but is this one compatible with MS2extra? Can I wire it in to the ECM Pin out and be good? Or should I play it safe and mod the board for direct fire?
2) CKP appears to only have 2 pins on the ECM. OK. One is signal the other is Shield. Great. Question is, is this right? Which is which? And I am praying this thing is a 36-1 wheel with a 0* crank angle?
3) I see a signal return on the ECM, but that looks like it is for TPS only. Which pins are signal return for IAT and CTS? Are they the same or a different grounding pin? This is my least concern as its not exactly hard to wire this one.
Oh and just a random thought, whats the compression ratio on these suckers?
Thanks for your help!
