your tranny(spindle thing) is still in the torque converter or the tranny itself maybe sittingon top of the torqueconverter. Try tilting the engine to the driver's side by lowering it. Get a crow bar, and try to tap/pry the tranny out. It should come out after that.
HOW-TO: Tranny swap
Well, it's already tilted to the driver's side of the car. how exactly doest the flexplate/torqur converter attach to the motor? Is it a splined shaft that connects the crank to the tranny? Or does the Flexplate/TC bolt up tight to the motor?
By taking all the tranny to motor bolts off, the tranny should be able to just "slide right off"?
It's not working for me...1999 Nissan Maxima
SHIFT_this
The flexplate is bolted to the crankshaft. The torque converter is bolted onto the flexplate. The spindle thing is on the auto tranny and inserts itself into the torque converter. You have to stick a pry bar and nudge the tranny out(usually gets stuck on the bottom. Just keep trying, top and then bottom.
It shouldn't slide off if you took off the bolts, you just need to give it a harder "nudge".
2002 audi a4 quattro- snowmobile!
1996 Mazda Mx-6 M-edition- New Toy!
1988 mx6 gt-Looking for a replacement engine
1991 Mazda miata
ATX-MTX
I want to do this sooooooo bad.. i dont have to donor car next to mines though, guy at the junk yard told me he will let me take all the parts off a probe to do it for $250...... im dont know about trannies that much but i need to do it sence i dont have a 3rd gear in my car anymore... and alot of slipage help me my car is a 89 mx6 lx
problems with my swap
i kinda ran into a wall with this swap, im hearing a few different things about year specific parts. is the ecu on a 97 gts the same on both the atx and mtx? and which years is the intermediate shaft on the 97 compatible?97 GTS - Gone Wonder what it looks like now...
98 Grand Prix GTP
BTW anyone in the toledo (ohio/michigan) area interested in performing a tranny swap???97 GTS - Gone Wonder what it looks like now...
98 Grand Prix GTP
Re: problems with my swap
Thanks to mx6/xj from mx6.com:
Originally posted by mx6/xj
Here are links to the write up on the wiring aspects of the ATX to MTX conversion.
http://www.overnight-networks.com/pi...ing%20CCP1.doc
http://www.overnight-networks.com/pi...ing%20CCP2.doc
http://www.overnight-networks.com/pi...ing%20CCP3.doc
http://www.overnight-networks.com/pi...ring%20NPS.doc
http://www.overnight-networks.com/pi...ing%20comp.doc
http://www.overnight-networks.com/pi...%20reverse.doc
Greg
1991 Mazda miata
Those interested in the 2.0 swap, mx6phan has an excellent write up in the projects forum on mx6.com. Link is here:
http://www.mx6.com/boardnew/showthre...threadid=56811
1991 Mazda miata
Hey I was just wondering does all of this post on the swap apply to the mazda 1989 gt ATX to MTX swap...I am about a week from diving in and this appears to be a big help if things are the same for the most part
-{godsquad}-No longer a six owner, but I still visit.
founding member or MWC
