Ive been making these harness's for the locals and have 2 extra's I am selling. These are made by me, they are both meticulously soldered and heatshrinked. They are both tested for an extended period and work very well. No issues whatsoever. I have a couple options for you to choose from.
With this harness, all you do is unplug your factory ecu, plug this harness in, plug the obd2 ecu in. If your doing the millenia MAF conversion, you add the steps to soldering the MAF and IAT connectors in place of the VAF connector. With this conversion you no longer need to jump the GND and TEN pin to check codes, you use your basic OBD2 code scanner, and plug into the provided port.
$165shipped. Harness only
$185shipped. Includes, Harness, MAF pigtail, IAT pigtail, IAT sensor, 5 sections of heatshrink tubing and detailed instructions on how to solder the pigtails onto your harness.
Notice in the pics one is long, and one is short. The one is rough a foot and the other is around 6-7 inches long, but both give you plenty enough room to utilize the factory ECU bracket.
Note: You will throw a check engine light if doing the millenia MAF conversion due to the millenia ECU being an ATX ecu and throwing ATX codes, but does not affect performance.
Also, I have not yet tested on a 95, but I am assuming it should work and am hoping to test soon.
Any questions. Feel free to ask. - Thanks Scott
Heres a start up video with one of these harness's
http://www.youtube.com/watch?v=gv5SK...uV4jFg&index=3
And another video with the first harness I made, wasnt too worried about how it looked, but as you can see, revs pretty good.
http://www.youtube.com/watch?v=lSSPB...qt_XDh4NuV4jFg
