Originally posted by David's94PGT
Electrical
-Plug in harnesses in tranny area.
-Plug in vehicle speed sensor.
-Don’t plug in reverse light switch.. To resolve that, use the 2 wires from the reverse light switch, plug into the to the 1 and 4 for continuity( for the harness in the illustraion below)
-Use 2 wires and jump 6 and 9 to trick the comp, so you can start the car.
-2-3 harnesses do not plug into anything, just leave it
The orange harness that looks like this:
TOP
|1 2 3 4 5|
|6 7 _ 8 9|
I only know of the reverse light switch on the front of the MTX closer to the rad, the sensor in the back closer to the firewall is the VSS, the VSS just plugs right in. The reverse light on the front can be wired in with the intructions above.
HINT
|1 2 3 4 5|
|6 7 _ 8 9|
^^^^^^think of this as a mirrior image, I wired it up wrong untill I thought of it as a mirrior image
As for the two switches on the clutch pedal, one of them is the neutral safty(AKA, clutch pedal safty switch) From factory you need to press the clutch down to start the car, this can be wired in to that switch from pin 6 and pin 9 from the instructions above.
The other switch is for the cruise controle kick off, all you have to do is wire this up in series to the cruise kick off from the switch off the brake pedal. SO, if you dont wire that up, if your on cruise and press on the clutch, your RPM's will sky rocket. It was a little scary the first time I did that.
TOP
|1 2 3 4 5|
|6 7 _ 8 9|
HINT
|1 2 3 4 5|
|6 7 _ 8 9|
