Originally posted by ladyjazz17
View Post
The SMOG thread
This is a sticky topic.
OK, since your post count isn't high enough, here it is:
http://www.accuratesmogcheck.com/
Note that at this link there is another link for a $15 off coupon. I take my PGT there and although they are not the cheapest, they are the best. The shop (Mr. Mazda) where I have taken my PGT for quite a few years also uses them, and they test performance cars as well as the average ones.
I realize it's a two hour drive for you from Sac, but maybe we could get a summit together down in the south bay.Last edited by ladyjazz17; January 29, 2013, 09:10 PM.2015 Dodge Charger SXT Rallye, JAZZZND , 40K
JAZZZIN 1994 PGT, MTX, Black/Gray leather, 200K, KLZE, Magnaflow catback SOLD to Dan [Sac]
JAZZZN8 (2008 Mazda RX-8 GT), JAZZZN6 (2013 and 2010 Mazda 6 s GTs), first BAPOC Prez James Creasy's JAZZZN2 (1994 PGT), the infamous GRPJUCE (1994 PGT) all sold
born in MA, grew up in MI, live in CA, just kept moving west
Ok so just a tad update on my SMOG battle.
I failed again. But the ZE is running alot cleaner then my K8. It has fairly new plugs, wires, fuel filter, catalytic converter and O2 sensors
The ZE is rigged up to use a EGR but i wanted to see if i would pass without one. I didn't pass Emission wise i only had high NOx at 25 mph....I thougth the EGR only ran at idle? or is it a 24/7 thing????
Visually i failed but i have an external coil and HEI. at my last inspection the smog tech wasnt to worried about that but this one was a little harsh. Ill go back the last shop i went too....
My idle is all willy nilly but that is a battle that i am continuing to battle.
The smog tech said he couldnt check my timing and my PCV was loose and it didnt seal.......well before i took it in there it had no problems but now its all loose. I can pull the thing without even trying
I also failed the check engine light because im running the KL36 ECU....... My plan to bypass that is take out the cluster and wire the oil light to the engine light so they come on and go off the same time as usual
I dont understand the High NOx at 25 mph
Im going to apply some of the patch ups and go in again before i buy a K8 manifold and switch the ECUĀ“s
here is a pic of my results>>>>>http://i.imgur.com/bX0TYcv.jpgLast edited by kulluminati777; March 6, 2013, 07:31 PM.
No EGR, KL36 ecu, Brand new CAT, and denatured alcohol in the gas tank. About 1 gallon to a half a tank......passed
http://i.imgur.com/UKrpeQ8.jpg
