Anybody in SC want a set of FD rims with tires??
  • #61
    yea man i inflated them to 40psi. just to be on the safe side incase they leaked air.
    karma to whoever can help me figure out why my brakes went.
    • #62
      Can you be a little more specific on the brakes? Did the pedal go to the floor? Was the pedal firm but it wouldn't stop? Also, the rim holds the rotor flat to the hub so maybe if your wheels were wobblin' the rotor was doing the same?
      Dale's twenny18 Lineup:
      93 PGT - On the 20 year restoration plan
      • #63
        given all the problems i still think the lugs are wrong. change those and then see whats up.
        when you put them on try to shake them while it is still on jackstands...
        Lots of cars... none of which are a Probe...
        • #64
          Originally posted by livingsacrifice View Post
          :thatswhyinolongertalktosummer:
          :nooneshould:
          Stephen Wilds #303
          PhotoPOC
          BMW 328i
          BMW Z4
          • #65
            Originally posted by supergoat View Post
            :nooneshould:
            Ypu and Daylin both suck. You're also both lying about your apparent disdain for me, but I'll avoid the public callouts.
            ~SumR
            I don't own a car anymore and it's weird.
            • #66
              :nooneshould:
              :peoplestilltalktosummer?: :howlate1990sisthat:
              • #67
                :welliwastoldtheproblem:
                Originally posted by weaksauce
                I think i know why your brakes werent workin mang. Totally logical explanation. Notice when you take a wheel off that the brake rotor has freeplay. Well what probably happened is the lugnuts didnt have the right taper and even tho you snugged them up the wheel still had plenty of play (shaking). The loose wheel was forcing the rotor to push the brake piston back into the caliper. Loss of brakes until you pumped the pedal a few times to rebuild pressure. Im almost positive that thats your problem especially since youre trying to run FDs wih no spacers. Get spacers and extended lugnuts or KICS Project spacers (google search them, they are dope) and the correct taper lugnuts and you should have no problems. Ive dealt with FD wheels before so i know how they fit.
                ^holla
                problem solved. going to get right lugnuts and spacers then try
                • #68
                  ^holla
                  too bad he is wrong. wonder what kind of 'dealings' he has had with fd rims. maybe he has seen some pictures on the internet. spacers have nothing to do with your problem. if the wheels fit on there without rubbing the struts, you don't have a spacer problem.
                  like i told you when you bought them... tapered lugnuts. thats it. you are trying to get enough pressure on an area to hold the rim centered by putting a flat bolt onto a tapered hole. | > is not going to seal very well. the wheels aren't drilled out for the exact size of the wheel studs so of course there is going to be play. that is what you were feeling. get tapered lugs so it forces the wheel to be 'aligned' with the hub and your problem will be solved. this has nothing to do with spacers.
                  oh. also. wheels don't hold rotors against caliper pistons, nor would they 'push brake pistons back into the caliper'. no matter how hard you do or do not put them on. the wheels hold the rotors to the wheel hub and the calipers float over the rotor. it would cause the rotor to just float around but both sides of the caliper would squeeze it regardless. might want to make sure the people you are getting your solutions from actually know what they are talking about...
                  • #69
                    hey shadow do you know anyplaces on woodruff or around woodruff that turn rotors? it would ahve to be close since i would be riding my bike to get them there. but i dont wana pay a ton!
                    word..
                    would u like to meet up for me to buy those spacers from you tonight? if not ill be over at that same bilo at like 8am tomorow.
                    ive had problems in the old towtruck with a front wheel bearing going bad and not having any brakes......
                    Last edited by thingsthatfly2; October 26, 2008, 03:23 PM. Reason: Automerged Doublepost
                    • #70
                      not on woodruff. only place i really know of that still does that for people is pepboys on laurens.
                      like i said, if you want spacers, that's fine. but put the rims on there first. if they sit against the hub without rubbing the springs, and you can still turn full lock in the front, you don't need them and i wouldn't recommend them. i bet if you just put on some tapered lugs you would solve all your problems at once. i can bring em to you somewhere tonight too.
                      • #71
                        cool well i live off woodruff unless u wana meet somewhere.. i need them for the rear because the rears the tires just barely touch the strut.
                        • #72
                          i'm on the exact other side of town so lemme know if you can meet somewhere more in the middle, like pellham road or somethin
                          • #73
                            im about to go up to the meet up at circut city if u wana meet up for the parts there? just give me a call i pm'ed the # to you
                            • #74
                              you sure you know how to PM? haha. cuz i haven't got your # either time you have haha.
                              • #75
                                :youaresadlymistaken:
                                2016 Subaru WRX Premium
                                04 Subaru Impreza WRX WRB sold to smurphsprobe
                                97 Probe 2.0L GONE
