  ProbeTalk.com Forums > Performance Section > 2nd Gen (93-97) V6 2.5L Performance > 2nd Gen (93-97) V6 2.5L Performance Archive
2nd Gen (93-97) V6 2.5L Performance Archive Quality Archived Posts and FAQs
May 6th, 2008, 05:44 PM   #1
Quicksilver
: Jun 2001
: fresno, ca
: 39
: 3,929
new retainers issues with head build? Part numbers inside --->
got a call today from the shop saying the retainers i gave them dont fit with the keepers. i drove down there and saw the issue.
this is with the new retainers and used keepers
http://s210.photobucket.com/albums/b...t=100_3966.jpg
http://i210.photobucket.com/albums/b...s/100_3970.jpg
this is with the old retainers and old keepers.
http://i210.photobucket.com/albums/b...s/100_3968.jpg
http://i210.photobucket.com/albums/b...s/100_3969.jpg
he measure the inner diameter of the new retainer and compared it to the old one, the difference is the new one is 6000 of an inch too small.
has anyone run into this?
he is also worried about the way the old retainer is sitting, says the stem head should protrude more.
probe is sold, now i have what the probe was suppose to replace, but ironically replaced my probe
1993 nighthawk 750
May 6th, 2008, 06:19 PM   #2
unknowncitizen
: Jan 2004
: SoCal
: 35
: 3,919
what kinda are they?
~GREDDY~MAGNAFLOW~ACT
FIDANZA~WILWOOD~AWR~RR-RACING~HS~OUTLAW
PRD~MSD-WINDOWS~TEIN-SS~RX-8~ALPINE
May 6th, 2008, 06:51 PM   #3
WhiteDart
: Oct 2002
: Boosting across east TN!
: 35
: 9,049
Yeah, what brand are the new ones?
As far as the old retainers are concerned, I have assembled 4 or 5 complete sets of heads and that looks normal to me. The way the HLAs are designed, they protrude about 5mm down inside the bucket and they press directly on the valve-stem and touch nothing else.
Gone but not forgotten:
) Its not purple dammit! Its
BOYSENBERRY!
New project
Daily When I go for a drive, I leave life behind. Friends, work, everything. Its just me, the car, and a twisty road. The exhilaration of being on the edge of catastrophe is something that I will never be able to give up.
May 6th, 2008, 08:11 PM   #4
Quicksilver
: Jun 2001
: fresno, ca
: 39
: 3,929
mazda OEM
part number
kl01-12-113B
i just did a google search on that part number and guess what i came up with
this is quoted from the aftermarket cylinder head sticky thread.
"Well....I have some information that might be good to know. The upper spring seats (retainers) for a '96 kl03 have the part number kl01-12-113B....the upper spring seats (retainers) for a '93-'95 kl03 have the part number kl01-12-113A. If these two parts are in fact different, this means that the '96+ kl03s received smaller locks and therefore needed a small diameter opening in the spring seat to hold them correctly."
1993 nighthawk 750
: Automerged Doublepost
May 6th, 2008, 11:44 PM   #5
1997
5 star member
: May 2003
: 50
: 5,704
You don't want it like that for sure: you will either hit something or drop the valve and still hit something
I had this problem assembling my heads. I was using ZE valves, Interprep retainers and ZE locks and it would sit too high. I had to go back and find all my DE valve locks to make it work.
(needs verification) Note that you need to match the locks as from the top of my head the locks are different size for intake and exhaust valves...
May 7th, 2008, 02:07 AM   #6
c-man
Mega Moderator
: Feb 2000
: SOCAL
: 22,061
That's a definite NO on using the new retainers. The old retainer/lock look right to me.
2015 Audi Q3 - Stock |
2017 Audi TTS - 034, Magnaflow |
May 7th, 2008, 07:29 AM   #7
Quicksilver
: Jun 2001
: fresno, ca
: 39
: 3,929
i'm going to see if i can get the updated keepers to go a long with the retainers.
1993 nighthawk 750
May 7th, 2008, 05:22 PM   #8
PovGRide742
: Jun 2006
: Womelsdorf, PA
: 30
: 2,133
When I emailed Interprep about their Valves and Retainers, they said their Retainers require a certain Keeper, which I believe are the new style. I am buying the Keepers from them also but my god are they expensive.
2001.5 Pearl White Audi S4 2.7T Quattro 6-Speed
GIAC-X Stage I
AWE Drivetrain Stabilizer / AWE Electronic Boost Gauge / AWE S-Flo Intake / AWE Side-Mount Intercoolers
May 7th, 2008, 09:31 PM   #9
Quicksilver
: Jun 2001
: fresno, ca
: 39
: 3,929
i decided to order the 93-95 style of retainers. the keepers i have are fine, i can just do a direct exhange for the retainers
1993 nighthawk 750
May 7th, 2008, 09:56 PM   #10
ouch1011
: Jul 2001
: ProbesNW.com
: 17,298
I don't think the valvestem protrusion is an issue because the actual part of the HLA that contacts the valvestem sticks out significantly further than the lifter bucket surrounding it.
Kevin B - Former Probe-owner
May 7th, 2008, 10:07 PM   #11
Quicksilver
: Jun 2001
: fresno, ca
: 39
: 3,929
maybe soo, but with the increase protrusion comes with a decrease of spring length. the retainer will sit lower in relation to the valve stem, thus compressing the spring even more further then what it was designed for, might even cause binding.
1993 nighthawk 750
May 11th, 2008, 06:53 PM   #12
Dan [Sac]
Admiral General
: Feb 2000
: Nor*Cal
: 25,085
So then what are the proper matching numbers for keepers & valve seats (retainers)?
My old build I was using OEM retainers with Interprep (which are also OEM) keepers, but I don't know what style either one was. The springs are Interprep.
For the rebuild now, I have the same Interprep springs, the new style retainers (kl01-12-113B) and the valve locks are FE3N-12-114. I'll have to swing by the shop and check out how they end up I guess.
- KLZE, fender-flared, right hand drive, 2350 lb fully loaded sex machine. ||
||- SOLD
- 10.24 @ 139.9 mph ||545 whp @ 20 psi ||
- GONE
97 GTS - Rear Wheel Drive KLZE, 6-speed, 3.90 Torsen LSD, 2650 lb, daily driver! -
- GONE
90 Ghettocet KLiata - forever WIP
May 16th, 2008, 03:57 PM   #13
Dan [Sac]
Admiral General
: Feb 2000
: Nor*Cal
: 25,085
Well. I did confirm ONE thing - the new styler retainers (KL01-12-113B) WILL NOT WORK with the keepers I have (FE3N-12-114).
So if you order keepers that have this part number(FE3N-12-114), make sure you get the older styler retainers (93-95) that end in 'A' (KL01-12-113A).
Matching hardware, for recap purposes:
'93-'95
Keepers: FE3N-12-114
Retainers: KL01-12-113A
'96-'97
Keepers: ???
Retainers: KL01-12-113B
That is all.
||- SOLD
- GONE
- GONE
May 16th, 2008, 11:00 PM   #14
Quicksilver
: Jun 2001
: fresno, ca
: 39
: 3,929
yep, that will work. to sum it up, just remember that OBD I and OBD II series retainers and keepers are NOT interchangeable
1993 nighthawk 750
September 18th, 2008, 10:19 AM   #15
PovGRide742
: Jun 2006
: Womelsdorf, PA
: 30
: 2,133
I know this thread is old but I want to fill in the missing information. I actually found the Number for the 1996-1997 Valve Keepers a while ago through Emails back and forth with MazdaPartsCheap.
Anyway, this information is pretty valuable so I figured I'd wake the thread from the dead. The 1996-1997 Valve Keepers are Part Number: FS01-12-114
So to finish the information Dan [Sac] posted above, here it is:
1993-1995 KL Part Numbers
Valve Spring Retainers: KL01-12-113A
Valve Spring Keepers: FE3N-12-114
1996-1997 KL Part Numbers
Valve Spring Retainers: KL01-12-113B
Valve Spring Keepers: FS01-12-114
That is all,
Brett
GIAC-X Stage I
