  ProbeTalk.com Forums > Performance Section > 2nd Gen (93-97) V6 2.5L Performance > 2nd Gen (93-97) V6 2.5L Performance Archive
2nd Gen (93-97) V6 2.5L Performance Archive Quality Archived Posts and FAQs
July 9th, 2002, 08:12 AM   #101
NOS97PGT
: Jul 2001
: Near the In and Out Burger
: 1,106
Read the faq. And don't use CAPS.
July 10th, 2002, 01:12 AM   #102
95sleeperGT
Balls Across The Nose
: Jun 2002
: 41
: 76
Originally posted by Drummerboyevil
As in the instructions above, I really don't want to epoxt the filter to the pcv.. don't most filters fit OVER 3 inch PVC in the first place??
the one i got didnt fit over it. the rubber surround for mounting was too stiff/thick to be worked over the pvc like i wanted it to do.
if ya want, just tap some screws thru the pvc into the rubber end of the filter, then you can just remove the screws for cleaning or replacing the filter.
July 12th, 2002, 10:47 PM   #103
slimdog23
: Jan 2002
: DeForest, WI
: 435
well i tried to make one for my atx today with 3 in pvc....aint no damn way that will ever fit tried to slide past radiator tube without pincing it. didnt work. I really hope 2.5in will work alot beter
July 13th, 2002, 07:22 AM   #104
NOS97PGT
: Jul 2001
: 1,106
If you read the original how-to on the first page, that wouldn't even have been a problem, b/c you'd have known it wouldn't work.
July 13th, 2002, 11:01 AM   #105
slimdog23
: Jan 2002
: DeForest, WI
: 435
haha i read it thats how i knew what to get.....but i wanted to attempt 3 in cuz i figured i might get it if i worked at it....oh well my own fault...so 2.5 works pretty wel right?
July 13th, 2002, 12:56 PM   #106
NOS97PGT
: Jul 2001
: 1,106
Should be ok...I gurantee you wont have issues with 2"
July 13th, 2002, 03:20 PM   #107
slimdog23
: Jan 2002
: DeForest, WI
: 435
hmm i think im gonna use 2.5....but where is a good place to get K&N cone filters that are 3 in? Or does neone have any product numbers
July 14th, 2002, 10:47 PM   #108
StreetThisMX6
PT Guru
: Oct 2001
: Barbertucky, OH
: 37
: 7,125
Thumbs up Want a cheap way to make a real CAI ???
check out this post on mx6.com:
http://www.mx6.com/boardnew/showthre...threadid=32967
your welcome
2006 Evolution IX - Best ET: 8.92 // Best MPH: 166.85
July 15th, 2002, 05:34 AM   #109
PurpleMetal1
: Apr 2001
: The TXPOC Garage
: 12,010
The HDCAI is cheap, that's just a visually appealing alternative. I saw that post a few days ago.
1994 Ford Probe 2.0L MTX
1996 Mazda 626 2.0L MTX
- Needs updating.
July 15th, 2002, 07:03 AM   #110
Madamen69
: Apr 2000
: coming to a cubicle near you !
: 39
: 560
Hey StreetThisMX6 thanks for the advertisement (I'm (V)azdaman ) hehe :grin:
July 15th, 2002, 07:12 AM   #111
Hibridmx3
: Jan 2002
: Rockford Illinois
: 1,273
i have personally seen josh's intake.... (and his skill of welding at 3am his intakes are they SHIZZZZY... i wouda used his disign if i didnt have my BBK inktake
July 16th, 2002, 09:29 AM   #112
Pete165
: Jun 2002
: Northern Illinois
: 853
I used 4" flexible dryer duct. Its a bi*ch getting it in, but once you do, its hardly pinched.
93 PGT {{SOLD}}
2000 Mustang GT
July 18th, 2002, 07:59 PM   #113
96GTAT
: Jul 2002
: cincinatti, OH
: 8
my friend has a 4 banger mustang and he got his made at the exhaust shop. just tell em where you want the bends and get 3" stainless pipe shouldnt run more than 20 bucks and no cutting required. anyone else done this i think im goin to try it
July 19th, 2002, 04:51 AM   #114
Madamen69
: Apr 2000
: 39
: 560
$20 for 3in mandrel bent stainless ?? you can't even get the amount of pipe needed for this project for $20 let alone have it custom bent, but if you can give the name and number of this exhaust shop !!
July 19th, 2002, 02:57 PM   #115
96GTAT
: Jul 2002
: cincinatti, OH
: 8
im serious he only paid 20 bucks for a piece like 2 feet long with 2 bends its not polished just regular exhaust pipe.
July 19th, 2002, 03:02 PM   #116
BabyBlue
: Sep 2001
: Canada
: 160
I think that I'm going to have to try this out for sure! Also, I dont' see why you need welding done?? Those rubber connectors are pretty damn strong
95' PGT - Pearl Blue/Purple - Greddy Cat-Back, HD Cold Air Intake, 64mm TB, Phenolic Spacers, PRD Short Shifter, NGK Spark Plugs, Mobile1 10-W30, Redline Mt-90, Yokahama AVS Tires... Mike Seli's reground cams in my closet just waiting to go in
Canadianz Rule
July 19th, 2002, 03:34 PM   #117
MC93GT
: May 2002
: grand junction, colo.
: 17
Re: Vacuum hoses
Originally posted by NOS97PGT
The little one you can just leave as it is one the stock sensor, just unbolt th bracket from the box. As for the larger one, cover it up with pantyhose or a breather, or you can jsut leave the damn thing.
the large vaccum line is part of the pcv system. make sure that it is hooked up. i didnt hook it back up and i am having to replace the whole pcv system. make sure it is hooked up!!!!!!!!
