  ProbeTalk.com Forums > Performance Section > Engine Electronics > Engine Electronics Archive
Engine Electronics Archive Only the worthy topics go here!
June 24th, 2005, 10:37 AM   #101
THEGAME
member #1,192
: Jun 2000
: At my work office, or home office
: 38
: 1,936
Okay, all is installed exactly to starr's setup and runs with two problems, i don't have a tach signal (Its a 93 so i shouldn't need the signal wire) and smoke came out of my prd cap (I've read it happens, but the wires are getting damn hot!) Any suggestions?
Chris
93GT royal blue-sold
93GT 5SPD 2.7L-sold
so whats next.......
August 5th, 2005, 10:12 AM   #102
a1waytrip
: Feb 2005
: Lincoln, NE
: 32
: 584
yea, make sure your wiring is right in the little dist. harness, that should take car of your tac.
1994 Ford Probe GT
H.S. CAI, H.S Headers, Resonated TP, Borla Cat-Back, MSD 6A w/ Blaster 2 Coil, PRD Plug Wires, Eibach Springs, Tokico Blues, and Pacesetter STS.
June 17th, 2006, 02:50 PM   #103
neilh2o
: Feb 2005
: Cleveland,Oh.
: 3,163
yellow/blue wire coming off the ICM is the tach feed
July 19th, 2006, 09:19 PM   #104
UnorthodoxCreat
Not done yet...
: Nov 2003
: Hanover, PA
: 35
: 5,373
Does anyone have any diagrams for a MSD install on a 93/4 PGT using the internal coil and the MSD harness that they could post or email to akprobegt@adelphia.net All I'm finding is ones with external coils and dead links.
Adam Kirkpatrick
1994 Ford Probe GT-T - Built for me, by me, 265whp
2010 Ford Fusion SEL - Wife's daily driver . . . . . . . . . . . . . 1997 Ford Explorer XLT 4x4 - Daily driver
1997 Ford F-150 XLT 4x2 - Work truck, wrapped, on 20's . . . 2001 Ford Focus SE Wagon - Work car
September 3rd, 2006, 11:18 PM   #105
charles
: Feb 2000
: washington dc
: 48
: 4,236
ok guys i hope these are as direct as i can possibly get:
1) i have a 93 v6 and i just installed a turbo on it.
2) i have a MSD 6AL with a blaster 2 coil
what i can't understand is, i ONLY use the 3 wire harness off the distibutor to hook this up right? Reason why is my tach is not working and if i understood this correctly that after cutting the green wire from the 3 wire harness that goes from the distributor to the ecu. i connected the white wire from the msd to the green wire on the side that goes to the ECU. Or should it be hooked to the green wire going to the distibutor.
Also i TAPPED the red wire into the black wire without cutting it. So have i done this correctly? If so then can someone help me to figure out why the car WILL start but will die if i don't hold the gas. also when i sometimes rev it up it sounds like it is missing as it will break up sometimes. I changed my plugs and it sounds like it help this situation as it revs alot smoother now but still won't stay started on its own. My next question is do i NEED a tach adaptor or not? If not then how do i get my tach to work?
ESPOC RACING TEAM charles
WITH SOME OF THE FASTEST FIRST GENS ON THE EAST COAST!!
Mazdaspeed6 current mods
CP forged pistons/carrillo rods/ARP head and main studs/DNP mani/GT3076 turbo/H&R coilovers/CPE 3" TBE/Ported intake mani/Standback ecu/custom 3" intake/FMIC etc... 12.28@112 1.68 60ft
1993 pgt/eibach springs/18' dritz/centerforce clutch/intake/ more later maybe..
October 6th, 2006, 11:09 AM   #106
metros
: Jun 2004
: upstate NY
: 36
: 156
Anybody have a wiring diagram for 93 mx6, 6al MSD, Blaster 2 Coil, #8910 tach adapter? I've searched through this whole thread and others. All the links seem to be dead.
If I've already done the HEI mod in the past do I have to stick with using that and wire that into the setup or can I throw that out and just use all the MSD gear? Reason I'm asking is because the only recent wiring diagram I did find was one where the guy kept his HEI setup and used the MSD here for reference:http://www.supermotors.net/vehicles/...media/178174_1
Thanks!
(edit) Also I don't have the MSD harness that everyone talks about. What extra steps will I need to take?
(edit #2) I found the performanceprobe diagram. I don't understand the portion of the distributor modification. Pretty much these steps: "Locate the wire connector with three wires on the distributor. Disconnect the metal tab that connects wire #1 (yellow/green wire) on the connector to the distributor.
Cut the wire from the distributor that connects to wire #2 (yellow/blue wire) on the connector and attach it to wire #1 on the connector"
Is it really necessary to remove the distributor to do this? From what I read/understand can't I just switch these two wires on the outside of the three pin connector? Also this diagram does not mention the tach adapter that I need for my car. Jesus this post is getting long with questions.
November 6th, 2006, 10:52 PM   #107
SOLDIER
: May 2004
: Willemstad,Curacao
: 39
: 274
Hi does the MSD BTM connect the same way ?
DISTURBING THE STREETS OF CURACAO .
ITS T3/T67 + KL03 forged +No2=
February 23rd, 2007, 03:41 AM   #108
attack_mx6
Balls Across The Nose
: Aug 2002
: Iraq
: 38
: 18,001
Question for using the msd and coil on a 95 pgt setup..... anything different and do they sell the plug harrness for that ?
February 23rd, 2007, 12:06 PM   #109
mac1
Probe has-been
: Jun 2001
: Phoenix
: 13,957
you cannot get the harness anymore. And I dont believe it's easy enough to install MSD on a '95+ pgt. You'd need a '93-'94 disty because of the internal crank sensor.
1993 Mercury tRacer :Vitara & mFactory: was my #1
1994 Mercury TrAcer Wagon : '02 SPI swap : the loaner
2001 Hyundai Accent 2.0L-T3 swaphas flat pots
2014 Factory Five 818s EJ255t :it's adorable
2000 Lotus esprit v8TT : under the knife 2018
2003 Pathfinder 200k miles : The daily
No I do not Uber any of these
February 23rd, 2007, 06:59 PM   #110
attack_mx6
: Aug 2002
: Iraq
: 38
: 18,001
Your joking....
isnt the 93-to 94 the same just a different wire harrness pin config ?
February 23rd, 2007, 07:10 PM   #111
mac1
Probe has-been
: Jun 2001
: Phoenix
: 13,957
i did say that.
March 13th, 2007, 11:01 AM   #112
N/A Matt
PT Master
: Jan 2001
: NJ
: 4,562
Cool
I still don't know of anyone running this setup on a 95 disty. I tried twice as did Turbo Mark. I even tried with a 93-94 disty and the adapter and only got smoke coming out of the disty. I've had a jacob's cap forever now, but my disty still works, so I'm not looking to put one in for sometime. Why the 95 is so different I have no idea, but this stuff was discussed in detail years ago and to much debate no results, proven that is, were had.
The ignitor replacement though I have not researched, search and on that you might come up with something.
