  ProbeTalk.com Forums > Performance Section > Engine Electronics > Engine Electronics Archive
Engine Electronics Archive Only the worthy topics go here!
August 18th, 2004, 09:00 AM   #1
Mbolin5
Five Star Member
: Jan 2002
: Terrible Haute, Ind.
: 49
: 3,909
Using a KLZE DISTY with HEI , anyone intersted?
I cleaned up the schematic for the 1993-1994 too, this one is much better than the old one.
'93-'94 KLZE Disty Schematic
This is a schematic for a 1993-1994 KLZE disty, HEI, external coil, MSD 6A. ZEDISTY with MSD
Here is a schematic for a 1995 PGT running the klze disty, and the HEI W/ MSD Blaster 2 coil. I hooked this up last night, and tried it out on a 1995 pgt, works great!
1995 PGT KLZE Disty Schematic
Here is the pin out for the 1995 disty plugs HERE
Here is the pin-out for the 4 pin klze disty Here
August 18th, 2004, 10:20 AM   #2
Tweaked
: Aug 2001
: Ottawa, ON
: 40
: 1,795
Go for it, I'll add it to my archives.....just gotta find my ZE disty now
ONPOC.ca Administrator
K-Series.ca Founder
1993 PGTZE, forever under construction...
August 18th, 2004, 10:51 AM   #3
Mbolin5
Five Star Member
: Jan 2002
: 49
: 3,909
Cool, one request is good enough for me! I have part of this done is MS Word, and a schematic is autocad. I will get it all together, along with a few pics, and make a post!
Look for it later in the week!
August 19th, 2004, 08:15 AM   #4
Mbolin5
Five Star Member
: Jan 2002
: 49
: 3,909
For starters, a schematic
Here is a drawing to start with, more pics to follow. Plus another drawing detailing the use of the 4 pin fuel rail plug instead of the 4 pin 'ze disty plug
http://img.photobucket.com/albums/v1...3-94-REV-C.gif
August 19th, 2004, 01:49 PM   #5
Ryanpzz
MegaSquirtPzz
: Jan 2001
: Somewhere Different Than Before
: 37
: 2,907
If anybody is interested, I could do a write up on using the KLZE disty with the GM hei mod. I have pics, wiring diagrams, plug info, etc.
I know its been done, well i think so, nobody admits to it anyway, but it took a lot of searching, reading, etc to put all the pieces together
Let me know, but i dont want to post it just to be posting!
I've done this a couple times... but for myself I'm running stock ignition. Good mod though, definately deserves a write-up... go for it! the probe community will thank you.
August 19th, 2004, 02:12 PM   #6
Omaha95PGT
o=II=o
: Oct 2002
: Virginia Beach, VA
: 6,953
Looks good so far. BTW, save the picture in a .gif file. You have too many artifacts using jpeg compression. The gif will end up being <20kb and look crisp. Also, you should try to also label the wires based on position of the harness while installed. The colors of the wires change year to year, but the position does not (except '95-'97). Use "front(radiator side)", "rear(firewall side)", "driver's side", "passenger's side" as positioning descriptors if needed.
an example: 800x600 gif multicolor and crisp lettering 21.5 kb
http://home.comcast.net/~mmunoz70/z/msdiag01.gif
Marc M.
2000 BMW M-Roadster
August 19th, 2004, 07:43 PM   #7
Mbolin5
Five Star Member
: Jan 2002
: 49
: 3,909
November 3rd, 2004, 12:11 PM   #8
Wowo76
: Feb 2000
: Orange, NJ 07050
: 1,086
Any updates on this?
What's a ZE?
i don't know, but your email address is NOT working and it needs to be fixed ASAP!
December 2nd, 2004, 02:16 PM   #9
Mbolin5
Five Star Member
: Jan 2002
: 49
: 3,909
Here is the schematic:
December 2nd, 2004, 03:28 PM   #10
janz99
: Jul 2003
: Winnipeg
: 1,626
Very nice!!! This pic helps me out a ton!
Thanks
Ryan
December 2nd, 2004, 11:37 PM   #11
turbo_KL
: Dec 2003
: turbo land
: 1,081
Good work.
Registered since 2001, but now a new screen name says it all :-)
December 3rd, 2004, 09:55 PM   #12
spada
ProbeTalk MC
: Feb 2000
: Eating spaghetti in Rochester Hills
: 39
: 15,555
i hooked up my ZE disty with MSD blaster 2 coil and HEI last night. works great
2014 Fusion SE MTXtreme
2005 Mountaineer Premier
December 4th, 2004, 09:39 PM   #13
Mbolin5
Five Star Member
: Jan 2002
: 49
: 3,909
Ben,
Is it hooked up like my schematic?
Good job either way Dude!
I was going to do mine this weekend too, but....fuel pump took a dump, so i am changing that out and............its everything i thought it could be, a total PITA!
December 4th, 2004, 10:33 PM   #14
spada
ProbeTalk MC
: Feb 2000
: 39
: 15,555
well it's close to your schematic. the difference is, your schematic seems to be for a 95 disty or something. i had to use all 4 pins on the ZE disty. the blue/white one on your schematic of the ZE harness is the crankshaft position sensor and it gets plugged into the one labeled Unused on the 6pin. this is mandatory for me, since my megasquirt is based off that sensor.
the coil works great though, no problems, runs smooth!
December 5th, 2004, 04:02 PM   #15
Mbolin5
Five Star Member
: Jan 2002
: 49
: 3,909
Looks Like I need to redo the schematic! Its supposed to be for a 93-94. I will redo it tomorrow, and fix the links to the new drawing.
Other than what you stated above, did the schematic look right?
Thanks!
December 5th, 2004, 06:22 PM   #16
spada
ProbeTalk MC
: Feb 2000
: 39
: 15,555
yes, everything else was fine, you should redo the schmatic in the correct wire colors.
December 6th, 2004, 02:08 PM   #17
Mbolin5
Five Star Member
: Jan 2002
: 49
: 3,909
Okay Ben, I updated with the wire change, can you take a look and see what you think now?
December 6th, 2004, 02:34 PM   #18
spada
ProbeTalk MC
: Feb 2000
: 39
: 15,555
yup right on, that's how mine's hooked up, and working great
February 19th, 2005, 06:37 PM   #19
Phat Matt
: Oct 2004
: Canada
: 34
: 9
i have a question about the 4 pin j spec plug
the color of my wires are why different from that diagram
from the front of my engine to the rear first i have pink then orange then red/blue (thickest) then black/red
what wires are what? can you tell me from front to rear of you engine compartment what wire is the grond, pcm power relay, crank pos, sensor, cyl ident?
February 21st, 2005, 09:59 AM   #20
jon93PGT
Five Star Member
: Dec 2000
: Jupiter, FL
: 39
: 11,155
I did this mod a couple years ago and have the diagrams all laid out as well. I had the setup running with the MSD Digital 6+ ignition and Blaster HVC coil though, so mine was a little different. If anyone would like to see my diagrams, let me know, I can scan em..
2014 BMW 328d Luxury Line- Mineral White/Saddle Brown Leather, Premium Package, Driver Assistance Package, Cold Weather Package, Navigation, car seats inside
2012 BMW X3 35i M Sport- Traded
2003 BMW 330i ZHP- Alpine White/Natural Brown Montana Leather, Performance Package, Cold Weather Package, Navigation, Certified Dinan Stage III, car seats inside
2004 BMW 330i ZHP- Totaled
February 21st, 2005, 11:44 AM   #21
Wowo76
: Feb 2000
: Orange, NJ 07050
: 1,086
I would like to see them....!!!
What's a ZE?
March 2nd, 2005, 01:54 PM   #22
Tim95pgt
Pr0n Photographer
: Mar 2004
: Manchester, TN
: 39
: 5,078
I am planning this on a '95, since my stock disty might be fried. What is the main difference in the wiring, since the '95+ distributers have a five wire lead versus the 6 wire lead? Also, I see a 1K ohm resistor in the mix. Will any 1K Ohm resistor work?
'08 Cadillac CTS 3.6DI FE3 MTX
'07 Lexus IS350
March 2nd, 2005, 07:03 PM   #23
Mbolin5
Five Star Member
: Jan 2002
: 49
: 3,909
See new schematics at post #50 for 1995 details
March 3rd, 2005, 08:02 AM   #24
Tim95pgt
Pr0n Photographer
: Mar 2004
: Manchester, TN
: 39
: 5,078
What is the wattage on the 1K ohm resistor? My local Radio Shack only carries 0.25 and 0.5 watt versions. I found the HEI module and the Blaster Coil locally, so all I lack is the resistor.
'07 Lexus IS350
March 3rd, 2005, 08:12 AM   #25
Mbolin5
Five Star Member
: Jan 2002
: 49
: 3,909
I would go with the .5 watt.
