  ProbeTalk.com Forums > Vendor Support and Contact > Former Vendors > Cyborgzero Racing Technologies
Cyborgzero Racing Technologies Cyborgzero Racing Technologies
April 4th, 2005, 01:16 AM   #1
c-man
Mega Moderator
: Feb 2000
: SOCAL
: 22,061
CZT "tranny saver" users?
How many actually have this on their daily driver? The reason i ask is because after I put it on, my 3rd gear broke one week later during a casual upshift. I had the entire tranny rebuilt with new synchros and gears.
Now some 3 weeks later, tonight...during a similar casual upshift to 3rd gear, the tranny went again.
Now I'm wondering if the czt bracket is adding firmness where it shouldn't be and causing the 3rd gear to fail.
Coincidence or not? Opinions welcome.
2015 Audi Q3 - Stock |
April 4th, 2005, 01:29 AM   #2
Project GT
Balls Across The Nose
: Jun 2004
: 3,493
wow. that's insane, i haven't read anything on pt about people having these problems. but if it's happened twice, i'd have to say it is the tranny saver. good luck man
April 4th, 2005, 05:54 AM   #3
babyblueMX3
: Jul 2003
: Gatineau, Quebec, Canada
: 36
: 1,015
shitty, I'm installing this brace in 2 weeks
01 Golf GTI 1.8T
April 4th, 2005, 10:21 AM   #4
Omaha95PGT
o=II=o
: Oct 2002
: Virginia Beach, VA
: 6,953
I haven't yet installed my brace yet (doh) but I don't really see how it can cause stress on the 3rd gear. All it really does is spread out the load across several bolts. The motor mount is still doing it's job (absorb some movement) and it doesn't seem to lock up any thing that should be moving. It's just holding what shouldn't move in place. I'll install mine and if it blows 3rd, I'll let you know. I hope not tho'.
Marc M.
2000 BMW M-Roadster
April 4th, 2005, 11:26 AM   #5
indymx6
: Feb 2004
: Indianapolis
: 36
: 3,142
its not the tranny saver. It sounds like you might have a bent shift fork to me. Did they check that while it was out?
"With A turbo, exhaust gasses go into the turbocharger and spin it, With a supercharger, air goes in,witchcraft happens and you go faster"
-Jeremy Clarkson
D'Jasper Probincrux III - South Carolina State University
April 4th, 2005, 01:46 PM   #6
c-man
Mega Moderator
: Feb 2000
: SOCAL
: 22,061
everything looked fine, but i'll check that out. the gears were worn originally, which is what we thought caused it to break the first time. but we;ll check the fork out again. the tranny is getting dropped tomorrow.
i'm down both cars now with a $150 weekly rental replacement. So its safe to April is starting off bad!
April 4th, 2005, 01:52 PM   #7
c-man
Mega Moderator
: Feb 2000
: SOCAL
: 22,061
Does anybody have it installed on their daily driver? Or am I the only one?
April 4th, 2005, 01:57 PM   #8
brian2305
: Sep 2000
: Deltona,FL,USA
: 2,818
I have one installed on my car but not a czt one but I've had no problems also I have a few other of my local guys that have em also and no problems
April 4th, 2005, 04:42 PM   #9
Jarod7920
: Feb 2002
: st. louis
: 34
: 4,049
dude i have had one installed on myn for almost a year and i have the horrible designed one, and i have had no problems and i run the shit out of the car.
-J-Rod-
301whp 293wtq 9.5psi 14 degrees
back under the knife (high compression & spray)
93 PGT-T
April 4th, 2005, 05:38 PM   #10
skelly
PT Guru
: Nov 2000
: The BAPOC Pit
: 6,208
Wowsers - I agree with the above comments, Chuck - the way that bracket mounts, it just doesn't sound plausible that it could be the cause of the failures. If you need it, I have a spare gearbox that I could ship you which is in need of a rebuild - just let me know.
- SK
April 4th, 2005, 06:10 PM   #11
ouch1011
: Jul 2001
: ProbesNW.com
: 17,298
I don't see any way that the CZT brace could be causing this problem. My guess is there is something else wrong in the MTX causing the synchro to go.
Kevin B - Former Probe-owner
April 4th, 2005, 07:56 PM   #12
Jeff L
: Mar 2000
: Des Moines, IA
: 47
: 9,017
Well, to answer your question, Chuck, I have one on my daily driver. So far [knock on wood] no problems at all.
I thought there were more people that had these things.
redeemed
IndyProbes founder
April 4th, 2005, 08:10 PM   #13
ProbinNewbie
: Sep 2001
: waynesboro va
: 32
: 1,335
i can't help you out but i feel for you and your tranny crapping out...mine locked at 60 mile and hours after 5 months of "clutch install" real shity people working on it. hope it all turns out alright
1994 pse- sold
1990 S5 RX-7 TII- destroys the autox/drift scene
1987 S4 RX-7 TII-wishing i could keep the tires planted
1988 mazda 323 GTX- Very much rally
2003 MSP-daily monster
April 4th, 2005, 10:11 PM   #14
skelly
PT Guru
: Nov 2000
: The BAPOC Pit
: 6,208
I had one in my hands, but never installed it. sold it to another PT'er.
April 5th, 2005, 12:20 AM   #15
c-man
Mega Moderator
: Feb 2000
: SOCAL
: 22,061
okay, so out of the few of us that actually use this, I'm the only one with this 3rd gear problem? It seems like it must be something else then. Anyother suggestions besides to look at the clutch fork.
Another issue: when i try to reverse, it wants to chatter. It makes it really hard to reverse. I end up having to give it alot of gas and ride the clutch. If I give it to little gas, like a normal reverse should require...its chatters. If I don't hold the clutch in almost fully, it will also chatter. Is this related to the fork? Or something else that could also cause the 3rd gear to fail? I replaced the reverse gear this last time as well. Its just getting really shitty/repetitive dropping and opening up the tranny.
Thanks so far.
April 5th, 2005, 12:48 PM   #16
JKpgt96
Drives Light Blurple Car
: Aug 2000
: St. Louis, Missouri
: 12,722
Your car hasnt been a daily dirver for a long time....
I have had this on my car since august and it is a daily driver, I have had no trouble at all.(knock on wood)...
April 5th, 2005, 08:19 PM   #17
mac1
Probe has-been
: Jun 2001
: Phoenix
: 13,951
damn Chuck sounds like you really need to take a close look at all your hardware in that tranny and/or get another used one to rebuild.
1993 Mercury tRacer :Vitara & mFactory: was my #1
1994 Mercury TrAcer Wagon : '02 SPI swap : the loaner
2001 Hyundai Accent 2.0L-T3 swaphas flat pots
2014 Factory Five 818s EJ255t :it's adorable
2000 Lotus esprit v8TT : under the knife 2018
2003 Pathfinder 200k miles : The daily
No I do not Uber any of these
