  ProbeTalk.com Forums > Performance Section > 2nd Gen (93-97) V6 2.5L Performance
June 29th, 2005, 01:15 PM   #1
AaronD81
: Feb 2000
: Manheim/State College, PA
: 1,162
How much Hp can stock injectors handle?
How much for stock injectors and how much for Millenias? Most people running boost switch to millenias, but I couldn't find a real number, just mods. Is there a cutoff when you should switch to bigger injectors?
Member #263
June 29th, 2005, 06:20 PM   #2
El_Chineois
: Dec 2004
: Montreal
: 34
: 236
I thinks it 230hp - 240hp...but I'm note sure... plz corect me if I'm wrong.
BuRn RuBBeR, NoT YouR SouL...
1997 BlacK On BlacK PGT
KLO3, KLZE IM, KLZE Cams, Phenolic Spacers, CAI,67mm TB, SS Autochrome headers, Testpipe, Borla Cat-Back, MSD Window Switchs, FPR, ACT 6 Puck Ceramique Clutch, Brembo Cross Drilled Rotors, 1995 FD's, Sprint Lowering Spring.
June 29th, 2005, 06:25 PM   #3
TRWeiss1
: Jul 2002
: Squirting all over Binghamton, NY!
: 38
: 16,018
hmmm..very good question. I wondered the same thing.
95 PGT MTX - Probezilla - Supercharged 'n Squirted ZE @ 8 psi
93 FD -
(w/ old rotary setup)
89 DTM PGT -
miles! -
- Sold
04 Subaru WRX STi - Perrin FMIC, Greddy 3.5" catback, K&N intake -
- Mustang Dyno
(past rotary setup)
June 29th, 2005, 08:20 PM   #4
bryantaylor
: Apr 2003
: under my hood in jacksonville, fl
: 33
: 2,599
there are just too many factor to just have a hp limit. when your duty cycle is to high, it time for bigger ones. us MS guys can actually see our duty cycle
94 PGT-T Blanchard V "most interior panels missing" winner (parted out)
90 miata t3/t4, meagsquirt, and more
95 lincoln mark VIII
06 GSXR 600
June 30th, 2005, 06:01 AM   #5
spada
ProbeTalk MC
: Feb 2000
: Eating spaghetti in Rochester Hills
: 40
: 15,555
also depends on what fuel pressure you are running, stock injectors with fuel pressure upped by an FMU can hit near 90psi or more. 220cc/min injectors at 90psi is quite a bit of fuel, and that will get you past 250hp easily. but then, the injectors probably won't last as long.
for a simple breakdown, check out this page http://www.msefi.com/msinfo/manual/minj.htm
2014 Fusion SE MTXtreme
2005 Mountaineer Premier
June 30th, 2005, 06:34 AM   #6
94PGT
: Feb 2000
: Oklahoma
: 40
: 1,639
depends on what your setup is. are you n/a or f/i? stock fuel pressure or higher?
injector flow (lbs/hr) = (hp x bsfc)/ (# of injectors x duty cycle)
stock ecu limits duty cycle to 75% iirc.
a bsfc of .5 for n/a would give you around 190hp with stock fuel presure for stock injectors, or around 230hp for millenia 280s. if you could find 310s you would have around 260hp worth.
if you use a bsfc of .6 for f/i, all the above hp numbers will decrease.
Black 94 PGT - squirted, LSD'd, turbo DE/ZE hybrid @ 8psi
Forget the dog...turbos are a man's best friend
June 30th, 2005, 07:09 AM   #7
AaronD81
: Feb 2000
: 1,162
Thanks for all the info guys, Spada that's a great page.
Member #263
