  ProbeTalk.com Forums > Probe Owners Clubs > Tennessee Probe Owners Club
Tennessee Probe Owners Club Home of Old No. 7 - and TNPOC!
October 9th, 2014, 02:21 PM   #501
grimjoker95gt
busy,busy,busy
: Oct 2008
: working
: 36
: 2,458
if you would have said something i would have sold you my fuel
set up
January 2nd, 2015, 09:31 PM   #502
WhiteDart
: Oct 2002
: Boosting across east TN!
: 35
: 9,049
So I guess I should post a little update since its been quite a while. Havent driven the car much since the shift shaft seal leak has gotten considerably worse. The inevitable thing that I have been putting off is having to pull the motor. I can no longer pull the trans with the motor still in the car because the rear turbo block ONE trans bolt from being removed, and of course the rear turbo cant be removed without pulling the motor out. Poop. Thing that sucks is I replaced all the seals besides that one which of course I cant replace without tearing down the trans.
The only other issue to speak of is an old problem that crops up during very cold weather. It involves the thermostat not opening due to the coolant being so low of a temp in the radiator before it hits the thermostat. My solution will be to either drill a bunch of bypass holes in the thermostat to force coolant flow, or, get an aftermarket inline thermostat housing and locate it in the upper coolant hose.
Other than that, the car still runs great. Currently on 7.5psi and is uber smooth all the way through the rpm range. Planning on eventually getting a TiAl Q 50mm bov for an even better sound track to go with the screaming twins.
Jim K.
Gone but not forgotten:
) Its not purple dammit! Its
BOYSENBERRY!
New project
January 3rd, 2015, 03:12 AM   #503
zerialz
: Sep 2012
: Las Vegas
: 687
Wow double postage victim!! Maybe this should be considered a symbol or a trophy or something..
January 3rd, 2015, 03:59 AM   #504
stoker100
: Oct 2003
: Australia
: 37
: 5,851
in regard to the thermostat issue one small hole should allow for enough flow to solve your issue. (small being 1.5mm roughly)
January 3rd, 2015, 11:44 PM   #505
WhiteDart
: Oct 2002
: 35
: 9,049
Im not sure a small hole it would completely solve the problem though. Sub freezing air hits the radiator and cools the coolant down before it hits the thermostat, which keeps it shut. It has nearly overheated on my several times and the only way to get it to stop is to shut the car off and let the thermostat heat soak for 20 or 30 minutes until it opens. Then it will run fine for a while until the radiator over cools and closes the thermostat again.
My only fear with relocating the thermostat is that it may reduce system pressure because the thermostat will be creating pressure just in the block and heads, and pressure will be reduced across the radiator.
Jim K.
BOYSENBERRY!
New project
January 4th, 2015, 12:19 AM   #506
Ghostcloak
: Feb 2005
: Garner, NC
: 33
: 83
During my first winter with my MX6, I experienced a LOT of issues with my thermostat sticking, nearly overheating before finally opening. I replaced my thermostat with an OEM one (previous owner had recently replaced it with an aftermaket universal one that didn't have the hole). I've got pictures comparing the two. After sticking with an OEM thermostat, I've never had issues. It's worth a shot replacing the thermostat for $15 and 30 minutes of your time before you go doing all kinds of crazy mods. Least it'll be good piece of mind...
2005 C6 Z51 460 glorious WHP
1997 Mazda MX6 LS Sold
1993 Ford Probe SE Sold
1985.5 Porsche 944 Sold
1993 Mazda MX3 RS Sold
January 6th, 2015, 06:38 PM   #507
WhiteDart
: Oct 2002
: 35
: 9,049
Im on my 3rd OEM one in about 2 years. lol. Im big into OEM parts whenever possible.
Jim K.
BOYSENBERRY!
New project
January 7th, 2015, 11:25 AM   #508
Ghostcloak
: Feb 2005
: Garner, NC
: 33
: 83
:'( Hope you resolve this issue!
January 7th, 2015, 04:47 PM   #509
1990GTturbo
: May 2013
: Cohocton, NY
: 32
: 188
On the rare occasion that my uncle has to drive his F-350 diesel in the winter he puts a piece of cardboard in front of the radiator between it and the core support. It limits the amount of cold air that can hit the radiator/intercooler and helps hold a little more heat in the coolant. Truckers have the canvas over the nose of the trucks for the same reason in the winter time. Its worth a shot to give it a try.
March 31st, 2015, 08:10 PM   #510
WhiteDart
: Oct 2002
: 35
: 9,049
Well after thinking on it hard I suddenly had a epiphany. Remember when I had swapped in the FS trans internals? Yeah, I also swapped in the 2 piece shift shaft which allowed me to replace the shift shaft seal without tearing apart the transmission. XD Only took 20 minutes to replace it. I also drilled two 3/32 holes in the thermostat to keep some coolant flowing to get the thermostat to kick open. Seems to work so far.
I really need to get the rear aligned again after replacing the rear lateral arm when the sway bar ripped out on the dragon last year. Also need to find somewhere to put my larger coolant reserve jug. Then its good to go for some summer fun.
Jim K.
BOYSENBERRY!
New project
April 2nd, 2015, 05:45 PM   #511
WhiteDart
: Oct 2002
: 35
: 9,049
Well, drove it to work today. Tweaked on the rear lateral arm a bit and got the rear alignment acceptable. Still needs to hit the alignment rack but it will do for now. Its almost time for tires anyway.
Got my new larger coolant reserve jug installed today as well. Holds roughly twice the coolant as the previous one so it shouldn't suck it dry and cause aeration problems anymore. The drilled thermostat is doing well. Takes a little longer to warm up but it maintains temp perfectly well. Its still a dream to drive.
Jim K.
BOYSENBERRY!
New project
August 5th, 2015, 09:44 PM   #512
WhiteDart
: Oct 2002
: 35
: 9,049
Just popping back in to say not much has changed. lol. Car still drives beautifully.
However there are some big things in store for this winter.
Jim K.
BOYSENBERRY!
New project
August 6th, 2015, 05:57 AM   #513
dammitcam
: Nov 2010
: Not So Pure Michigan
: 28
: 499
putting one them there tree fittys in er?
September 14th, 2015, 01:16 PM   #514
WhiteDart
: Oct 2002
: 35
: 9,049
Lets just say its gonna be much faster come springtime.
The cool weather on saturday had this thing pulling like it never has before. Was on some sticky pavement playing around doing some roll ons and was getting wheel hop. At 70.
Then it starting overheating cruising at highway speeds.
Jim K.
BOYSENBERRY!
New project
September 14th, 2015, 02:16 PM   #515
concealer404
PT Know it All
: May 2010
: Indianapolis
: 3,794
Didn't get to see you at MATG this year. I brought a 3rd different car in 3 years just to confuse you.
1988 MX6 GT $2015 Challenge Car, 1990 MX6 GT DD/$2015 Challenge Car, 1993 Escort GT Broken Forever, 1993 Miata F2T Incoming, 1998 5spd Cherokee Sport Overland, 2000 Cherokee Sport Yum! Groceries!, 2000 Miata Track car
September 14th, 2015, 07:33 PM   #516
WhiteDart
: Oct 2002
: 35
: 9,049
Yeah I was bummed I missed it. Was out of the state at the time. Did you notice the Knox Area Roadsters adopt a highway signs on the gap?
Jim K.
BOYSENBERRY!
New project
September 15th, 2015, 05:44 AM   #517
concealer404
PT Know it All
: May 2010
: Indianapolis
: 3,794
Yep i did!
October 12th, 2015, 10:24 AM   #518
j-dogg
/p/hotoPOC
: Sep 2004
: pwning the crap out of supersquid in Unreal Tournament
: 35
: 14,829
You guys do meets anymore? I might be coming through around December possibly on my way back to Missouri and wouldn't mind stopping through and telling fish stories.
PhôtôPOC(tm)
MM9 MMX FF FF2 FF3 FF4 FF5
95' base SOLD
93' PGT-ZE MS2PNP, Innovate LC2, ACT Stage II HDSS, Fidanza 9lb fw, Hotshot headers, Greddy SP2, Mazda6 BBK on EBC Yellowstuff, SS brakelines, 626 swaybar, Alpine, RPF1s
91' PLX MTX 262k. 2.5" into a Flowmaster 40
October 22nd, 2015, 09:50 AM   #519
WhiteDart
: Oct 2002
: 35
: 9,049
Im sure we can get some peeps together for an impromptu hangout. Maybe fire up the grill.
Jim K.
BOYSENBERRY!
New project
December 17th, 2015, 12:08 PM   #520
j-dogg
/p/hotoPOC
: Sep 2004
: 35
: 14,829
Been through ya'lls state a few times lol
Anyone got a black 94 gt 5 speed they dont want?
PhôtôPOC(tm)
95' base SOLD
December 18th, 2015, 07:26 AM   #521
WhiteDart
: Oct 2002
: 35
: 9,049
No but ill have two 95 rollers shortly. lol. Red, clean body, and white, some body damage.
Jim K.
BOYSENBERRY!
New project
January 6th, 2016, 07:07 PM   #522
WhiteDart
: Oct 2002
: 35
: 9,049
Small update. Orange wheels are going back on. They have been freshly repainted the original hellishly bright orange. I love the shoguns but I just cant stand the weight of them. Once I kill these tires though, I will be on the hunt for some 8 or 9 inch wide wheels. The camera cant quite handle the brightness. lol
https://www.facebook.com/photo.php?f...4&l=33376cd7f9
Got a few goodies over the past few weeks. Greddy Profec B type II EBC. Thing is pretty sweet, and actually keeps the boost even more stable than the Hallman I was running. Within three miles of driving after installation, I had both the high and low boost and gain adjusted perfectly. Dunno why some people have issues with theirs.
https://www.facebook.com/photo.php?f...3&l=a405b3454d
Also got some braided brake lines (with purple vinyl coating of course) since I know I have been pushing my luck hardcore running the original rubber lines with 310,000 miles on them. Pedal is extremely firm now. Gonna take some getting used to.
https://www.facebook.com/photo.php?f...0&l=09011a4bd2
And to top it off, I finally getted me a sticker.
https://www.facebook.com/photo.php?f...0&l=0cad626c5d
This coming weekend Ill be picking up some things. Very awesome things. 350whp will be in my grasp. Cant wait to hear those twins really singing.
Jim K.
BOYSENBERRY!
New project
May 29th, 2016, 04:37 PM   #523
j-dogg
/p/hotoPOC
: Sep 2004
: 35
: 14,829
Kinda may be going on the epic road trip of a lifetime soon and will be passing through and staying in East TN for a few days on my way up to Canada........meet and greet? I'll probably be coming up in the base model.
PhôtôPOC(tm)
95' base SOLD
May 29th, 2016, 09:02 PM   #524
WhiteDart
: Oct 2002
: 35
: 9,049
When you thinking?
Jim K.
BOYSENBERRY!
New project
May 30th, 2016, 07:25 PM   #525
j-dogg
/p/hotoPOC
: Sep 2004
: 35
: 14,829
Everything is tentative right now but ill let you guys know within a couple weeks of me coming up
PhôtôPOC(tm)
95' base SOLD
