  ProbeTalk.com Forums > General > Knowledge Base > How-To
How-To Post, read, and discuss 'How-to' guides for all years of Probes.
October 13th, 2015, 02:00 AM   #1
sbeube02
: May 2012
: France
: 31
: 245
[How To] Rear caliper rebuild
I would like to share with you my experience in rebuilding a Probe rear caliper.
I know that buying a re-manufactured caliper on Rockauto is maybe a simple option, rebuilding a caliper is often cheaper but more time consuming.
Plus it offers the ability to be painted in a professional way in any color of your choice.
The problem I encountered with my rear calipers is the famous sticky handbrake plus a strange brake fluid leak.
The tools you will need:
  • a 14 mm wrench
  • a 10 mm wrench
  • a 8 mm wrench
  • a 6 mm hex wrench
  • a 4 mm hex wrench
  • a long nose clip plier
  • a rebuild kit with the seal (eg. DORMAN D352735)
  • some copper grease
  • sand blaster
  • high temp epoxy paint
First you have to have to remove the whole assembly from the car.
Here is the rusty/dirty/leaky caliper:
Remove the first slider pin with a 10 mm spanner:
Rotate the bracket and slide from the second slider pin:
Next you have to heat a lot the bracket to get the second slider pin off. It is glued with some red Loctite:
When the glue is softened, use the 6 mm Allen wrench to remove the slider pin:
Remove now the various bolt and handbrake cable support:
Turn several turns the gear to extract the most you can the piston.
Then remove the handbrake adjust gear with a 4 mm Allen wrench:
Carefully remove the handbrake lever spring:
Slide off the piston:
Remove the dust seals and rubber guides:
Now here is the tricky part. You have to remove the small clip inside the cylinder bore:
You can now extract the handbrake adjustment mechanism:
Now the hanbrake lever may be removed, just pull off:
You can see the culprit. The old dust seal leave water pass inside the caliper:
Remove with a flat screwdriver the seal and the inner seal inside the piston bore:
Now the magical part Use a sand blaster to remove all the rust of your calipers:
If you want to paint your caliper this is the right time.
October 13th, 2015, 02:01 AM   #2
sbeube02
: May 2012
: France
: 31
: 245
This is the new seal kit with contain four seal:
Install the new seals:
Re install first the handbrake bracket followed by the adjustment mechnanism:
New boot and dust seal:
The whole re manufactured assembly:
Later, I decided to disassemble again the caliper to paint it with 2 components high temp red paint.
Picture on the car with new Brembo brake disc:
October 13th, 2015, 06:05 AM   #3
probe,man
: Sep 2014
: Yadkinville, NC
: 136
clean looking probe. did the SE and base models have drum or disc brakes?
95' pgt stock, black with sunrooof.
October 13th, 2015, 08:00 AM   #4
sbeube02
: May 2012
: France
: 31
: 245
In Europe we only have the 16v model and 24v model. They share the same brake disc.
October 13th, 2015, 09:03 AM   #5
probe,man
: Sep 2014
: Yadkinville, NC
: 136
but American made had drums?
thread
Rear caliper rebuild (Write-up) bxstang2000 2nd Gen (93-97) V6 2.5L 0 March 15th, 2009 07:18 PM
Seized caliper - rebuild or replace? zimm0who0net 1st Gen (89-92) All 7 May 31st, 2005 09:46 AM
Caliper Woes...(rebuild help) 3.0 1st Gen (89-92) All 0 August 19th, 2004 02:33 PM
Caliper rebuild\paint Nivram 2nd Gen (93-97) V6 2.5L 4 October 17th, 2003 12:00 PM
