| 2nd Gen (93-97) V6 2.5L Archive Quality Archived Posts and FAQs |
Thread Tools |
#1 |
Noclss write-up: OBD-1 codes and OBD-2 codes
I was reading that MC Spada wanted to make up a post for all the codes so everybody can see what codes are what.
Since I'm bored, figured I'd take it upon myself to do it. These are taken directly from the Haynes Manual and a couple from "mike's PGT site" at http://homepage.ntlworld.com/mx6-uk/malf/malfcode.htm The OBD-1 computer system was used in the 93-95 Probes. To check for OBD-1 codes, use a paperclip and insert it into the 10 and ground pins in the diagnostics box under the hood by the battery. please make sure the car is turned off OBD-1 02- crankshaft position (ckp) sensor or circuit 03- camshaft position (cmp) sensor or circuit 04- camshaft/crankshaft position sensor or circuit 05- knock sensor 08- Mass Airflow (maf) sensor or circuit 09- coolant temperature sensor or circuit 10- Intake air temperature sensor (IAT) 11- Intake air temperature (IAT) sensor or circuit 12- Throttle Position sensor (TPS) or circuit 14- Barometric Pressure Sensor 15- Oxygen sensor or circuit 16- EGR valve position sensor or circuit 17- Oxygen sensor (check the fuel and ignition system performance) 23- Rear 02 sensor inactivation error 24- Rear 02 sensor inversion error 25- Fuel Pressure Regulator Control Solenoid or circuit 26- Solenoid valve(purge control) or circuit 28- EGR vaccum solenoid 29- EGR solenoid vent or circuit 34- Idle Air Control(IAC) valve or circuit 41- VRIS #1 solenoid 46- VRIS #2 solenoid 67- Cooling fan relay or circuit 69- ECTF sensor 111- System pass 112,113- Intake Air Temperature(IAT) sensor or circuit 116,117,118- Engine Coolant Temperature(ECT) sensor or circuit 121,122,123- Throttle Position Sensor(TPS) or circuit 157,158,159- Mass Air Flow(MAF) sensor or circuit 172,173,179,181- Heated oxygen sensor(H02S) or circuit 211,212,213- Ignition system 214,244- Camshaft position(CMP) sensor or circuit 327,332,337- EGR function sensor or circuit 411,412- Idle Air Control(IAC) valve or circuit 452- Vehicle Speed Sensor(VSS) or circuit 511,512,513- PCM 519,521- Power Steering Pressure(PSP) switch or circuit 522- Transmission range sensor or circuit 536- Brake On/Off (BOO) switch or circuit 538- Dynamic response test 539- a/c sensor or circuit 554- Pressure regulator solenoid valve or circuit 559- a/c relay or circuit 563- cooling fan relay(high speed) or circuit 564- cooling fan relay(low speed) or circuit 565- Purge control solenoid valve or circuit 571- EGR solenoid valve(vent) or circuit 572- EGR solenoid valve(vaccum) or circuit 998- PCM
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I'll kiss you right on the mouth, Kenny Rogers. PhotoPOC DaddyPOC Last edited by noclss2000; February 17th, 2006 at 09:50 PM. |
#2 |
The bad thing about the 96-97 probes is they use the OBD-2 system which requires a code reading tool, or you can go to your local autozone and they can diagnose it for free.
OBD-2 codes P0100,P0102,P0103- Mass Airflow(MAF) sensor or circuit fault P0110,P0112,P0113- Inlet Air Temperature(IAT) sensor or circuit fault P0115,P0117,P0118- Engine Coolant Temp.(ECT) sensor or circuit fault P0120,P0122,P0123- Throttle Position Sensor(TPS) or circuit fault P0125- Excessive time to enter closed loop P0130,P0131,P0150- Heated 02 sensor or circuit fault P0133,P0134,P0140- Heated 02 sensor slow response P0154,P0160- Heated 02 sensor slow response P0135,P0141, P0155- Heated 02 sensor heater or circuit fault P0170,P0171- fuel system too lean P0172,P0173- fuel system too rich P0230, P0231, P0232- fuel pump circuit fault P0300- Random misfire detected P0301- Cylinder number 1 misfire detected P0302- Cylinder number 2 misfire detected P0303- Cylinder number 3 misfire detected P0304- Cylinder number 4 misfire detected P0305- Cylinder number 5 misfire detected P0306- Cylinder number 6 misfire detected P0320- Ignition input circuit fault P0335- Crankshaft position sensor or circuit fault P0340- Camshaft position sensor or circuit fault P0400- EGR flow fault P0420,P0430- Catalyst system efficiency below threshold P0440- EVAP system fault P0443- EVAP purge solenoid or circuit fault P0500, P0503- Vehicle Speed Sensor(VSS) or circuit fault P0505- Idle Air Control(IAC) valve system fault P0510- Idle Switch fault P0552,P0553- Power Steering Pressure(PSP) switch or circuit fault P0603- ECM Keep Alive Memory test error P0605- ECM Read Only Memory test error P0703- Brake On/Off(BOO) switch or circuit fault P0704- Clutch pedal position switch or circuit fault P0705- Transmission range sensor or circuit fault P0710 through P0760- Electronic transmission control system fault
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I'll kiss you right on the mouth, Kenny Rogers. PhotoPOC DaddyPOC |
#3 |
ProbeTalk MC
i swear to God if anyone asks what a code is now, they are seriously done for.
ya never know the capabilities of newbies
1994 Probe GT Megasquirted ZE - 183.7whp/167.2wtrq on 87 octane 1995 Ford Probe GT - bone stock 2005 Saab 9-2x Linear... grocery getter 2008 Ford Fusion SEL 32mpg Company car. |
#4 |
Incredibly nice write up Dan!!
Dave Co-founder of KYPO 1994 Probe SE Sold / 1993 Probe GT Sold / 1994 Probe GT Sold To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. / 95 Lexus SC300 Sold 2003 Subura Impreza WRX My new project To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
PT Guru
Location: somewhere trying to get my truck stuck in the mud
there is over 3000 OBDII codes the info you posted is not always true about OBDII codes
click here for OBDII stuff
2004 EDGE reg cab oxford white |
#6 |
Official PT DOM!
This is my list of Mazda complaint OBDII codes. Part 1
----------------------------------------------------------- P1000 OBD II Monitor Testing Not Completed P1001 Unable to Achieve Self-Test Function or SCP Error P1100 Mass Airflow Sensor Circuit Intermittent P1101 Mass Airflow Sensor Circuit out of Self-Test Range P1102 Mass Airflow Sensor Signal Inconsistent with Throttle Position Sensor P1103 Mass Airflow Sensor Signal Inconsistent with Engine Speed P1110 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit P1112 Intake Air Temperature Sensor Circuit Intermittent P1113 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit P1114 Intake Air Temperature Sensor Circuit Low Input P1116 ECT Sensor Circuit Out of Self Test Range P1117 ECT Sensor Signal Intermittent P1120 Throttle Position Sensor out of Range Low P1121 Throttle Position Sensor Signal Not Consistent with Mass Airflow Signal P1122 Throttle Position Stuck Closed P1123 Throttle Position Stuck Open P1124 Throttle Position Sensor Signal Out of Self Test Range P1125 Throttle Position Sensor Signal Intermittent P1127 HO2S Bank 1 Sensor 2 Heater Not On During Key On Engine Running Self Test P1128 HO2S Bank 1 Sensor 1 Signals Swapped in Key On Engine Running Self Test P1130 HO2S Bank 1 Sensor 1 Not Switching (Fuel Control Limit Reached) P1131 HO2S Bank 1 Sensor 1 Signal Below 0.45v (A/F Ratio Too Lean) P1132 HO2S Bank 1 Sensor 1 Signal Above 0.45v (A/F Ratio Too Rich) P1135 HO2S Bank 1 Sensor 1 Heater Circuit Low Input P1136 HO2S Bank 1 Sensor 1 Heater Circuit High Input P1137 HO2S Bank 1 Sensor 2 Not Switching (Fuel Control Limit Reached) P1138 HO2S Bank 1 Sensor 2 Signal Above 0.45v (A/F Ratio Too Rich) P1141 HO2S Bank 1 Sensor 2 Heater Circuit Low Input P1142 HO2S Bank 1 Sensor 2 Heater Circuit High Input P1143 HO2S Bank 1 Sensor 3 Signal Below 0.45v (A/F Ratio Too Lean) P1144 HO2S Bank 1 Sensor 3 Signal Above 0.45v (A/F Ratio Too Rich) P1150 HO2S Bank 2 Sensor 1 Not Switching (Fuel Control Limit Reached) P1151 HO2S Bank 2 Sensor 1 Signal Below 0.45v (A/F Ratio Too Lean) P1152 HO2S Bank 2 Sensor 1 Signal Above 0.45v (A/F Ratio Too Rich) P1169 HO2S Bank 1 Sensor 1 Circuit Fixed (Bank 1 Sensor 1) P1170 HO2S Bank 1 Sensor 1 Circuit Fixed (Bank 1 Sensor 1) P1173 HO2S Bank 2 Sensor 1 Circuit Fixed (Bank 2 Sensor 1) P1195 EGR Boost Sensor Circuit P1196 Ignition Switch Start Circuit P1235 Fuel Pump Control Circuit P1236 Fuel Pump Control Out Range P1250 Pressure Regulator Control Solenoid Circuit P1252 Pressure Regulator Control Solenoid '2' Circuit P1260 Anti-Theft System Signal Detected - Engine Disabled P1270 Engine RPM or Vehicle Speed Limit Reached P1309 Misfire Detection Monitor P1345 No CMP or SGC Signal P1351 Ignition Diagnostic Monitor Signal Lost to PCM or Out Of Range P1352 Ignition Coil 'A' Primary Circuit P1353 Ignition Coil 'B' Primary Circuit P1354 Ignition Coil 'C' Primary Circuit P1358 Ignition Diagnostic Monitor Signal Out Of Self Test Range P1359 SPOUT Signal Lost To Powertrain Control Module Or Out Of Range P1360 Ignition Coil 'A' Secondary Circuit P1361 Ignition Coil 'B' Secondary Circuit P1362 Ignition Coil 'C' Secondary Circuit P1364 Ignition Coil Primary Circuit P1365 Ignition Coil Secondary Circuit P1390 Octane Adjust Shorting Bar Out or Circuit Open P1400 DPFE Sensor Circuit Low Input P1401 DPFE Sensor Circuit High Input P1402 EGR Valve Position Sensor Circuit P1405 DPFE Sensor Upstream Hose Off Or Plugged P1406 DPFE Sensor Downstream Hose Off or Plugged P1407 No EGR Flow Detected P1408 EGR System Flow Out of Key On Engine Running Self Test Range P1409 EGR Vacuum Regulator Solenoid Circuit P1410 EGR Boost Solenoid Valve Stuck P1443 EVAP System Purge Flow Fault P1444 EVAP Purge Flow Sensor Circuit Low Voltage P1446 EVAP Purge Flow Sensor Circuit High Voltage P1449 CDCV or Throttle PositionCV Circuit P1450 EVAP Control System Fault P1451 Canister Vent Solenoid Circuit P1455 Fuel Tank Level Sensor Circuit P1460 Wide Open Throttle A/C Cut-Off Relay Circuit P1464 Air Conditioning Control Signal Circuit P1474 Fan Control (Primary Winding) Circuit
Rick_96PGT™ #62 "I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson |
#7 |
Official PT DOM!
Part 2
------------------------------------ P1479 Fan Control (Condenser Primary) Circuit P1485 EGR Vacuum Solenoid Circuit P1486 EGR Vent Solenoid Circuit P1487 EGR-CHK (Boost) Solenoid Circuit P1496 EGR Valve Motor Coil '1' Open or Shorted P1497 EGR Valve Motor Coil '2' Open or Shorted P1498 EGR Valve Motor Coil '3 Open or Shorted P1499 EGR Valve Motor Coil '4' Open or Shorted P1500 Vehicle Speed Sensor Intermittent Signal P1501 Vehicle Speed Sensor Out of Self Test Range P1502 Vehicle Speed Sensor Circuit Error P1504 Idle Air Control Solenoid Circuit Intermittent P1505 Idle Air Control System at Adaptive Clip P1506 Idle Air Control System Overspeed Detected P1507 Idle Air Control System Underspeed Detected P1508 Bypass Air Solenoid '1' Circuit P1509 Bypass Air Solenoid '2 Circuit P1512 VTCS Fault P1521 VRIS Solenoid '1' Circuit P1522 VRIS Solenoid '2 Circuit P1523 VICS Solenoid Circuit P1524 Charge Air Cooler Bypass Solenoid Circuit P1525 ABV Vacuum Solenoid Circuit P1526 ABV Vent Solenoid Circuit P1529 L/C Atmospheric Balance Air Control Valve Circuit P1540 ABV System Fault P1562 Powertrain Control Module +BB Voltage Low P1569 VTCS Circuit Low Input P1570 VTCS Circuit High Input P1601 Powertrain Control Module Communication Line to TCM Error P1602 Powertrain Control Module Communication Line to TCM Error P1602 Immobilizer System Communication Error with Powertrain Control Module P1603 Immobilizer System Fault P1604 Immobilizer System Fault P1605 Powertrain Control Module Keep Alive Memory Test Error P1608 Powertrain Control Module (ECM CPU) DTC Test Fault P1609 Powertrain Control Module (ECM CPU) Knock Sensor Circuit P1621 lmmobilizer System Fault P1622 lmmobilizer System Fault P1623 lmmobilizer System Fault P1624 lmmobilizer System Fault P1627 Powertrain Control Module (ECM/TCS) Line Communication Error P1628 Powertrain Control Module (ECM/TCS) Any Line Communication Error P1631 Generator Output Voltage Signal (No Output) P1632 Battery Voltage Monitor Circuit P1633 Battery Overcharge Fault P1634 Generator Terminal 'B' Circuit Open P1650 Power Steering Pressure Switch Out of Range Fault P1651 Power Steering Pressure Switch Circuit P1652 Power Steering Pressure Switch Circuit P1701 Transmission Range Sensor Reverse Engagement Error P1702 Transmission Range Sensor Circuit Intermittent P1703 Brake On/Off Switch Out of Self Test Range P1705 Transmission Range Sensor out of Self Test Range P1709 Clutch Pedal Position Switch Circuit P1711 Transmission Fluid Temperature Sensor Circuit out of Self Test Range P1713 Transmission Fluid Temperature Sensor Circuit P1714 Shift Solenoid '1' Mechanical Fault P1715 Shift Solenoid '2' Mechanical Fault P1716 Shift Solenoid '3' Mechanical Fault P1717 Shift Solenoid '4' Mechanical Fault P1718 Transmission Fluid Temperature Sensor Circuit P1720 Vehicle Speed Sensor '2' Signal Error P1729 Transmission 4x4 Low Switch Error P1740 Torque Converter Clutch Solenoid Mechanical Fault P1741 Torque Converter Clutch Control Electrical Fault P1742 Torque Converter Clutch Solenoid Shorted P1743 Torque Converter Clutch Failed On - TCIL is On P1744 Torque Converter Clutch Solenoid Mechanical Fault P1746 Electronic Pressure Control Solenoid Circuit Open P1747 Electronic Pressure Control Solenoid Circuit P1749 Electronic Pressure Control Solenoid Circuit Low P1751 Transmission Shift Solenoid 'A' Mechanical Fault P1752 Transmission Shift Solenoid 'A' Circuit Shorted P1754 Transmission Coast Clutch Solenoid Electrical Fault P1756 Transmission Shift Solenoid 'B' Mechanical Fault P1757 Transmission Shift Solenoid 'B' Circuit Shorted P1761 Transmission Shift Solenoid '3' Mechanical Fault P1762 Transmission SS3/SS4/OD Band Fault P1765 Transmission 3-2 Timing Solenoid Valve P1767 Torque Converter Clutch Solenoid Circuit P1771 Throttle Position Sensor Circuit Open to Transmission Control Module P1772 Throttle Position Sensor Circuit Shorted to Transmission Control Module P1780 Transmission Control Switch Circuit P1780 Overdrive Off Switch not Cycled during the Self Test P1781 Transmission 4x4 Low Switch out of Range Fault P1783 Transmission Fluid Temperature High Input P1788 3-2T/CCS Circuit Open P1789 3-2T/CCS Circuit Shorted P1794 Powertrain Control Module Battery Direct Power Circuit P1797 P/N Switch Open or Short Circuit P1900 Turbine Speed Sensor Circuit Intermittent P1901 Torque Converter Clutch Circuit Intermittent The end
#8 |
Official PT DOM!
Remember, not all codes in this list apply to 96-97 OBDII Probes/Mazdas. Some of these codes are for current model years as well.
Enjoy.
#9 | |
Official PT DOM!
Its also where I got my list.
#10 |
thanx rick.
#11 |
Official PT DOM!
Here is a link to the Mazda OBDII list in .pdb and .txt format. I abstracted all the codes and meanings from the .pdb file to the .txt file for simple reading, editing and or importing of the file.
Right Click and save as mazda.pdb Right Click and save as mazda-OBDII.txt
#12 |
differences
Hey,
I have a list from Autozone and there are differences in the list. I didn't go through the whole thing for OBD II but code P1170 on my list says: Engine shut off solenoid fault. So which on is it...O2 sensor fault? or Engine shut off solenoid fault. So if you had code P1170 what would you do? And what the hell is an Engine shut off solenoid switch... One of those things that have the Mitsubishi symbols on it? |
#13 |
How bout code 41 ... I think it's vris solenoid #1, but I'm not sure
#14 | |
Official PT DOM!
#15 | |
Official PT DOM!
Re: differences
#16 |
I also saw that 41 was the VRIS Solenoid #1, I was looking recently b/c I got the same code. I will post this question in maintanence, but anyone know how to/how difficult it is to replace that? The web site where I saw the code said it affects torque at 3250 RPM.
'95 MX-6 LS, 5-speed, Ram air intake, Pacesetter cat-back, Tokiko Illumina struts/springs, front/rear strut tower bars, CM stage I, SS clutch line, MX3 lightened flywheel, RR Racing motor mounts and shifter bushing, polyurethane CA bushings, UOR pulley, B&M shifter, KVR rotors/pads, PTRASB, I wish I had headers... |
#17 |
Kevin B - Former Probe-owner To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#18 | |
Re: Noclss write-up: OBD-1 codes and OBD-2 codes
i have 95 GT and im trying to pull the code.. this is the only thread i can find with good instructions and i still have NO IDEA what your talking about... insert a paperclip in a 10?? whats that?? and were are these ground pins at that i plug into the diagnostic box??? speak with a little more thought that there is MORE THEN JUST GUYS ON THIS FORUM!! thanx for letting me vent... Tessa
Tessa 93 Super Grape MX6 LS Blitz Kit To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#19 |
I can't get too much more detailed that what I did.
Under your hood behind your battery there is a 1" by 1" black box that says "diagnostics" on it. You open that up and there are female connectors as if you were to plug a computer to it. On the inside of the diagnostics lid there is a diagram that tells you what pins of these connections are what. One of these pins is called "10" and another is "grnd" these are the two you need to connect the paperclip to.
#20 |
ight .... the check engine light is sapposed to blink right? mine just blinked a bunch... and wouldnt stop.. is this bad?? how do i know what its saying... now if you could explain a little more on how to describe the blinks other then flashes... does the first blink count?? if so then it started with a long flash and then 3 short but it looks like when its done with the codes it goes back through and then the first one would only be 3 short..then then next were.. a long flash and 5 short and a long and 6 short, a long and 7 short. then it proceeded to do 2 long and 3 short... 2 long and 4 short. and then it went back to the begining.. . those are alot of codes im thinkin
#21 | |
so if you read it correctly it would read codes: 13 15 16 17 23 24 may want to reset the computer by disconnecting the negative battery terminal and applying the brake for 10 seconds because I'm showing there is no code 13 but the rest seem to be pointing to o2 sensors and 17 is the egr. reset the computer and read it again, some may disappear.
#22 |
Kiwi parts bin special, what pin do I use?
Well, its Saturday morning so I go out to the PGT armed with a paperclip and high hopes to see if I can sort out the "check engine" light which comes on occasionally.
Now the car is registered as a 96 PGT, but it was initially exported to Japan before being re-exported to New Zealand. I checked the VIN against the Ford VIN decoder on http://www.geocities.com/ponch8725/fordvin.htm VIN 1ZVLT22B755xxxxxx says its a USA/Ford Probe/Probe Passenger/belts and airbags/Import/Probe 2 door hatchback GT/V6 2.5L/1995/Flat Rock. Ok, so the car might have been shipped from Flat Rock late '95 and arrived and was first registered in Japan early in '96 - I can live with that. But in the little black box marked "diagnosis" are all these pins and I'm looking for pin "10". Only trouble is the pins are identified by 3 letter codes in the black box cap. Across the top row are pins "FEN" "MAN" gap "TEN" and "+B". Next row is "GRND" "FAT" "FBS" "FVS" and "FSC. Down the bottom of the black box cap, under another double row of pins, is a code "H381". I've got a couple of questions: Am I looking for pin "TEN" to connect to "GRND" or should the pins be identified numerically, i.e. "9" "10" "11"? Have I got a PGT made in 95 with a 96 diagnosis (OBD-2) system? Can I identify the diagnosis system from the engine number, and where is that? |
#23 |
10 was meant like TEN (Test ENgine). Please check here : http://home.golden.net/~trinity/
#24 |
Heres a good question......
I have a Late Build 97 GT. WHen I open the lid on the diagnostic box, there is NO diagram of what pins are what.
I am trying to set the TPS,,,,,,,,How do I know what Pins are the TEN and the Grnd????????? So I went to Rick 96's page and saw his Picture of the Diagnostic box for a 96 gt. Mine is Completely different. I have female connectors in all different positions than his. Whats the deal? Where is the Grnd and TEN Pin? I have no clue where to look. Anyone have a clue?????????????
97 GT, MTX, GReddy, MX3 Flywheel, Clutchmasters Clutch, Phenolic Spacers, Bored TB, Home Depot Racing CAI, AWR Motor Mounts, Short Throw Shifter, H4 Conversion, PIAA Fogs, Tokico's/Eibachs, Probetalk Sway Bar, Beautiful FACTORY Paint! |
#25 |
my cel used to stay on so i got code 24 and i changed my rear sensor near the firewall. now after its changed the check engine turns on and off constantly. i disconnected my battery to try to reset my computer but nothing still turns on and off when it wants to. it tends to turn off when i hit the gas and turn on when i let go of the gas. some days it even stays on for a long time then turns off. i know its the right sensor(bosch sensor universal) but why is it doing, i even checked my wires they are all connected properly, why is this happening please help!!!!!!
| Thread Tools | |
