| Register | FAQ | Members List | Timeslips | Calendar | Arcade | iTrader | Mark Forums Read |
Thread Tools |
#1 |
:sigh:
Rear Motor Mount removal/installation write-up, with pics!
Ok, first lemme say that this is a REAL PITFA especially if you are a larger person, or have large arms. My rear MM was toast! I had engine rock while in 5th gear http://images.cardomain.com/member_i...71_51_full.jpg http://images.cardomain.com/member_i...71_52_full.jpg http://images.cardomain.com/member_i...71_53_full.jpg TOOLS NEEDED: Jack----floor jack will work, but you’ll need something to put on top of it to jack against the tranny with, a short 2X4 will work for this. I used a bottle jack. ½” ratchet 3/8” ratchet 17mm socket, ½” drive 24-32” + of ½” extension (adds 10x the ease to the job 10mm deep well 3/8 drive socket Jack stands ½” universal (yet another tool that will make this job a lot easier) SUPLIES NEEDED: A LOT of chill pills Step #1 Jack up the car and support with the jack stands. Remove the CAI From the TB forward. Those with Cruise may have to remove the cruise control cable. Step#2 Remove the drivers side splash shield. Take the bottle jack and jack up the tranny enough to alleviate the pressure on the front Motor Mount. (yet another small side job that takes 5 min and in all makes the job easier and shorter to do). Step#3 Now here is a little trick I learned while doing this job. Take the 24-32” of extensions, put the 17mm socket on the end of them, and insert them through the pass side wheel @ about 9 O’clock on the wheel. Look through the wheel and guide the socket in and put it on the MM through bolt (one that goes through the MM). Now while watching the bolt/nut from the pass side (it can be seen while standing up and looking behind the intake from the pass side of the car.) loosen the nut up. http://images.cardomain.com/member_i...71_54_full.jpg http://images.cardomain.com/member_i...71_55_full.jpg Step#4 Take the 10mm deep well socket and the 3/8’s ratchet and remove the 2 nuts that hold the electrical wiring to the firewall. Once removed, pull the wiring off the bolts and push it forward. (kind of a PITA to do). http://images.cardomain.com/member_i...71_56_full.jpg http://images.cardomain.com/member_i...71_57_full.jpg Step#5 Take the jack and put it under the rear of the tranny, and put some up pressure on the tranny to hold it in place as you remove the MM nuts/bolt. http://images.cardomain.com/member_i...71_58_full.jpg Step#6 Take the ½” universal and the 17mm socket and pull the nuts (2) and the bolt that hold the MM down to the sub frame. http://images.cardomain.com/member_i...71_59_full.jpg Step#7 As you can see once the MM through bolt’s nut has been removed along with the MM mounting nuts/bolt, the through bolt can’t be removed. As it will hit the P/S line. Simple fix. Take the jack and jack the engine/tranny up a little until the bolt will clear the line. Finally remove the though bolt. http://images.cardomain.com/member_i...71_60_full.jpg Step#8 The fun/hated/PITA step. Now with as much patience and as many valium as you have, remove the rear MM. I spent about an hour turning/twisting and just plain trying to force the *******er out of there. Step#9 Replace the old MM, or install the inserts. Step#10 Follow the above steps in reverse order and put it all back together. Enjoy! ~Aaron
~Aaron~ |
#2 |
Here is another *unofficial* Probetalk member of the month award. I'd say you have a good shot at the *unofficial* Probetalk member of the year award as well. VERY NICE WORK! |
#3 |
As said above, u really deserve that award. Since that MM thread which was open last month, i knew u were going to hit this subject
Rio Red 94PGT, T3T4E 50 trim @ 7.5psi 257whp & 245wtq on Mustang Dyno with a ported T3 60 trim @ 8.7psi ,,, oh and I swap engines every other oil change Pearl White 91 infiniti M30 Coupe-The back up car and future project (5-spd & turbo). |
#4 |
'nuff said.
94 PGT MTX/Borla Cat-back/Kumho 712s/PIAA 1400XP/PRM CAI/Remote starter/RR-Racing Motor Mount Inserts http://sirk.sytes.net |
#6 |
I have had the rear mm out of my 93gt mtx to put in the RR-Racing inserts. It turnd out that I had a diferent mount
Nice right up Matt P.S. I have the front insert in and I love it.
R.I.P. Roy W Clark You will be missed. 06 subaru Impreza 2.5i siting on cobs "Sir, you got crack paraphenalia in your spagetti noodles" myspace.com/thebigsmarty Originally Posted by 04.SPT.WRX ... ride cushioned by a load of poo ... |
#7 |
good write up
1993 ford probe GT KLZE with some other stuff......SOLD 9/16/2003 |
#8 |
Six Star Member
at least your write up has pictures in it. i didn't have a digital camera when i did my write up.
-Jay ASE Master Certified ASE L1 Advanced Engine Performance Specialist THE RACECAR daily - '95 PGT mtx stock HOW TO TEST YOUR VRIS |
#9 |
perfect timing, i was planning on putting in my rear inserts this weekend. i finally found a compatiable mount. mine is the right kind, just looks kinda whipped out. you saved me from a lot of extra work. thanks
matt
'01 Silverado 1500: Wait4me tune, Gibson catback, Detroit Truetrac locker, 4:10s, K&N intake, 2" lift, 33" tires, Escalade gauge cluster, Pioneer DVD, Pilot HIDs '05 Honda Superhawk: 996cc v-twin, Jardine dual exhaust, Dynojet, K&N, Pilot Power 2CTs and more. '04 Cannondale Scalpel: noisy race bike |
#10 |
Wow an hour of turning and twisting to get the mount out!! Mine must have gone pretty easy. It slid right out. I didn't have to jack the tranny up. I put the inserts in the front, then did the rear. The other three support the engine and tranny pretty well.
FYI, the 93 mount is diffrent than 94 on. The poly inserts are made for the 94 on. I had to replace my rear mount to get the inserts to fit. I was able to reach everything from the top, didn't need to go in the sides. PS, Hood removal is nearly a must! Saves time and frustration! Over all, Nice job Silver. What is your Email, I have a picture of the two mounts side by side if you want to post it as well.
Bill Pendleton, 96 MX-6 M, Black, tan leather, t304E turbo, MSnS extra, FMIC, front and rear cross drilled slotted rotors, front and rear strut tower braces, Centerforce DF clutch, high flow cat, Dropzone springs, 18" RX8 wheels. 13.49 1/4 @110.7 mph on 10 psi 2003 Altima 3.5 SE, lots of mod that you don't care about cus it's a Nissan. 97 Millenia S, all stock |
#11 | |
No longer a PT'er since I have not even a single Probe part left in the garage. Thanks for all the good times Probetalk. |
#12 |
Sure, I've been on this board for two years and now I learn I can upload images!
I don't feal so smart........ http://pt.zkiller.de/uploads/Engine_Mount.JPG
#13 |
Too bad, if you would have searched the list back to last May, when I did mine exactly like this, you could have finished it even quicker!!
IIRC, Halfriceboy did his write up on this job back then. He took the IM off, this way doesn't need that done- a major time saver. |
#14 | |
Six Star Member
#15 | |
:sigh:
However, many people asked me to do one with pics, so I did. Use whichever you choose, I just figured I'd write-up one with pics to help in the prrocedure. ~Aaron
~Aaron~ |
#16 |
That's more than likely why mine came out with such ease..... I had my IM off as well.
Still a very good write up. "A picture is worth a thousand words"
#17 |
This write up ROCKS. Luckily I won't have to go through the bottom as I'll be replacing vcg's at the same time I do the rear mount (thank god) so I'll go in from the top.
Hats off to a great tutorial!
Silver 93PGT -- 97PGTS Motor Phenolic IM Spacers, Coned TB, Custom CAI, K&N, Catco Cat & Magnaflow Muffler. For Sale: 93 Throttle Position Sensor / 93 Intake Manifold (with VRIS butterflies) PM/Email me for details! |
#18 |
I've just removed my whole turbo system and wrapped the pipes and turbo, installed the Pheno Race kit studs, and changed both exhaust manifolds, and now am moving on to installing my RR Racing rear motor mount. Thanks for a great writeup.
Lee Hubanks As a political discussion grows longer, the probability of a comparison involving Hitler or the Nazis approaches 1. http://members.cardomain.com/ntruder95 |
#19 |
btw, step 8 is about 100000 times easier if the IM is off.
#21 | |
:sigh:
Oops, sorry people, I forgot that these pics were uploaded with zkiller's uploader, and since it is down well....... I'm uploading them to Cardomian as i type this. ~Aaron
~Aaron~ |
#22 |
Just finished doing mine. The fronts are easy but the rears...They are a major PITA if you are lazy and dont want to remove everything under the motor(like me). I did a few things different.
1. I didnt remove the rear mount. I just removed the shield part and let it sit on the steering rack. 2. Lubed up the insert and slipped it in while the mount was attached to the firewall(or whatever it was attached to). Then replaced the shield part, put the through bolt to hold the shield in place. Then went on to struggling with the 3 other mount bolts. Snugged everthing down after all the hard stuff was done. 3. Removing the shifter arm at the tranny gave me enough room to wiggle everything together.(that plus a lot of swearing) Removing the shifter arm exposed the fact that i no longer have any semblence of a bushing in there, it is just wiggling aroung like mad! And now i am mad, another stupid thing to fix(that plus the ripped CV joint boot that i also found) I have kind skinny arms so i could fit in the tight confines, and i have the cuts all over my arms to prove how tight it was. All you other bodybuilder types will be out of luck here. 4. I know it probably would have been easier if i removed the mount from the car, but for the life of me i couldnt see where it was bolted on Driving impressions: You need to slip the clutch and rev a little more off idle or the vibration will rattle the crappy ford plastic interior bits. There is a little more vibration at cold start and everyday type driving but it is not too bad. Shifting...i cant really say since i dont seem to have a shifter bushing right now. But i will try Home Depot to see if i can find some kind of nylon bushing that will fit the arm and some kind of sleeve that will keep the bolt thread from eating up the plastic bushing again. Oh well, it just never seems to end....
Black 95PGT~~~Borla/JJ testpipe/Fidanza/CM stageIII/Redline MT-90/RR-racing inserts/PRD RSB-99, STS-99/ebay CAI/Outlaw engineering race kit/PRD plug wires/MSD 6AL/Blaster 3/warbro 255hp/Goodridge braided/eibach/illuminas/PT 17.5mm swaybar/Razo SS mesh/Ti plate pedal kit |
#23 |
If your just putting in inserts there should be no need to get the mount all the way out. Just take the two bolts and one nut off that hold the mount. They are just behind it, between the fire wall and mount. With those off you can pull the mount up a little to squeeze in the inserts. I removed mine becouse I replace the mount as well.
As for the vibrations. Don't worry to much about it, it softens up. Mine doesn't vibrate anymore. Had the inserts in for about 6-8 months. Either I got used to it, or it went away.
#25 | |
00 Silver Mustang GT - Not Stock, 60k miles. Stock Dyno - 222rwhp 256rwtq. 93 Black PGT MTX Codename: "Skunky" - 219k miles, White GTS Stripes, KLZE engine, 40k mile trans, Hotshot Headers, Random Tech High-Flow Cat, Hotshot Cold Air Intake, RR-Racing STS, RR Racing Poly Front Mount and Shift Stabilizer Arm Bushings, etc. etc. 95 Black PGT ATX - Stock, 85k miles, gone./95 Black PGT MTX - Shell, going |
| Thread Tools | |
