Your Ad Here
Go Back   ProbeTalk.com Forums > Tech Section > 2nd Gen (93-97) V6 2.5L > 2nd Gen (93-97) V6 2.5L Archive
2nd Gen (93-97) V6 2.5L Archive Quality Archived Posts and FAQs
Old March 6th, 2007, 01:30 AM   #151
craptastic93
according to http://img64.imageshack.us/img64/8545/HEI.jpg link, where the heck does G go if i terminate 5 and 6. The way i wired it from the project mazda site i have G tapped into #6 with nothing cut/terminated nor anything with the internals of the distributor messed at all. Then again i have a 93, but from reading way too many pages of this thread it seemed 93-94 were very similar and 95 on is where differences occur. I guess i might as well go for the external coil Mod if i am going to be taking the intake and dist. cap off again and before the ignitor bites it anyways. so i planned to folllow the directions from the Project Mazda site for the external coil too but since the HEI diagram there is diff from the one here, is there something more clear then the kiddie artwork thats on that site that works for a 93.
Basically here's what i have,
-sanded the area immediately behind the drivers headlight to metal and mounted the HEI mod there with the gooo on the back....did not use bracket, just directly to sanded metal frame...is this going to screw me up?
-W and the screw hole are grounded at the same point right by the battery ground but not the exact nut as the battery ground by diagnostics box
-My G tapped into the wire of the 6 wire harness that is closest to firewall when connected.
-My C tapped into wire of 3 wire harness that is farthest from friewall when connected
-And my B to the wire closest to firewall of 3 wire harness.
-internals and cap of dist. left untouched
so where have i gone wrong in the above steps other then the mentioned confusion about the G should be wired?
craptastic93 is offline
Old March 6th, 2007, 10:11 AM   #152
KevinD
Moderator
KevinD's Avatar
Originally Posted by craptastic93
... i have G tapped into #6 with nothing cut/terminated nor anything with the internals of the distributor messed at all.
You either need to cut the Blue/Orange (#6) wire and run it to the HEI G (this is the trigger pulse from the PCM), or completely remove the ICM (ignitor) inside the distributor.
You didn't need to sand off the paint, just make sure the mounting holes in the HEI are grounded. And use a thin film of the "goo", or it'll do more harm than good.
Any ground will do; try to use a screw into the body close to the HEI module.
That should be the Blue with Orange stripe wire.
Terminal C to the Yellow with Green stripe wire, terminal B to the Black with Pink stripe wire.
As mentioned, you either need to cut both wires #5 & #6 on C134 (6-pin connector), or remove the strap inside the distributor and cut wire #6.
KevinD
1995 Sapphire Blue Mustang GT Convertible, 2006 Storm Red Metallic Mercedes-Benz CLK 350 Cabriolet, 2006 Dark Shadow Gray Ford F250 V10 Supercab 4x4, 2003 San Marino Red Acura CL Type S, 2002 Burgundy Pearl Suzuki XL-7 Touring, 1971 Spring Green Jeep J4000 Gladiator, 1966 Signal Flare Red Ford Fairlane, to name a few...
KevinD is offline
Old March 6th, 2007, 12:30 PM   #153
craptastic93
thanks for the clearest and most informative post of this thread so far Kevin. I gave wires by location instead of color scheme because first off the 1993 probe has a 626 motor in it, i dont know from what year but yes i know they are the same i just dont know what of the parts under the hood are actually probe or 626 so didnt know if the wire colors are like they should be for a 93....and 2...they are so faded its extremely hard to tell actual colors so i decided to go by wire location....i.e. closest to firewall/farthers from firewall and etc.
after snipping the metal band near the 3 wire plug do i need to do anything with the remainder of it....i removed the part screwed in but the part coming from the harness, does it need to be touched up with anything or just leave it after its been snipped....im doing this mod as i type on thuis forum in case i **** up too bad....thanks everyone.
both...or i thought just grounding the one along with W was fine....im just trying to do this right the first time before piecing it together to find out wires need to be switched or grounds were incorrect. thanks all
heres what i got so far...let me know where i have gone wrong before i do the power tower tomorrow cause im trying to get as much done today before tomorrow the tower will be in and really need the wires to spark and only doing the HEI didnt solve it....link to pictures HERE---> http://picasaweb.google.com/AlexWBeall
also looking at the coil wiring i have found two ways...which one is the correct, the one with green doodles or without green doodles...or if both work which is better...heres the two different diagrams...
http://download.xdrive.com/sp/234278...T&partner=xdrv
http://download.xdrive.com/sp/234278...V&partner=xdrv
Last edited by craptastic93; March 6th, 2007 at 06:27 PM. Reason: Automerged Double Post
Old March 6th, 2007, 09:44 PM   #154
KevinD
Moderator
KevinD's Avatar
As to those drawings: they're both correct.
This thread is CLOSED! If you have problems with this modification, REREAD THE POSTS!
If you're really having problems, start a new thread
Thanks.
KevinD
KevinD is offline
Powered by vBulletin® Version 3.8.4
Hosted by Intrus Technologies :: Managed IT Solutions
Solar Lights | Cheap Home Insurance | Cheap Home Insurance | Nikon D5000 | Debt Help
