Go Back   ProbeTalk.com Forums > Tech Section > 1st Gen (89-92) All
1st Gen (89-92) All Discussion of Maint Issues for 1st Gen (all models)
Old March 29th, 2004, 12:41 PM   #1
itscard0man
hole in flex pipe, make car run bad ?
ok , I was bringing the car out of the drive way and its so low that it scrapped the flex pipe, and when I look at it it seems like alot of the braides in it was cut out maybe there is even holes in it.. when im beside a wall or something and at idle I can hear the exhaust coming from it, so im pretty sure there is a pretty nice hole in it.. im just wondering would the holes cause alot of popping ? and sluggy driving, like say I shift from first to second whenI go into second ( just crusing ) it feels like something is holding the car back for about 1 second or so then it just picks up, ( and I kept my foot on the throttle the same way with out pressing or nothing ). oh and what other probs does a hole in there cause and is there an easy way to fix it ?
1 more thing.. is it normal for our cars that like when u mash on the throttle it doesnt really go anywhere until the turbo start's boosting ?.. because when I step on the gas out of know where say with out making it spool it doesnt really make a diff until the turbo starts boosting..while with my dx as soon as I step on it I felt the torque..
3" cat-back exhaust, APEXi N1 muffler, filled mounts, WALBRO255lph pump,sabb93 fmic, 2.25" IC press bent piping, ,turboxs boostcontroller 15psi stock turbo,MAGNACORE 10mm wires, NGK V-power plugs, over bored .020 over, ported & polished head, double valve springs, SS valves, 5 angle head job, ZombieSS chip...
http://www.cardomain.com/id/cardo
itscard0man is offline   Reply With Quote
Old March 30th, 2004, 04:26 AM   #2
ProbeGT90R
Re: hole in flex pipe, make car run bad ?
well a hole just makes a disruption in the flow and can change things yeah. you would have to get a new flex pipe welded in to fix that, or get a hard pipe put in so that it doesn't happen again. or just cut the exhaust off at the down pipe and freeball it, heh. but that would be really loud.
yeah it's called lag.
"Gone" but still around...
, RIP
V8 4.7L 4x4 5spd
5spd, new project
ProbeGT90R is offline   Reply With Quote
Old March 30th, 2004, 08:36 AM   #3
turbo2nr
i recently had the same problem, my flex pipe had holes in it and the car wasnt preforming to how it should be.. i changed the flexpipe and the throttle response was better for me..
1
turbo2nr is offline   Reply With Quote
Gran Turismo 4 Car list. supergoat Probe Lounge 64 January 28th, 2005 10:39 PM
PHD Level Math (andrew, double check me) ShadowSE SCProbes 27 February 23rd, 2004 08:26 PM
This whole car thing is kinda pointless, isnt it? ness2728 Missouri Probe Owners Club 23 October 21st, 2003 02:20 PM
Is it possible for my car to run with a bad disty? MikePGT 2nd Gen (93-97) V6 2.5L 6 June 25th, 2002 07:37 AM
