Ok, i wanted to re-adjust my tps. I couldn't get anything to work right, I wasnt able to get any kind of voltage reading except a common .15 (wtf!).
I had the tps connector off and was plugging the positive multimeter into each lead so that I could get some sort of voltage. Nothing, so I switched the multimeter (Haoyue DT830B) positive connection from "V something m A" (the 'something is a sigma or a delta or the like), to a 10ADC output.
Upon switching to that output I tested each lead again, and when I got to the top lead which is green, i heard a couple clicking noises and what sounded like the fpr moving fuel very rapidly. I wanted to know what this was and tried it a couple times, each with the same whoosh of fuel noise and the clicking/popping noise.
Now the car turns and turns and won't turn over! I checked the fuse box where the popping was coming from and it looks like fuses are blown on the 30A fuses and the 60A's. I can't really decipher if they are blown. I switched some around that looked good but to no avail; no full start.
I hope someone can help, I should be at work in half an hour but I can't if my car won't start.
