| 2nd Gen (93-97) V6 2.5L Discussion of Maint Issues for V6 |
Thread Tools |
#1 |
Ok, I added first setup for those that don't have switch, so that they can test idea. There is no need for any distributor modification, no opening and pulling parts from inside, all modification are done on cables outside distributor. It is possible to make this work only with pocket knife on the road
http://img64.imageshack.us/img64/8545/HEI.jpg http://njsr.org/pics/albums/userpics/normal_HEI.jpg Second schematic is for those that have switch. http://img28.exs.cx/img28/148/HEIswitchSTOCK.jpg http://njsr.org/pics/albums/userpics...witchSTOCK.jpg This is draft. Only for experienced and responsible at this stage of testing. There is no need for any distributor modification. All modifications are done externaly. Currently it is not possible to switch while driving car And, Yes I need volunteers for implementation and testing. Possible for porting this design on other years of Probe. OK, I see that I need to clear some things, so that people can easily port this schematic to 93 or others years. Connector C134 : Pin 5 - is transistors emiter that is grounded Pin 6 - is transistors base that is connected to PCM (computer) by cuting those two wires you are disabling switcher transistor inside distributor. Pin 5 wire that is cutted is ground, and that ground you need to connect to (W) connector on HEI module. Pin 6 wire that is cutted comes from computer and you need to connect it to (G) connector on HEI module. Connector C170 Pin 1 - is transistors collector that connects to primary coil(- side), and goes to DLC connector IG- Pin 3 - Comes from ignition Switch and connects to primary coil (+ side) Pin 1 should be connected to (C) connector on HEI module. HEI module switches that connector on and off ground. (B) is power supply for HEI module that needs to be connected to Pin 3 Hope that this helps in porting to other years of cars. OK, from schematic it looks like 1993 is same as 1994 so, yes you can try same schematic for 1993 year. For 1995 it looks like they switched position of two wires, so everything is same for conector C134 (6 pin connector), but C170 (3 pin connector) have been permutated so for that year Pin1 should be connected to (B) connector on HEI module and Pin2 should be connected to (C) connector on HEI module. Hope that helps! I will try to make pictures for 1993 and 1995 years, but I need confirmation that this setup works on those years first. Well, now I need help from you! Check this thread http://forums.probetalk.com/showthread.php?t=1701114528 If somebody helps me find those connectors I can make fix for distributor that will be simple as plug and play. No cuting, no splicing, nothing, just disconnect distributor two connectors, plug HEI and drive!!!!!! Plug and drive solution. But I need those connectors! Just imagine, your car dies on road, and you can just unplug connector, plug HEI and drive. No cutting, no splicing, no thinking what wire goes where, just plug it in. Last edited by kuki; April 8th, 2005 at 02:29 PM. |
#2 |
link aint working
#3 |
Balls Across The Nose
worked for me...nice diagram.....you need people to try it?
#4 |
Where can I upload pictures and schematics so that they are available all the time to others?
Thanks |
#5 |
o=II=o
www.njsr.org
IIRC, the upper right of the page has an uploader section Your original picture is working. Looks like a good setup. You may even be able to test back to back stock vs HEI ignition systems.
Marc M.- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 177.4 whp/159.6 wtq 2000 BMW M-Roadster 1976 BMW 2002 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Omaha95PGT; August 3rd, 2004 at 10:35 AM. |
#6 | |
#7 |
Moderator
The circuit numbers & wire colors you're using change somewhat, depending on the year. Look at this thread for distributor wiring & connector diagrams for all 2nd Gen. PGT's.
KevinD
1995 Sapphire Blue Mustang GT Convertible, 2006 Storm Red Metallic Mercedes-Benz CLK 350 Cabriolet, 2006 Dark Shadow Gray Ford F250 V10 Supercab 4x4, 2003 San Marino Red Acura CL Type S, 2002 Burgundy Pearl Suzuki XL-7 Touring, 1971 Spring Green Jeep J4000 Gladiator, 1966 Signal Flare Red Ford Fairlane, to name a few... |
#8 |
will those diagrams above work on 93 disty's?
#9 | |
#10 |
o=II=o
Actually, the wire position should match perfectly between the '93-'94 disty's. The only thing that won't match up are the wires' colors. In other words, go by the wire position not the color.
Marc M.- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 177.4 whp/159.6 wtq 2000 BMW M-Roadster 1976 BMW 2002 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#11 | |
#12 |
With this setup....will the tach work???...ANd do this fix really work....I'M waiting an answer to begin it...thx
#13 | |
FWIW, YMMV, EIEIO MM7 and MM8 - Showroom Class: Best in Show '73 Jeep Commando 4X4X4.2 '87 Jeep Grand Wagoneer C.S. |
#14 |
Why are you cutting the wire on pin 5? I didn't. The guy that originally made this mod didn't, why do you need to?
93 PGT Electric Blue KL-Z(zed To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. )E, Stoker100 Chipped To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , OBX headers, JJ TP, Vibrant Power 1 muffler, 67mm bored TB, CAI, CM#2, MX-3 FW, Ultimate STS, Homemade Grounding Kit, AWR Sway Bar, Rear Protege Calipers. |
#15 |
I did this mod exactly as shown, cutting pins 5 and 6. 50 miles later it seems to be working great. Read about it here:
http://www.pagel.net/Probe Thanks. |
#16 |
Has anyone confirmed that this works? I have a 95pgt and i'm ready to cut/connect the wires as we speak. The 95 disty's 6pin connector has 5 wires though, with one connector not in use.
'02 WR Blue WRX 21psi = 322ft/lb & 357whp To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Ex: Laser Red '95 Probe GT MTX SUCK-SQUISH-BANG-BLOW! |
#17 |
for those skilled in electronics who want to look at changing the existing ignitor IGBT transistor and use an external coil..in the disty... here is the work ive done regarding the ignition so far..
info on how to source one here.. http://www.incony.org/KLZEWiki/pwp_1...Page&iPage=HEI |
#18 |
HELP THE CAR WON't Start CKP & CID
i messed up this mod. I had two wires crossed when i cranked it the first time. I think I may have messed up something now. I returned everything back to stock and now I have CKP & CID error codes. where is the crank-ID sensor? Is it part of the ICM inside the distributor? I cant get spark even though I returned everything back to normal. The 2.5l 94probe was running fine before I did the HEI mod. All the fuses are good. How do I fix the CKP & CID so I can get running again? Please help?
#19 | |
Well, in some situation it is possible to leave (Pin 5), but that depends of the condition of transistor. If transisor is burned in way that his impedance is infinite than you don't have to cut (Pin 5). If transistor is shorted and that way distroyed, than you can not use this scenario. Also in case that distributor works fine before this modification, if you don't cut (Pin 5) you risk your good transistor inside distributor, because I'm not sure what voltage will be in that case between base and emiter (In that case stock transistor and HEI work in paralel). It is possible that even in that case everything would work fine, and in that case both transistors, internal stock, and external switch in HEI would work together, but that is something that needs testing and more money than I have, because as I sad you risk burning good stock transistor and destroying stock distributor. |
#20 |
Simplest HEI-STOCK replacement for testing
Well, simplest solution, no need for opening distributor or cuting wires, just splice them.
http://img156.exs.cx/img156/5402/heisimplest2gu.jpg Same as above, but now you can switch between stock ignition or HEI ignition with simple and inexpensive switch. http://img25.exs.cx/img25/4879/heisimplestswitch5ur.jpg Please this schematic is for Ford Probe GT 1993 and 1994. Please post results here, and your experience which ignitor works better stock or HEI. Now is possible to compare them, just by simple switching between them. Last edited by kuki; April 8th, 2005 at 02:40 PM. |
#21 |
1994 pgt
is this the correct diagram I'll need ? http://img64.imageshack.us/img64/8545/HEI.jpg Have others tried this way of doing it ? Thanks Last edited by eazypic; April 8th, 2005 at 08:25 PM. |
#22 | |
Yes, jp94GT tried latest one, you can check his site with lot of pictures http://www.pagel.net/Probe And please post your experience, which one worked better for you. My advice is that you start with first one , because you don't have to cut wires, just splice them. If it is not working, it means that ignitor is probably shorted, and in that case cut those wires to disable stock ignitor. In that case use second schematic. |
#23 | |
#24 | |
I fried the CPK1 inside the stock disty So I replaced it with cheap reman and it ran great for 2 weeks then it completely died, took my alternator with it I even replaced both axles because my boots were leaking I had to crack through afrozen bastard of a nut too! So the only thing left is an O-rings inside the tranny that is making my shift-rod leak. Well now that everything except the leaky tranny is replaced & running I have: detonation &/or pistron slap &/or valve spring failure on cylinder #4 The car has really kicked my ass this time I'm gonna work on my bike instead i'll come back to this probe again in a few months after i can get some riding time out of a more reliable method of transportation I love probes and think they are very reliable cars this one just doesn't like me very much |
#25 | |
| Thread Tools | |
