| Register | FAQ | Members List | Timeslips | Calendar | Arcade | iTrader | Mark Forums Read |
Thread Tools |
#1 |
Experience Cert. PGT Tech
Change your own clutch..........
I just PM'd this to mrduke to help him with his weekend coming up, figured it could go in here as well.:
My best time is 1 hr 37 minutes OK, as in Spaceballs, here's the Short, short, short version:
do clutch replacement and FW? if applicable. MAKE SURE THE CLUTCH IS DEAD CENTER....use the alignment tool. Tricks on install: installation is reverse of removal but..... Note orientation on upper 2 MM bolts and 2 studs. use automotive lubricant on input shaft, teeth, and T.O. bearing shaft. hit the steel sleeves on the edge of the bell housing as well, to help it sink when you seat it. you didn't mess with the passenger side on purpose, because now you have a shaft that will help you guide the transmission back home. When you go to put it in, sink that shaft first, then play with the alignment on the input shaft. Careful, it can/will fall back off even if you think you got it on....so thread that 14 mm bolt back in when you can get it to line up to secure the transmission Oh, add fluid, pump clutch a few times first, and check your engagement before you get it down. good luck, that is the short, short, short, short, short, version.
¶¶¶ Spyder Mica Metallic1994 PGT ZE-T04E Intercooled @ 6 psi.. ----- 3yrs boost , MS Soon ¶¶¶ Arancio Atlas Metallic1995 PGT NOVI 1000 Intercooled @ 10psi. ----- STUPID FAST ¶¶¶ Verde Mica Metallic 1993 PGT Modified, Sanctified, Retired. ----- Damn I miss her. Last edited by TravisWilliams_GT : May 28th, 2007 at 12:34 PM. |
#3 |
um, sticky? I'd say that's very useful information. Hour and a half, eh? You were flyin'.
#4 |
An hour and 37 mins, thas wild.
KL-ZE, Southbend Clutch OFE, 11 pound UR flywheel, cross-drilled rear rotors, CAI, sleepy eyes, H-4 conversion, NGK V-power plugs, MSD super conductor wires, MBX UDP Just moved to Boston any MAPOC members in the area. Hit me up with a PM. |
#5 |
MMMM sticky!!!
New Ride: 95 mustang gt... SOLD !1996 Ford Probe GT- (14.83 @ 91.8 MPH 60' 2.112) KLZE, Mx-3 flywheel,MSD Window Switches, Exedy Clutch, Autometer Gauge pods, cold air intake, Custom 2.5 inch exhaust with flowmaster super 40 muffler, Slammed with cut Dropzone Springs 1993 Base Sold- Lots of interior paint... Adam L |
#7 |
A vote for sticky is a vote for saving lives!
I Vote Sticky!
BC Probe Owners Club is VERY MUCH ALIVE - www.bcpoc.ca 93 PGT 2.5L SILVER - Stock DE, ZE Intake Manifold, T3/T4 .50/.63 AR Turbo, Valant Turbo Pipes, Tial 38mm Wastegate (~9PSI), Custom Water/Meth Injection, Megasquirt v3 (MSnS-Extra 029q2 Fuel/Spark), Millennia Injectors @ 70psi, 65mm TB, JJ Resonated TP, Centerforce DF Clutch, MX3 Flywheel, AWR Mounts, it begins all over again... 93 PGT 2.5L BLACK Dismantled GARAGE - The hybrid with a piston hole... lots of various leftovers... |
#8 |
This should go into the archives!
#9 |
I have two words for high speed repairs: Impact gun.
That is seriously quick though regardless...
Jim K. :89 LX: Gone but not forgotten.:96 PGT: Its not purple dammit! Its BOYSENBERRY! 267k and still climbing. When I go for a drive, I leave life behind. Friends, work, everything. Its just me, the car, and a twisty road. The exhilaration of being on the edge of catastrophe is something that I will never be able to give up. |
#10 |
Out of the woodwork
It took me 12 hours to do my transmission swap (MTX to MTX) I hate you.
Dan- ASE certified-A1, A4, A5, A8 Life, Liberty and the Pursuit... R.I.P. Joe Mohr 10/3/06, Tom Major 2/17/08 95 S10 ecsb, 5.7 L31, ported heads, 9.5:1, Crane(.484/.512 216/228 112LSA), upgraded injector, Hooker LT's, 2.5" ORY, 40 series flow, 4L60E, 8.8 posi with 3.73's, 7427 PCM in PFI mode, $OD. - Daily Driven! |
#11 |
wow It took me 2hrs just to get my trany out of my 1st gen. Some day I will beat that time.
Matt
R.I.P. Roy W Clark You will be missed. 06 subaru Impreza 2.5i siting on cobs "Sir, you got crack paraphenalia in your spagetti noodles" myspace.com/thebigsmarty Originally Posted by 04.SPT.WRX ... ride cushioned by a load of poo ... |
#12 |
I honestly have forgotten how many of these I have done......as well as engine swaps (best time 7 hrs 10 min start to finish and drive the car away, included WP, TB, TBT, C/FW and VCG install)...................you do enough of them and you get into a rythim, knowing what tool you need enxt before you get to that point, knowing what bolts are next to be removed....ect.....
and .............I don't use impact/pneumatic tools...... all ratchets and pliers, I prefer to feel the pressure/force applied, you loose that with air...
¶¶¶ Spyder Mica Metallic1994 PGT ZE-T04E Intercooled @ 6 psi.. ----- 3yrs boost , MS Soon ¶¶¶ Arancio Atlas Metallic1995 PGT NOVI 1000 Intercooled @ 10psi. ----- STUPID FAST ¶¶¶ Verde Mica Metallic 1993 PGT Modified, Sanctified, Retired. ----- Damn I miss her. |
#13 |
was that motor swap alone or with someone else? The best time my roomate (harvey93gt) and I had was starting around midnight and backing the car out with the new (read: not blown up) motor at around 530-6ish the next morning.
Jim K. :89 LX: Gone but not forgotten.:96 PGT: Its not purple dammit! Its BOYSENBERRY! 267k and still climbing. When I go for a drive, I leave life behind. Friends, work, everything. Its just me, the car, and a twisty road. The exhilaration of being on the edge of catastrophe is something that I will never be able to give up. Last edited by WhiteDart : October 3rd, 2005 at 12:54 PM. |
#14 |
I work alone...........
every now and then I'll have a padowin learner with me, but that one was alone.
#15 |
That's a good time! It took me almost 6 hours to do mine, well that was by myself and without power tools.
#16 |
Six Star Member
my fastest time is 4 hours. but we had to manually resurface the flywheel in that time with sandpaper. thats part of the 4 hours. someday, i will be like Travis Williams. i did a PGT clutch/flywheel a few days ago, being lazy, took 5.5 hours or so.
-Jay ASE Master Certified ASE L1 Advanced Engine Performance Specialist THE RACECAR daily - '95 PGT mtx stock HOW TO TEST YOUR VRIS |
#18 |
PT Master
awesome write up. I took some pics during my recent clutch job, I'll add them to this post shortly. It took me probably a total of 7-8 hrs working VERY meticulously, yet wasted.
Mike
96 PGT - 14.639 @ 91.54 mph N/A 2.025 60' - 2605 lbs CS Lip ll Megasquirt ll ZE-IM ll Hotshot Headers ll PRM CAI ll Illuminas/Intrax ll 6 puck/MX3 FW ll RR Shifter ll 19" Giovanna Kobell Black Roof ll Black Leather 93 PGT-ZE - 14.433 @ 96.06mph N/A 2.159 60' - street tires - 2555lbs ZEX ll Seli Cams ll Walbro ll Fidanza/DXD ll Addco ll PS Headers ll 65mm TB ll PRM CAI ll Blues and GC's ll MX6 Black Leather |
#20 |
awesome write-up i used it already doing my clutch and flywheel, went great! sticky
93 Mx-3 GS, KL-ZE, Fidanza flywheel, clutchmasters stage II clutch, Ebay headers, 2 1/4" exhaust no cat, magnaflow muffler, sts |
#22 | |
What's your average time doing the headers ? sticky
2007 Cobalt SS/SC 1994 GT, MX3 FW, Stage II CM, Borla, headers, STS Last edited by stinkyP : August 1st, 2005 at 10:51 AM. |
#23 |
This post so proves why Travis Williams is Travis Williams...
-------------------------------Wes Fenton------------------------------- / 03' Dinan Cooper S / 04' Explorer XLT / 06' R6 ~Track / 93' Del Sol Si / -------------------------------------------------------------------------- --------No longer a probe owner, but I'm still a probe enthusiast!------- -----------------I can't believe I made it to 9 Myrtles!!!----------------- |
#24 |
1 Hr 37 Min.. Thats Insane!
95 Geo Tracker - FLIPPED | 87 Nissan 200SX - SOLD | 95 Geo Prizm - 2 10"s(JUNKED) | 85 Toyota Supra - 4 10"s (JUNKED) 99 Mazda 626 - SOLD | 93 PROBE GT - kitted & BLOWN 2 pieces | 94 civic EX - SOLD | 89 Isuzu I-Mark - SOLD | 98 Isuzu Rodeo - 2 10"s | Yamaha Maxim 650 SOLD | Honda CBR 600 F2 (DAILY RIDE) | Im a Dad |
#25 |
I hate to rush when i work on cars but if i was forced too, i might beat him by a minute or so
Doing the work on my car only!! All bolt, nuts, surfaces, brackets etc etc are anti-seized and painted for extra protection soo i know i wont have trouble in the future cutting and grinding them. But seriously 1 hour and 37 minutes is just crazy! I vote for "Sticky"
Rio Red 94PGT, T3T4E 50 trim @ 7.5psi 257whp & 245wtq on Mustang Dyno with a ported T3 60 trim @ 8.7psi ,,, oh and I swap engines every other oil change Pearl White 91 infiniti M30 Coupe-The back up car and future project (5-spd & turbo). |
| Thread Tools | |
