| North Eastern Probe Owners Serving the Eastern and Northeastern United States |
Thread Tools |
#1 |
Experience Cert. PGT Tech
OCTOBER MARYLAND / NOVA RoadTrip. 10-4 to 10-7
I need to organize the itenerary and waypoints for the 4 day weekend.
I have an idea of who needed work done, and I've arranged weekday and weekend opportunities. Post here for what you needed and when is best for you.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ----- 3yrs boost , MS Soon To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ----- STUPID FAST To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ----- Damn I miss her. |
#2 |
I need to install my UDP and posibly my clear corners. anyday works good for me but i'll let you know closer to the date
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. totaled...Remembered for what she was and what she will be! 98 Pontiac Grand AM Blown Engine To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Boost in the works! |
#3 |
i might need alot done ill let you know travis. it depends on if i get a new tranny and get it installed by then or not....
ZE, MS Tuned by Shaodome,Probinator Chip, 6 puck clutch, K801 Flywheel, Traction bars, Tranny Saver, AWR Mounts, CAI, STS,Borla,Cross drilled rotors, SS Autochrome headers, TB spacers,NKG spark plugs, 10 mm spark plug wires, 93 ZR1 Oil Filter, KYBGR2 Struts, Eibach Springs,Escort front strut mounts, 65 MM TB, 20% tints, protege rear calipers, rear seat delete. Sold To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Montego Blue 335i Coupe 6 speed SOLD Black G35 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Hand is in air, yelling, pick me! pick me!
96 gt ze 5 spd., hotshot headers, cai, 2.5 full exhaust, baker electronix window switches and rr inserts. Sometimes it more of a money pit than a car! |
#5 | |
Dedicated Member
-Nate Cade Proud to be an American To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. lightly modded 2010 Chevy Cobalt LT four door, auto, boring, reliable. |
#6 |
you already know about me and if you want to finsh up with someone one day and start with me the next morning, I can offer a bed for you to crash on for the night
///M-POC To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 448whp at 24psi Built by Me, Tuned by SHAODOME MMX - PRD BEST of Show and 1st Place Unlimited Class MM8 - PRD BEST of Show |
#7 |
well if your in my area and torch is running you know you have a helper here! Just let me know!
From a Probe to a MX-6, and the desire still hasn't died! 8 is the magic number. |
#8 |
Daily Driven
I may need some work done.... dunno if im gonna do it myself by then or not. But hey, the Mazda meet is in Harpers Ferry WV that weekend, so if you are coming through stop by, I linked it in a seperate thread....
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 93 GT--- Stripped, scrapped, and raped for parts To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#9 |
Damm i wish you guys were closer to philly i need help with my PGT. Idles bad, need to replace motor mount and clutch. Nobody lives in philly with a probe
#10 |
i might need some work..... i know my dad wants to talk to you about the turbo setup. He's in the process right now. If you can stop by, that'll be great.
New Ride - '03 Berlina Black S2K - A Few Mods 1994 RioRed PGT, 1997 Black GTS - Gettin' Some Rest....... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 1999 Black SHO - Intake, 3rd Cat. Delete, MagnaFlow Exhaust, Cams Welded, Tranny Cooler, FPS Tuned........ Sold |
#11 |
I'd like to get some things concreted as soon as possible. That way I know what tools to bring.
#12 |
Needs heads and valve springs installed. you game?
J.D. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#13 |
I probably want to change my clutch master cylinder. I might also give you my ZEIM to have it polished as before and modded with the EGR setup.
I think my dad just has questions about general turbo setup.
#14 |
That Guy
Travis, I PMed you about my stuff.
Patrick Desmond NEPO-VA 2008 350Z 1995 PGT - Soon to be some sort of project |
#15 |
If I don't go to the Coast to Coast meet I'd be up for some beer one night
ßill
2006 MAZDASPEED 6 GT To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 94 PGT- w/some mods To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. NEPO NY LONG ISLAND™ -oh yeah and "underground" |
#16 |
question, are you going to do work in MD first or N.VA (what days are you going to be in each state)?
#17 |
If you know how to do the HEI mod I'd be very happy since my disty is dead and the car wont start. I'm in NVA, 4 blocks right off 495 so excessive driving won't be an issue for you
#18 |
Bill, thanks for the offer, I just very well may take you up on that.
Trip route depends on the final list and jobs apparent. And Probey I can do HEI mods all day long.. Hopefully the coil is still good, and it is just the ignitor that has failed. If you have to add an external coil as well, bear in mind modifying the 03 disty to that point needs a MSD power tower modified into the disty cap (also available from PRD), where as if you were to have a ZE disty, there would be no modifications externally.
#19 |
ok......well, imma add the battery relocation to the list also
#20 |
Soo... is that a no on the valve spring install, or did I get skipped?
#21 |
Timewise that is a major undertaking. However, I may have something that'll work out...........
#22 |
Edit:
Nevermind Travis.......just sold the car Last edited by probey; September 20th, 2007 at 05:43 PM. |
#23 |
hey travis, did you receive the package?
#24 |
travis if it makes it any differences i can meet at jds so you dont have to jump around more than you have to.... and there will be more hands to help with what jds needs done... just let me know oh all i need is my UDP not the clears
#25 |
PT Know it All
elkton,md if you'd like.
Chris Rose |
| Thread Tools | |
