Old April 22nd, 2008, 05:01 PM   #1
wannaberockstar
wannaberockstar's Avatar
Please check my timing!
Hey guys:
I am hoping that you veterans out there can tell me if my timing is off. I just bought this KLZE and I want to be extra sure that the timing belt is installed correctly. Everything looks okay to me except the front cam sprocket. It seems to be a little off, but I'll defer to you.
Here is the crank sprocket:
And the rear cam sprocket:
And finally the front cam sprocket:
I seriously appreciate your help!
Tim
wannaberockstar is offline   Reply With Quote
Old April 22nd, 2008, 05:12 PM   #2
JKpgt96
Drives Light Blurple Car
JKpgt96's Avatar
To me, both of them look a smidge out (they both look advanced just a touch), but I would spin it around a couple times to see if the slack would work itself out and you would be alright.
JKpgt96 is offline   Reply With Quote
Old April 22nd, 2008, 05:52 PM   #3
FWP!
PT Inner Circle
You're not going to get it any better.
2007 Audi RS4
FWP! is offline   Reply With Quote
Old April 22nd, 2008, 07:32 PM   #4
SuperSquid
It's all J-dogg's fault
SuperSquid's Avatar
I'm just sooo used to using the dual dots on the rear cam that line up with the valve cover....using that single one doesn't look right to me.
Old April 22nd, 2008, 08:37 PM   #5
gandarilla
get the align teeth painted with liquid paper. seems to me to be on time...
BIGGEST WHP MAZDA MX6 KL EVER-----KLZE with PAUTER Rods and Wiseco Pistons 8.5:1 ...........553whp and 495tq@28psi and still running....
1997 Silver Frost PGT... like new...
dude, your email address isn't working ~admin
gandarilla is offline   Reply With Quote
Old April 22nd, 2008, 09:02 PM   #6
Workman
Looks like your belt's kinda frayed on the edge in spots. Any issues with the belt "walking" while its running? As for the timing, that really is as good as its gonna get. Are you having any problems with it running or just curious?
1995 Lincoln Mark VIII
I'm getting old... my sports car has air ride.
Workman is offline   Reply With Quote
Old April 23rd, 2008, 05:25 AM   #7
wannaberockstar
I haven't fired it up yet (it's out of the car.) I checked the timing alignment with my DE motor, and it seems to be in line with the DE's timing marks. It's just not -exact- which bothers me slightly. I played around with it last night and moved it around slightly. This particular situation is the best.
Thanks for your input, I really appreciate it.
Tim
Old April 23rd, 2008, 05:12 PM   #8
1993fpgtatx
PT Master
what effing camera do you have? lol
93GT. Black/Slammed.
All Motor Straight Neck ZE Swap.
MAF Swap.
All Bolt On's.
1993fpgtatx is offline   Reply With Quote
Old April 23rd, 2008, 06:46 PM   #9
KING6
The arrow on the crank should be pointing in the the dip. One notch from TDC
KING6 is offline   Reply With Quote
Old July 9th, 2008, 05:56 PM   #10
ImportKillerMan
hey guys question, I had the motor apart and its now going back together. Aglened the cams like the book said. Alls well both stubs on cam line up with head mark. However when i put the R gear on the R and dot do not line up unless i turn the cam. Normal? if some one would tell me how to post a pic i could show u.
ImportKillerMan is offline   Reply With Quote
Old July 9th, 2008, 06:01 PM   #11
halfriceboy
Six Star Member
halfriceboy's Avatar
looks good, crank it over manually a few times to see if it stays. i always start the engine for about 10 seconds at this time.
-Jay
ASE Master Certified
ASE L1 Advanced Engine Performance Specialist
daily - '95 PGT mtx stock
halfriceboy is offline   Reply With Quote
Old July 12th, 2008, 05:14 PM   #12
ImportKillerMan
does the klze's timing belt setting differ from the DE's? im swapping from a de to a ze and i never checked the timing marks on the de. What i did notice is that the ze's gears are not flipible like the de's. also i lined up the cams like the book said. the gear locating pins need to line up with the timing mark which makes the 2 yellow strips on the mesh gears line up. Everyone still follow? I put the L gear on alls well, i go to put the R gear on and the R gears dot doesnt line up. I need to move it clock wise to line up, is this normal? the book doesnt mention this.
can anyone verify this as gright or wrong? is that how its should be?
Last edited by ImportKillerMan; July 13th, 2008 at 02:12 PM. Reason: Automerged Doublepost
[IMG] code is On
