Go Back   ProbeTalk.com Forums > Tech Section > Racing/Suspension
Old August 17th, 2009, 02:29 PM   #1
driftwood
driftwood's Avatar
oil consumption for you track guys
how much oil on average do you guys go through during track/autox events?
out of curiosity?
driftwood is offline   Reply With Quote
Old August 17th, 2009, 04:09 PM   #2
slinkyPgT
me none...
matt this is like the 2nd thread you made about oil consumption problems.
have you tried using a new PCV valve? if its plugged all that extra crankcase pressure will blow right past your valve seals and burn off.
if it ain't broke, mod it!
slinkyPgT is offline   Reply With Quote
Old August 17th, 2009, 07:59 PM   #3
driftwood
driftwood's Avatar
yes the pcv is good...
maybe im just a little paranoid...its not a ton of oil being lost...
but its like i cant rev on my car without seeing a noticeable difference in oil level... & i'm letting my car sit on level surfaces for hours before checking...
im talking about 1 day sessions too... not talking about over a span of a month or 2... 1 days worth of spirited driving & im noticing slight changes
Old August 18th, 2009, 08:19 AM   #4
lthomas2g
dose drag racing count as track? if so i use very very little on 12passes i fill my oil to the top of the full after 12 hard runs it maybe just little under the full id say maybe a cup of oil every12 passes but most of that is going throw my trubo i think
black 94 gt turbo 12.503 at 116.95mph best 1/4mile 1.911 best 60 foot
white 93 gt "gas saver"
red 97 gts "hit"
red 93 mx6 ls
lthomas2g is online now   Reply With Quote
Old August 18th, 2009, 08:58 AM   #5
elkco75
we run a 1994 2.0 probe in a FWD 4 cyl class on a local dirt bull ring. it uses about a quart of oil in and evening which is only about 25 laps on a 3/8 mile track. Of course this is at about 7500-8000 rpm. It smokes bad when you first start it and idle. Not too noticeable at speed. Thought it was a bad vavle seal but we must have a broken ring in #1 cylinder. That plug is oily all the time. Still makes plenty of power. Will rebuild over winter. Key is, do not let it get down on oil. A quart of oil is cheaper than a blown engine.
elkco75 is offline   Reply With Quote
Old August 19th, 2009, 02:17 AM   #6
dillinr
I see what I consider very little oil loss. Perhaps at most 1quart over 1-2k miles, in which I might do 5-10 autocross events.
Of course at those events I may have a co-driver, in between she sees the rev limiter on the street a few times, and plenty on race day.
I have noticed that with a very high rpm 1-2 shift, on the limiter around a corner she will occasionally puff a small blue cloud, but with all the oil sloshing around I'm not surprised, or worried.
Track days I've seen no oil consumption. That's 4-5 20min sessions. It gets changed just before and immediately after a track day.
Ryan
'94 Mazda MX6 V-6
STX Prep:
MFactory LSD [] TEIN [] Enkei 17x9 RPF1 [] Toyo R1R [] Hawk HP+ [] Schroth [] Corbeau [] AWR [] HotShot [] Headers [] Magnaflow [] Side Exit []
Old August 19th, 2009, 07:18 AM   #7
driftwood
driftwood's Avatar
you run synthetic during events?
Old August 19th, 2009, 01:42 PM   #8
dillinr
Mobil1 Extended Performance 10w-30 for normal driving and autocross. It gets changed when it starts getting dark. Usually around 2-2500 miles.
Redline for track/lapping days at MMP. The weight depends on ambient temperatures. Pretty much anything above 90deg amb I'll run 20w-50, anything below that I'll put in one quart of 5w-30 to thin it out. Coldest track day I did was about 60 deg, for that I ran straight 10w-30.
I run Redline for the track because it's got a LOT of moly, 6-800ppm compared to 80-100 for Mobil1. I like the thought of lots of high temperature, high pressure wear protection when I'm running at 5-8k rpm for 20 min sessions in 105deg heat, and coolant/oil temps at 230deg+
I run on fresh oil and drain it after every track day.
Overkill? Yes. But at 130k miles I'll take all the overkill I can get. It's safe to say I put more stress on my engine than most.
http://user.streetfire.net/video/MX6...gin_636119.htm
Ryan
'94 Mazda MX6 V-6
STX Prep:
Old September 12th, 2009, 10:07 PM   #9
ford13
I race at a 1/4 mile dirt oval and use about a pint to half a pint on a average night. The big question I have is how do you get that many RPM? The rev limiter shuts me down at about 7200. A little more rpm would really help!
ford13 is offline   Reply With Quote
vB code is On
Your Ad Here
