Go Back   ProbeTalk.com Forums > Performance Section > N2O Technical
Old November 8th, 2009, 05:20 PM   #1
suprakid366
A/F ratio for spray
Well im gonna be ordering my wideband tomorow and by the time it gets here i want to know what i should get my A/F ration to when spraying a 50 shot then a 75 shot. Oh and an idle A/F and when i let of the gas/spray.
So anyone know?
95 whitePgt, Fstb, Rust free Moonroof mod Polk Audio db 12"s, Alpine 850 Amp, Speedhut overlay, HIDs,
Custom VRS catback, Headers, JJ Resonated Testpipe, CAI, DXD stage 1, Mx3 fly, RR inserts, Trans saver,
V-powers & wires, Afpr, Newest mod- LC1, Zex'd
....best so far a 14.9@96
suprakid366 is offline   Reply With Quote
Old November 9th, 2009, 02:09 AM   #2
c-man
Moderator
c-man's Avatar
PS Network Nick: NT_c-man
I'd watch to make sure it stays in the 11-12 range. If you're getting to 12.5+, I'd pull fuel.
I'd just tune if for n/a though and use the plug readings to tweak the nitrous jet combos.
Chuck | ProbeTalk's Mega Moderator |
2009 Mazda 6 GT | 3.7L Grand Touring |
2003 Tiburon GT | 2.7L GK boost'd |
1995 Probe GT | 2.5L ZE nitrous'd | SOLD!!!
c-man is offline   Reply With Quote
Old November 9th, 2009, 10:07 AM   #3
KLDE Wagon
Make sure you have a few jets higher and lower for both the fuel and nitrous. This will allow you to fine tune it without making big jumps. Big jumps= bad news on nitrous applications.
Also make sure your intake clamps are Really tight and you don't spray too soon (keep it above 3K at the bare minimum). I've found out the hard way
Jeremy
85 Mercury Marquis wagon "Family Truckster": It's boosted, just not running yet! <<<New hot-ness
05 Mazda 3 5-door "Baby": Auto, wheels, HID fogs<<<DD
99 Ford Ranger XLT "Little Foot": Sold for a probe
Back to terrorize with drift-eze in the new hot-ness
KLDE Wagon is offline   Reply With Quote
Old November 9th, 2009, 11:02 AM   #4
U2SLO
Jeremy
What happens if your below 3k?
1994 PGT ZE- MTX, pacesetter longtube headers, Magnaflow exhaust, CAI w/K&N filter, Lowered on Tokiko blues, Clutchmasters RR stage 2 with Lightened mx3 flywheel, mbolin's tranny brace, ZE ePROM, PRD rear strut bar, pacsetter short shifter, HEI mod with MSD coil, Zex dry kit, Unorthadox UDP, Custom harness bar in the works, and more to come!
U2SLO is online now   Reply With Quote
Old November 9th, 2009, 11:16 AM   #5
KLDE Wagon
Usually it will backfire if over a 50 shot. Blows the intake tube apart and bends your VRIS butterflies. The motor can't consume it all quick enough and really you're just wasting it
Jeremy
P.S. See, look: http://videos.streetfire.net/video/K...ous_714016.htm
Old November 9th, 2009, 11:57 AM   #6
suprakid366
Ok stay in the 11-12 range while spraying? And then if im at 12.5 reduce the fuel? I dont like the plug readings, just always seems faulty. When i put the new plugs in a while ago and didnt even spray they were all completly white. Put afpr in and they arnt so white anymore, but they still get white when i drive around.
Just for the record.. Higher number is rich and lower number is lean?
Old November 9th, 2009, 12:13 PM   #7
KLDE Wagon
Plugs are THE way to know what is going on if you can read them right. White and brown is good. White with brown spots is bad.
No, it's a ratio of air:fuel. 14:1 is lean (less fuel for the amount of air) while 12.5:1 is richer (more fuel for the amount of air). Closer to 1:1, the richer it is.
Jeremy
Old November 10th, 2009, 12:49 PM   #8
ademan
PT Know it All
So anyone know?
i kept my as close to 13.1 as possible, i was able to keep running 113shot cold fusion jet on my stock 110hp n/a motor. running more nitrous than the motor output is never recomended but hey its a low compression motor and still running strong
1990 and 91 pgt .big turbo,big injector,f2 motor & hks fcon.
mx6lxhttp://http://www.youtube.com/watch?v=6p0yDnv3gYc
1988 mx6gt..f2 motor,hx35 turbo, 460inj,hks fcon,n20
1990 pgt (DIY PAGE) http://www.cardomain.com/ride/2423853/1
people will doubt what you say or who you are,but will always believe what you do
ademan is offline   Reply With Quote
Old November 10th, 2009, 01:22 PM   #9
c-man
Moderator
c-man's Avatar
I'd watch to make sure it stays in the 11-12 range. If you're getting to 12.5+, I'd pull pull nitrous/add fuel/a little of both.
Sorry. Typed from blackberry...auto correction didn't like my "/" ...pull nitrous/add fuel/a little of both.
Old November 10th, 2009, 03:54 PM   #10
JKpgt96
JKpgt96's Avatar
my car is tuned for 12.0-12.3 on the jug..
-John Kessler- MOPOC Mod NOT named Jarod
'96 PGT- Something NASTY is coming..12:1|I-beams|3" Exhaust|One-off Longtubes|Custom Cams|Ported Heads|Interprep Springs,etc..|Big Brakes|custom X-member|ITB goodness|Ext. Oil Pump|10000rpm|PAR 1-4th & Final|MFactory LSD|125 shot..
My '96 GT My Nitrous Dyno Current: Colt Tri-Flow Test Car
'02 Nissan Maxima SE- Tint, 6 spd, Stock Maxima E.T. & Trap Speed Record Holder14.01@99.77mph 214whp/233wtq
JKpgt96 is online now   Reply With Quote
Old November 10th, 2009, 06:44 PM   #11
GlickPGT
Exactly how necessary is it to tune? I've never really heard of anyone tuning for nitrous before now.
GlickPGT is offline   Reply With Quote
Old November 10th, 2009, 07:31 PM   #12
suprakid366
Ok thx guys for the help. But these numbers are coming from when you are actually spraying correct? Like his-
Old November 10th, 2009, 10:18 PM   #13
JKpgt96
JKpgt96's Avatar
..yes thus the 'on the jug' part.
Glick how have you not heard of one tuning for nitrous? you have to tune to for in one way or another!
Old November 11th, 2009, 12:49 AM   #14
KLDE Wagon
The manufacturers do a good job providing you with the correct jet settings most of the time but to get to most out of it you need to know what your air/fuel is doing and pull some timing to be safe.
Jeremy
Old November 11th, 2009, 05:45 PM   #15
GlickPGT
I'm not experienced in the area, but you're changing permanent settings for a temporary fuel condition. To me it just doesn't make sense.
**Disclaimer**
I am NOT experienced in this area, at all.
Old November 11th, 2009, 06:39 PM   #16
suprakid366
**Disclaimer**
Its because its still sometype of power adder. Not exactly forced induction, but any big power adder u should "tune" it to the right settings. More air/fuel= bigger boom and more heat so u need to control that boom and heat. No matter how temporary it is. As far as i understand it, all ur really changing is the fuel pressure with an afpr, but thats not even needed if u have a wet kit. And then u are also chaning the fuel/nitrous jets.
Old November 11th, 2009, 07:02 PM   #17
JKpgt96
JKpgt96's Avatar
**Disclaimer**
If you are not experienced then stop commenting! Yes it is for a temporary condition, but that 'temporary condition' will non-temporarily end your engine's life. You only would be changing the Fuel Pressure if you are not using megasquirt and only while on the bottle. Otherwise you would have a different map in your MS for nitrous.
Old November 11th, 2009, 11:27 PM   #18
c-man
Moderator
c-man's Avatar
I stopped reading at ..I'm not experienced. Please stop posting in this thread.
Old November 12th, 2009, 01:01 AM   #19
KLDE Wagon
Haha. You don't tune any different while not on the spray, only while on the spray.
I.E. you don't just up the fuel pressure to get more fuel, just as you don't on a boosted car cause when you're not boosting (cruising and idle) your car will run like balls cause it will be rich. An FMU adjusts fuel pressure to boost pressure, that's the cheap way of getting more fuel on a boosted car.
With that said, MS can switch fuel maps when the nitrous is activated OR the cheaper way is to just adjust the fuel jet on your wet kit, with a dyno and a wideband. If you're rich with a .024 jet, switch to an .023 and run it again!! That's called tuning too
Jeremy
Old November 12th, 2009, 01:40 AM   #20
c-man
Moderator
c-man's Avatar
^^^ or fork over a c-note and a handful of jets and I'll tune it for you.
Old November 12th, 2009, 01:01 PM   #21
Jarod7920
Jarod7920's Avatar
Yes....lets all resort to a haphazard tuning method cause that is the best forward progression i know of!
-J-Rod-
301whp 293wtq 9.5psi 14 degrees
93 PGT-T
08 Mazdaspeed 3 GT 280whp/313wtq
I can neither confirm nor deny that we may or may not be in what may or may not be a position to either confirm or deny what you may or may not have allegedly alleged.
Jarod7920 is offline   Reply With Quote
Old November 12th, 2009, 06:52 PM   #22
suprakid366
alright just opened my wideband and holy hell, my jaw dropped. Read through the manual and theres alot of crap u have to do for this thing. Cant believe i need to wire in this push button thing with an LED. The software is cool tho. But anyways whats the best stock o2 sensor to remove for the wideband one? The front one or the rear one?
Old November 12th, 2009, 06:56 PM   #23
JKpgt96
JKpgt96's Avatar
if you have no leaks just plug the two and have a bung put in before the cat
Old November 12th, 2009, 07:03 PM   #24
suprakid366
what? cant i just take out a factory 02, and replace it with the wideband one? And leave the other factory 02 in and wired up?
Old November 12th, 2009, 07:38 PM   #25
JKpgt96
JKpgt96's Avatar
why only read from one bank? it would cost you like 10 bucks to have a bung welded in so you can account for both banks..
vB code is On
Your Ad Here
