So far i have eliminated the ATX solenoid codes by wiring up VRIS solenoids to Shift a, b, c, and TCC.
As long as you do not have any of the ATX (D) (2) (L) (R) wires hooked up to +12v telling the ECU what gear you are in it will not bitch about the missing trans temp sensor or the missing input turbine sensor. It will not shift while driving... it just thinks its in neutral or park.
If you have (D) hooked to +12v the solenoids click when it shifts at specific speeds. But you then get another code for Input turbine sensor.
The next step is to try and do this more cleanly with a resistor network.
