Closed Thread
Old September 24th, 2001, 11:30 PM   #1
rikpimp
ok 1st is ok 2nd is not so bad and 3rd well ya get it. its sluggish till bout 4500rpm then it almost feels like (cant believe im sayin this)v-tec kicks in (cept ill run through hondas all day) injectors? compression? is that how it feels with dohc? i just got it so i dont know (used to 93 gt) oh yea and by the way my clutch is alil wore could it be that?
93 gt 113,000 miles 5- speed eibach, flowmaster, intake
i hate hondas
rikpimp is offline
Old September 24th, 2001, 11:33 PM   #2
TheProbeKid
PT Inner Circle
TheProbeKid's Avatar
What kind of intake do you have?
TheProbeKid is offline
Old September 24th, 2001, 11:44 PM   #3
HowLeTT
HowLeTT's Avatar
VRIS. Variable Resonance Intake System. Search & research it (get it? research? heh. wow, that really isnt funny at all is it? :smile: )
that kick you're feeling is probably at 4250 rpms, and your VRIS system is probably not working properly.
HowLeTT is offline
Old September 24th, 2001, 11:53 PM   #4
rikpimp
thanx man ne ideas where to search and research ha had to say it but for real ne ideas?
i hate hondas
rikpimp is offline
Old September 25th, 2001, 12:07 AM   #5
HowLeTT
HowLeTT's Avatar
try searching in the 2.5L maint forum and the 2.5L perf forum for things like 'VRIS' or be more specific if you're looking for specific info. here's a couple links to get you started, since i hate hondas too :razz:
http://64.60.145.228/forums/viewtopi...38970&forum=11 http://64.60.145.228/forums/viewtopi...36436&forum=11 http://64.60.145.228/forums/viewtopi...32065&forum=11
1993 Ford Probe GT - KLDE + N2O
228 whp 241 wtq - 2340 lb race weight
ATX - 13.44@105.1 MTX - 13.35@106.1
HowLeTT is offline
Old September 25th, 2001, 12:22 AM   #6
bluehornet
PT is my life!
I ran a search on google to see what was out there (I've never searched it before).
http://www.netspace.net.au/~nephilim/Jerry/vris.htm
http://home.epix.net/~wfmartin/vris.htm
http://pub49.ezboard.com/ffordprobef...picID=84.topic
I got lazy and only went 4 pages in. Should be enough to give you a good idea though. Well, save that last one...
bluehornet is offline
Old September 25th, 2001, 12:29 AM   #7
rikpimp
so its prolly the vris ok ok now if it dont work can i get a new one or is that hella expensive?
i hate hondas
rikpimp is offline
Old September 25th, 2001, 12:55 AM   #8
HowLeTT
HowLeTT's Avatar
read those sites and do some searching. the answer to your question is worthless unless you understand what VRIS is and how it works first. I hate to make you do work and all, but we cant spit out part #'s and answers to EVERY thread instantly at 3 am EST. Just most!
HowLeTT is offline
Old September 25th, 2001, 01:00 AM   #9
rikpimp
yea bro i did that and i just did the paper test at 3am and its not workin right im gunna chek my hoses tomm. ill keep ya posted but by chance if i have to get a new one neideas onprice? i doubt i will alil duct tape and prayin can fix nething HA (im so not used to this tech shit i had a 5.0 hahah all it was,,, was cylinders and a cam and a trans hahaha thanx alot though i appreciate it....
i hate hondas
rikpimp is offline
Old September 25th, 2001, 01:18 AM   #10
HowLeTT
HowLeTT's Avatar
5.0's rock :smile: There's alot of former and current stang lovers on this board by the way. If your VRIS is malfunctioning, tying the nonfunctioning flap(s) open temporarily is better than letting them always be closed. if something's bad its usually a vacuum hose problem. It could be a bad selenoid, if that's the case dont go to ford for one because they'll look at you like you just spoke greek when you tell them what you're looking for. Check at a mazda dealer Have you had your intake manifold off, or have any previous owners that you know of?
HowLeTT is offline
Old September 25th, 2001, 01:26 AM   #11
rikpimp
hell yea bro luv stangs just wrecked my gt with a vortech s-trim was runnin 12.6 had to stick with ford.... im not sure bout the manifold i havnt takin it off should i ?
i hate hondas
rikpimp is offline
Old September 25th, 2001, 06:57 AM   #12
HowLeTT
HowLeTT's Avatar
no, leave that sucker on there! The reason I asked is because alot of times the vacuum lines will get crossed or put in the wrong place on the back of the intake manifold, causing problems with the VRIS and EGR systems. There's no upper & lower intake on these cars, just a big old hunkin pain in the ass manifold full of flaps and carbon!
HowLeTT is offline
Old September 26th, 2001, 07:07 PM   #13
cs93pgt
my car does the same thing man i know what you are going through and it sucks i get beet by every car i race in first gear but when it hits 4500 RPM and when i hit second i come back i need help also
1993 GT laser red
k&n cone filter
more to come soon i hope
cs93pgt is offline
Old February 4th, 2007, 04:48 AM   #14
cubanfisher
i have the same problem... im picking up the vris#1 code. and i feel that "vtec-like" boost around at 3300 rpms. is that how it should work? y would i be picking up the code?
93 Ford Probe Gt 202k miles. C.A.I. 2 12" Sony X-plodes w/ 600w Lightning Audio Amp. 14 Zipties holding front bumper.
93 Ford Mustang LX 2.3L Turbo 117k miles.
cubanfisher is offline
Old February 4th, 2007, 07:30 AM   #15
vickx3
cause the first VRIS isnt workin....lol
it will give the vtec feelin when its not working and the car will suck balls until its fixed. like people said earlier in the post...look for loose vac lines FIRST! then go and see if the solenoid is bad. personally i would just go get a set from the junkyard and swap em out. and put NEW vac line son them. chances are your vac lines are old as the car so they'll need to be changed once you remove the vac lines from the solenoids.
vickx3 is offline
Old February 4th, 2007, 10:07 AM   #16
tour96se
PT Semitic God
yeah,just junkyard them(aka pocket) they can be found on the any 93 and newer mazda..4cy or 6..also you can borrow the one from your fuel pressure reg. its the same thing
93gt 230k dd.
96 pgt 135k dd
tour96se is offline
Old February 4th, 2007, 10:57 AM   #17
cubanfisher
reason i said that because on all the sites that i research on says that the vris kicks open the butterfly around that rpm range and remains closed every other.
Old February 4th, 2007, 11:25 AM   #18
vickx3
yea it does BUT you shouldnt feel it thats why i said that your VRIS 1 solenoid inst working. i went through the same prob with my GT when i first got it...i liked it at first cause i could HEAR it actually kicking in but then i realized i was loosing so much power by it not working. when it was fixed i loved my car all over again lol. and yea like tour96se said (pocket) pick up the solenoids from your local junkyard....
vickx3 is offline
Old February 4th, 2007, 11:40 AM   #19
KevinD
Moderator
KevinD's Avatar
Search: it's a terrible thing to waste...
KevinD
KevinD is offline
Closed Thread
