The KL is not the only engine with weak oil pumps. Nissan RB26 has similar issues: Turns out minimal drive contact and excess clearances hammer the pump at high rpm and it breaks apart. Nissan has one contact point, the KL has two. Source: http://www.skylife4ever.com/2011/01/...-oil-pump.html
The solution: Copy a successful design (Toyota 2JZ)
http://www.skylife4ever.com/2014/08/...urce=BP_recent
http://www.gtr.co.uk/forum/270049-sp...ump-gears.html
I'd imagine the cost to custom make one set for the KL would be insane unless you have a 3D scanner and a machine shop at your disposal. I know there's a few external oil pump setups out there that are doing well just thought I would share this.
You'll recall the big killer of the stock oil pump on the Skyline is precisely hard rev limiter slams on the narrow contact patch - it's easy to see how a spline drive would solve this problem very effectively when considering, that with the splines you pretty much get contact of all splines equally distributing the force and you have the oil film between the splines as a damper as well. In most cases there are no issues with alignment during installation, you fit the pump to the block just like you would with an oem pump.
